Page 1 of 3
mouseover label
Posted: Fri Jun 08, 2018 4:07 pm
by koke
Buenos días.
¿Alguien a implementado el efecto mouseover para un label?
Vi un post donde se discutió en el 2009
http://hmgforum.com/viewtopic.php?f=5&t ... over#p7043
Pero no funciona bien en 3.4.3 y no pude encontrar ningún otro ejemplo.
Saludos.
traducido por google
Good Morning.
Has anyone implemented the mouseover effect for a label?
I saw a post where it was discussed in 2009
[url]
http://hmgforum.com/viewtopic.php?f=5&t ... over#p7043 [/ url]
But it doesn´t work well on 3.4.3 and I could not find any other example.
Greetings.
Re: mouseover label
Posted: Fri Jun 08, 2018 6:56 pm
by mol
Fee years ago I've posted sample with mouseover effect.
Re: mouseover label
Posted: Fri Jun 08, 2018 8:56 pm
by andyglezl
Re: mouseover label
Posted: Sat Jun 09, 2018 8:09 pm
by KDJ
Can somebody know why WM_MOUSELEAVE message is not generated for LABEL and another controls?
Example of code:
MEMVAR _HMG_SYSDATA
FUNCTION Main()
DEFINE WINDOW MainForm;
WIDTH 300;
HEIGHT 200;
DEFINE LABEL Label1
ROW 10
COL 10
WIDTH 140
HEIGHT 45
VALUE "This is LABEL"
ALIGNMENT Center
END LABEL
DEFINE BUTTON CloseButton
ROW 70
COL 10
WIDTH 80
HEIGHT 23
CAPTION "Close"
ACTION MainForm.RELEASE
END BUTTON
HMG_ChangeWindowStyle(MainForm.Label1.HANDLE, 0x00800200 /*WS_BORDER|SS_CENTERIMAGE*/, NIL, .F., .T.)
EventCreate("LabelEventHandler", MainForm.Label1.HANDLE)
MainForm.CENTER
MainForm.ACTIVATE
FUNCTION LabelEventHandler()
STATIC lTracking := .F.
LOCAL nHWnd := EventHWND()
LOCAL nMsg := EventMSG()
SWITCH nMsg
CASE WM_MOUSEMOVE
IF ! lTracking
MainForm.Label1.FONTCOLOR := {255, 0, 0}
MainForm.Label1.FONTBOLD := .T.
lTracking := TrackMouseEvent(nHWnd, 0x00000002 /*TME_LEAVE*/)
EXIT
CASE WM_MOUSELEAVE
MainForm.Label1.FONTCOLOR := {0, 0, 0}
MainForm.Label1.FONTBOLD := .F.
lTracking := .F.
EXIT
ENDSWITCH
#pragma BEGINDUMP
#include <windows.h>
#include "hbapi.h"
#include "HMG_UNICODE.h"
HB_FUNC( TRACKMOUSEEVENT )
TRACKMOUSEEVENT tmi;
tmi.cbSize = sizeof(TRACKMOUSEEVENT);
tmi.dwFlags = hb_parni(2);
tmi.hwndTrack = (HWND) HMG_parnl(1);
tmi.dwHoverTime = HOVER_DEFAULT;
hb_retl(TrackMouseEvent(&tmi));
#pragma ENDDUMP
Re: mouseover label
Posted: Sat Jun 09, 2018 8:52 pm
KDJ wrote: ↑Sat Jun 09, 2018 8:09 pm
Thanks, good question
- MOUSELEAVE.JPG (16.95 KiB) Viewed 6587 times
Re: mouseover label
Posted: Sun Jun 10, 2018 7:33 am
by gfilatov
Add
SS_NOTIFY style to your Label definition
Hope that helps.
Re: mouseover label
Posted: Sun Jun 10, 2018 12:19 pm
by KDJ
Grigory
MSDN wrote:
SS_NOTIFY
Sends the parent window STN_CLICKED, STN_DBLCLK, STN_DISABLE, and STN_ENABLE notification codes when the user clicks or double-clicks the control.
So applying SS_NOTIFY style should not affect the WM_MOUSELEAVE message generation.
In addition, this LABEL already has SS_NOTIFY style:
0x50800301 == WS_CHILD | WS_VISIBLE | WS_BORDER | SS_CENTERIMAGE | SS_NOTIFY | SS_CENTER
There must be some other reason that WM_MOUSELEAVE is not received.
Re: mouseover label
Posted: Sun Jun 10, 2018 3:42 pm
by gfilatov
KDJ wrote: ↑Sun Jun 10, 2018 12:19 pm
You are right!
Please take a look for an updated sample below:
FUNCTION Main()
WIDTH 300;
HEIGHT 200;
MAIN ;
ON MOUSEMOVE (MainForm.Label1.FONTCOLOR := {0, 0, 0}, MainForm.Label1.FONTBOLD := .F., lTracking := .F.)
DEFINE LABEL Label1
ROW 10
COL 10
WIDTH 140
HEIGHT 45
ALIGNMENT Center
END LABEL
ROW 70
COL 10
WIDTH 80
HEIGHT 23
CAPTION "Close"
END BUTTON
MainForm.CENTER
MainForm.ACTIVATE
SWITCH nMsg
CASE WM_MOUSEMOVE
IF ! lTracking
EXIT
CASE WM_MOUSELEAVE
lTracking := .F.
EXIT
ENDSWITCH
#pragma BEGINDUMP
#include "hbapi.h"
#pragma ENDDUMP
Just idea.
Re: mouseover label
Posted: Sun Jun 10, 2018 4:11 pm
gfilatov wrote: ↑Sun Jun 10, 2018 3:42 pm
OK
Thanks Grigory and KDJ
Happy HMG'ing
Re: mouseover label
Posted: Sun Jun 10, 2018 4:36 pm
by KDJ
Grigory
Yes, thank you for the idea.
This can also be done by processing WM_SETCURSOR message in main window event handler (example is here:
viewtopic.php?f=9&t=4806&hilit=mouse+andyglez ).
But WM_MOUSELEAVE is still not received.
Why WM_MOUSELEAVE in HMG Extended works and in classic HMG doesn't work?
