Harbour MiniGUI Extended Edition build 18.06 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 18.06.
* Fixed missed 'XObject' and 'OnDisplayChange' properties reference
in the Set/GetProperty() functions.
* The MODAL windows supports an optional FLASHEXIT clause instead of
an usual blocking of exit from a modal form at activate of a child form.
It is an experimental feature.
* Added Min and Max range for the NON CLIENT attributes of windows.
* Added possibility to set the position of the dialog boxes
at runtime with the following new commands:
SET DIALOGBOX [ POSITION ] ROW <nRow>|<@VarCodeBlockRow>|<NIL> ;
COL <nCol>|<@VarCodeBlockCol>|<NIL>
SET DIALOGBOX [ POSITION ] CENTER OF PARENT
SET DIALOGBOX [ POSITION ] CENTER OF <hWnd>
SET DIALOGBOX [ POSITION ] CENTER OF DESKTOP
SET DIALOGBOX [ POSITION ] DISABLE
* Updated and improved the TSBrowse library.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
(ChangeLog Last Entry: 2018-06-04 01:30)
* Added the new interesting samples and updated some Advanced samples.
A setup of the build 18.06 for Borland C++ 5.5.1 is published at
the following URL:
And you can also download from the new mirror:
http://hmgextended.org/files/CONTRIB/hm ... -setup.exe
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
Thanks for your attention and support!
Pierpaolo Martinello, Grigory Filatov and all Minigui Extended Team
P.S. There are also the private Minigui Ex builds for the following C-compilers
(available by your request):
- MinGW 8.1.0 (32-bit) and Harbour 3.2.0dev;
- MinGW 8.1.0 (64-bit) and Harbour 3.4.0dev;
- MS Visual C++ 2017 (32-bit) and Harbour 3.2.0dev;
- Borland/Embarcadero C++ 7.3 (32-bit) and Harbour 3.2.0dev.
Re: Harbour MiniGUI Extended Edition build 18.06 is published
Thanks a lot, Grigory!
Congratulation
Luis Vasquez
quartz565
Post by quartz565 »
Thank you, Grigory!
Nikos.
os: Windows Server 2019 - 64
BeGeS
Post by BeGeS »
Thanks, Filatov.
Steed
Post by Steed »
Thansk a lot
Anand
Post by Anand »
Thanks Pierpaolo, Grigory and all Minigui Extended Team for the release.
Anand
Anand
