build error : c:\hmg.3.4.4\SAMPLES\HFCL\SQL\HMGSQLite
hmgchang
Post by hmgchang »
Dear Friends,
built and error on build error : c:\hmg.3.4.4\SAMPLES\HFCL\SQL\HMGSQLite
the build.log :
hbmk2: Triggered by #require directive: hmgsqlite.hbc
hbmk2[demo]: Warning: Cannot find hmgsqlite.hbc
hbmk2: Linking... demo.exe
.hbmk/win/mingw/demo.o:demo.c:(.data+0xa8): undefined reference to `HB_FUN_CONNECT2DB'
.hbmk/win/mingw/demo.o:demo.c:(.data+0x168): undefined reference to `HB_FUN_SQL'
.hbmk/win/mingw/demo.o:demo.c:(.data+0x178): undefined reference to `HB_FUN_C2SQL'
.hbmk/win/mingw/demo.o:demo.c:(.data+0x218): undefined reference to `HB_FUN_MISCSQL'
hbmk2[demo]: Error: Running linker. 1
gcc.exe .hbmk/win/mingw/demo.o .hbmk/win/mingw/_hbmkaut_demo.o c:/hmg.3.4.4/SAMPLES/HFCL/SQL/HMGSQLite/_temp.o    -pthread  -static-libgcc  -static-libstdc++  -static -lpthread -mwindows -Wl,--start-group -lhmg -lcrypt -ledit -leditex -lgraph -lini -lreport -lhfcl -lmsvfw32 -lvfw32 -lhbmysql -lmysql -lhbfimage -lhbpgsql -lsddmy -lhbvpdf -lhbct -lhbwin -lhbmzip -lminizip -lhbmemio -lhbmisc -lhbtip -lsqlite3 -lhbsqlit3 -lsddodbc -lrddsql -lhbodbc -lodbc32 -lhbhpdf -lhbnetio -lxhb -lpng -llibhpdf -lhbzebra -lhbextern -lhbdebug -lhbvmmt -lhbrtl -lhblang -lhbcpage -lgtcgi -lgtpca -lgtstd -lgtwin -lgtwvt -lgtgui -lhbrdd -lhbuddall -lhbusrrdd -lrddntx -lrddcdx -lrddnsx -lrddfpt -lhbrdd -lhbhsx -lhbsix -lhbmacro -lhbcplr -lhbpp -lhbcommon -lhbmainwin -lkernel32 -luser32 -lgdi32 -ladvapi32 -lws2_32 -liphlpapi -lwinspool -lcomctl32 -lcomdlg32 -lshell32 -luuid -lole32 -loleaut32 -lmpr -lwinmm -lmapi32 -limm32 -lmsimg32 -lwininet -lhbpcre -lhbzlib   -Wl,--end-group -odemo.exe  -LC:/hmg.3.4.4/harbour/lib/win/mingw -LC:/hmg.3.4.4/lib
hbmk2: Error: Referenced, missing, but unknown function(s): CONNECT2DB(),
       SQL(), C2SQL(), MISCSQL()
TIA
best rgds,
Chang
Just Hmg It !
jayadevu
Re: build error : c:\hmg.3.4.4\SAMPLES\HFCL\SQL\HMGSQLite
Post by jayadevu »
Hi Chang,
These functions are in hmgsqlite.prg found in c:\hmg.3.4.4\SOURCE\HMGSQL
Warm regards,
Jayadev
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
You need hmgsql library
Look at c:\hmg.3.4.4\SOURCE\HMGSQL and create library what you need
hmgchang
Post by hmgchang »
Thanks Dragancesu,
Maybe this is not an original sample from HMG,
if I am not mistake its from the HMGforum...
Anyway every code is a good teacher for me...
best rgds,
Chang
Just Hmg It !
dragancesu
Sample is OK, but you must do
1. on folder c:\hmg.3.4.4\SOURCE\HMGSQL run buildlib.bat
then you can see new library in c:\hmg.3.4.4\lib
2. then c:\hmg.3.4.4\hmg32.hbc add line libs=hmgsqlite
3. then compile demo c:\hmg.3.4.4\SAMPLES\HFCL\SQL\HMGSQLite
it's work
p.s. this library is not default, this is Rathi's work, search forum for it
Hi friend Chang
Look at this Sqlite sample I published
viewtopic.php?f=9&t=4795&p=45549&hilit= ... ite#p45549
Sample New ---> Sqlite_Sample_New.zip
SALINETAS24
Post by SALINETAS24 »
Muy buena la aplicación Musfata y la he compilado y a la primera. Por el contrario el SAMPLES\HFCL\SQL\HMGSQLITE no he podido todavia.
Agradecido y lo dicho.. me pongo a ver eso del SQL.. vamos con una cervecita..!!
jairpinho
Post by jairpinho »
use C:\hmg.3.4.4\SAMPLES\HFCL\SQL\SQLITE works perfect
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho
Post by jairpinho »
hmgchang wrote: Tue Jun 05, 2018 9:10 pm Dear Friends,
the build.log :
TIA
best rgds,
Chang
follows a new review as an example in IDE
HMGSQLite_Rev2.zip
(1.95 MiB) Downloaded 291 times
Jair Pinho
