Error on c:\hmg.3.4.4\samples\controls\systemTray\notes
hmgchang
Post by hmgchang »
Dear Friends,
Tried to compile c:\hmg.3.4.4\samples\controls\systemTray\notes,
i got this error :
notes.prg(121) Error E0030 Syntax error "syntax error at 'CFORM'"
the code on notes.prg(121) is :
DEFINE WINDOW &cForm ;
		AT nRow, nCol ;
		WIDTH 200 HEIGHT 180 ;
		TITLE DtoC(Date()) + " " + Time() ;
		ICON "TRAY" ;
		CHILD ;
		TOPMOST ;
		NOMINIMIZE NOMAXIMIZE NOSIZE ;
		ON INIT InitNotes(cForm) ;
		ON RELEASE CloseNotes(cForm, nForm) ;
		ON MOUSECLICK EditNotes(cForm) ;
		BACKCOLOR aColors[nColor] ;
		FONT 'MS Sans Serif' SIZE 10
i remember it use to work....
pls advise
TIA
best rgds,
Chang
Just Hmg It !
Re: Error on c:\hmg.3.4.4\samples\controls\systemTray\notes
hmgchang wrote: Fri Jun 01, 2018 12:09 am Dear Friends,
i got this error :
pls advise
TIA
best rgds,
Chang
Hello Chang,
Thanks for your bugreport :!:
Please be so kind to try the updated code below :arrow:
 * http://www.hmgforum.com//
#include "common.ch"
#define CRLF HB_OsNewLine()
#define PROGRAM 'Notes'
#define COPYRIGHT ' by Grigory Filatov, 2002'
#define MAXSHEETS 100
#define NTRIM( n ) LTrim( Str( n ) )
Static nWindows := 0, aWindows := {}, nRow := -22, nCol := -24, nColors := 0, ;
	aColors := { { 255 , 255 , 0 }, { 255 , 128 , 192 }, { 255 , 0 , 0 }, ;
		{ 255 , 0 , 255 }, { 255 , 128 , 64 }, { 0 , 255 , 0 }, { 128 , 0 , 128 }, ;
		{ 255 , 255 , 255 }, { 128 , 128 , 128}, { 0 , 0 , 255 }, { 192 , 192 , 192 } }, ;
	aNotes := { {"ID","N",4,0}, {"DATE","D",8,0}, {"TIME","C",8,0}, ;
			{"ROW","N",4,0}, {"COL","N",4,0}, {"COLOR","N",2,0}, ;
			{"TEXT1","C",24,0}, {"TEXT2","C",24,0}, {"TEXT3","C",24,0}, {"TEXT4","C",24,0} }
Function Main( cPack )
	Local lPack := .f.
	Private lExit := .f., lSound := .t., lHidden := .f., nSheets := 0
	Set Date German
	Set Delete On
   MsgInfo( "This program is based on a notify menu, Look at system tray to use..."  )
	DEFAULT cPack TO ""
	lPack := ( Empty(cPack) .OR. Upper( SubStr(cPack, 2) ) # "NOPACK" )
	DEFINE WINDOW Form_0 ;
		WIDTH 0 HEIGHT 0 ;
		TITLE PROGRAM ;
		MAIN NOSHOW ;
		ON INIT OpenNotes(lPack) ;
		ON RELEASE {|| HideNotes(), lExit := .t., dbCloseAll(), Ferase( "Notes"+INDEXEXT() )} ;
		NOTIFYICON 'TRAY' ;
		NOTIFYTOOLTIP PROGRAM + ": Left click for a new sheet" ;
		ON NOTIFYCLICK NewNotes()
		DEFINE NOTIFY MENU
			ITEM 'S&top All Sounds'  ACTION (lSound := !lSound, ;
							( Form_0.Sound.Checked := !lSound)) NAME Sound
			SEPARATOR
			ITEM '&Show All Notes'	  ACTION ShowNotes()
			ITEM '&Hide All Notes'	  ACTION HideNotes()
			SEPARATOR
			ITEM '&Mail to author...' ACTION ShellExecute(0, "open", "rundll32.exe", ;
							"url.dll,FileProtocolHandler " + ;
							"mailto:gfilatov@rambler.ru?cc=&bcc=" + ;
							"&subject=Notes%20Utility" + ;
							"&body=How%20are%20you%2C%20Grigory%3F", , 1)
			ITEM 'A&bout...'		ACTION ShellAbout( "", PROGRAM + ' version 1.4' + ;
					CRLF + Chr(169) + COPYRIGHT, LoadTrayIcon(GetInstance(), "MAIN") )
			SEPARATOR
			ITEM 'E&xit'		  ACTION Form_0.Release
		END MENU
		DEFINE TIMER Timer_1 ;
			INTERVAL 1000 ;
			ACTION CheckTopLeftCorner()
	ACTIVATE WINDOW Form_0
Function NewNotes()
	Local cForm, nForm, nColor
	nWindows++
	nForm := nWindows
	cForm := 'Form_' + NTRIM(nForm)
	nSheets++
	IF nSheets > MAXSHEETS
		MsgStop( "Quantity of Sheets is Very Big!", "Stop!" )
	Form_0.NotifyTooltip := PROGRAM + ": " + NTRIM(nSheets) + " sheet(s)"
	nColors++
	IF nColors > 11
		nColors := 1
	nColor := nColors
	nRow := nRow + 22
	nCol := nCol + 24
	IF nRow > GetDesktopHeight() - 200
		nRow := 0
		nCol := 200
		AT nRow, nCol ;
		ICON "TRAY" ;
		CHILD ;
		TOPMOST ;
		@ 6,12 LABEL Label_1 VALUE "" WIDTH 168 HEIGHT 22 ;
			ACTION EditNotes(cForm) ;
		@ 6,10 TEXTBOX Text_1 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
			ON ENTER DoMethod ( cForm , 'Text_2' , 'SetFocus' )
		@ 36,12 LABEL Label_2 VALUE "" WIDTH 168 HEIGHT 22 ;
		@ 36,10 TEXTBOX Text_2 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
			ON ENTER DoMethod ( cForm , 'Text_3' , 'SetFocus' )
		@ 66,12 LABEL Label_3 VALUE "" WIDTH 168 HEIGHT 22 ;
		@ 66,10 TEXTBOX Text_3 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
			ON ENTER DoMethod ( cForm , 'Text_4' , 'SetFocus' )
		@ 96,12 LABEL Label_4 VALUE "" WIDTH 168 HEIGHT 22 ;
		@ 96,10 TEXTBOX Text_4 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
			ON ENTER DoMethod ( cForm , 'Button_1' , 'SetFocus' )
		@ 125,35 LABEL Label_5 VALUE "Mouse Click for Editing" WIDTH 120 HEIGHT 22 ;
			FONT "MS Sans Serif" SIZE 9 ;
		@ 126,60 BUTTON Button_1 CAPTION "OK" ACTION ExitEdit(cForm, nForm, nColor) WIDTH 70 HEIGHT 22 ;
		DEFINE CONTEXT MENU
			ITEM '&Hide a sheet' ACTION DoMethod (cForm,'Hide')
			SEPARATOR
			ITEM '&Stick a sheet' ACTION CompactNotes(cForm, nForm, nColor)
		END MENU
	SetProperty ( cForm , 'Text_1' , 'Visible' , .f. )
	SetProperty ( cForm , 'Text_2' , 'Visible' , .f. )
	SetProperty ( cForm , 'Text_3' , 'Visible' , .f. )
	SetProperty ( cForm , 'Text_4' , 'Visible' , .f. )
	SetProperty ( cForm , 'Button_1' , 'Visible' , .f. )
	ACTIVATE WINDOW &cForm
Procedure InitNotes(cForm)
	IF lSound
		IF FILE("Open.wav")
			PLAY WAVE "Open.wav"
			PlayOk()
	AADD( aWindows, cForm )
Procedure CloseNotes(cForm, nId)
	Local nForm := ASCAN( aWindows, cForm )
	IF lSound
		IF FILE("Open.wav")
			PLAY WAVE "Close.wav"
			PlayBeep()
	IF !lExit
		ADEL( aWindows, nForm )
		ASIZE( aWindows, Len(aWindows) - 1 )
		nSheets--
		Form_0.NotifyTooltip := PROGRAM + ": " + ;
			IF( Empty(nSheets), "Emptily", NTRIM(nSheets) + " sheet(s)" )
		Seek nId
		IF FOUND()
			IF Rlock()
				DELETE
				UnLock
Procedure EditNotes(cForm)
	SetProperty ( cForm ,'Label_5' , 'Visible' , .f. )
	SetProperty ( cForm ,'Text_1' , 'Visible' , .t. )
	SetProperty ( cForm ,'Text_2' , 'Visible' , .t. )
	SetProperty ( cForm ,'Text_3' , 'Visible' , .t. )
	SetProperty ( cForm ,'Text_4' , 'Visible' , .t. )
	SetProperty ( cForm ,'Button_1' , 'Visible' , .t. )
	DoMethod ( cForm , 'Text_1' , 'SetFocus' )
	IF lSound
		PlayBeep()
Procedure ExitEdit(cForm, nId, nColor)
	Local h := GetFormHandle( cForm )
	Local SaveRow := GetWindowRow( h ), ;
		SaveCol := GetWindowCol( h )
	Local cText1 := GetProperty ( cForm , 'Text_1' , 'Value' ), ;
		cText2 := GetProperty( cForm , 'Text_2' , 'Value' ), ;
		cText3 := GetProperty( cForm , 'Text_3' , 'Value' ), ;
		cText4 := GetProperty( cForm , 'Text_4' , 'Value' ), ;
		cTime := Time()
	Seek nId
	IF !FOUND()
		DBappend()
		IF Rlock()
			Replace ID WITH nId
			UnLock
	IF Rlock()
		Replace DATE WITH Date(), TIME WITH cTime, ;
			ROW WITH SaveRow, COL WITH SaveCol, ;
			COLOR WITH nColor, ;
			TEXT1 WITH cText1, TEXT2 WITH cText2, ;
			TEXT3 WITH cText3, TEXT4 WITH cText4
		Commit
		UnLock
	SetProperty ( cForm , 'Label_1','Value' , cText1 )
	SetProperty ( cForm , 'Label_2','Value' , cText2 )
	SetProperty ( cForm , 'Label_3','Value' , cText3 )
	SetProperty ( cForm , 'Label_4','Value' , cText4 )
	SetProperty ( cForm , 'Text_1','Visible' , .f.   )
	SetProperty ( cForm , 'Text_2','Visible' , .f.   )
	SetProperty ( cForm , 'Text_3','Visible' , .f.   )
	SetProperty ( cForm , 'Text_4','Visible' , .f.   )
	SetProperty ( cForm , 'Button_1','Visible' , .f. )
	SetProperty ( cForm , 'Label_5','Value' , PadC( "Last Update: " + cTime, 25 ) )
	SetProperty ( cForm , 'Label_5','Visible' , .t. )
	IF lSound
		PlayBeep()
Procedure SaveRowCol(cForm, nId)
	Seek nId
	IF FOUND()
		IF Rlock()
			Replace ROW WITH SaveRow, COL WITH SaveCol
			UnLock
Procedure HideNotes()
	Local i, nForm := Len(aWindows), cForm
	if nForm > 0
		lHidden := .t.
		For i := nForm To 1 Step -1
			cForm := aWindows[i]
			If IsWIndowDefined(&cForm)
				SysWait()
				SaveRowCol( cForm, Val( SubStr( cForm, At( "_", cForm ) + 1 ) ) )
				DoMethod ( cForm , 'Hide' )
			EndIF
		Next
Procedure ShowNotes()
	if nForm > 0
		lHidden := .f.
		For i := 1 To nForm
				SysWait()
				DoMethod ( cForm , 'Show' )
			EndIF
		Next
Procedure OpenNotes(lPack)
   LOCAL cDataBase := "Notes.dat"
   PRIVATE cActForm := {}
   If !File( cDataBase )
      DBcreate( cDataBase, aNotes )
   EndIF
   If lPack
	USE ( cDataBase ) NEW
	If !NetErr()
		PACK
		DBEVAL( {|| FIELD->ID := RecNo() } )
		CLOSE
	EndIF
   EndIF
   USE ( cDataBase ) ALIAS NOTES SHARED NEW
   If !NetErr()
      If !File( ( "Notes"+INDEXEXT() ) )
         INDEX ON FIELD->ID TO NOTES
      EndIF
      SET INDEX TO NOTES
   Else
      MsgStop("Data file is locked", "Please, try again")
   EndIF
   GO BOTTOM
   nWindows := FIELD->ID
   GO TOP
   DO WHILE !EOF()
	LoadNotes( FIELD->ID, FIELD->DATE, FIELD->TIME, ;
		FIELD->ROW, FIELD->COL, FIELD->COLOR, ;
		FIELD->TEXT1, FIELD->TEXT2, FIELD->TEXT3, FIELD->TEXT4 )
	SKIP
   ENDDO
   IF LEN( cActForm ) > 0
	_ActivateWindow( cActForm )
Procedure LoadNotes(nId, dDate, cTime, SaveRow, SaveCol, nColor, cText1, cText2, cText3, cText4)
	Local cForm := 'Form_' + NTRIM(nId)
	nSheets++
		AT SaveRow, SaveCol ;
		TITLE DtoC(dDate) + " " + cTime ;
		ICON "TRAY" ;
		CHILD ;
		TOPMOST ;
		ON RELEASE CloseNotes(cForm, nId) ;
		@ 6,12 LABEL Label_1 VALUE cText1 WIDTH 168 HEIGHT 22 ;
		@ 6,10 TEXTBOX Text_1 VALUE cText1 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
		@ 36,12 LABEL Label_2 VALUE cText2 WIDTH 168 HEIGHT 22 ;
		@ 36,10 TEXTBOX Text_2 VALUE cText2 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
		@ 66,12 LABEL Label_3 VALUE cText3 WIDTH 168 HEIGHT 22 ;
		@ 66,10 TEXTBOX Text_3 VALUE cText3 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
		@ 96,12 LABEL Label_4 VALUE cText4 WIDTH 168 HEIGHT 22 ;
		@ 96,10 TEXTBOX Text_4 VALUE cText4 HEIGHT 22 WIDTH 172 MAXLENGTH 24 ;
		@ 126,60 BUTTON Button_1 CAPTION "OK" ACTION ExitEdit(cForm, nId, nColor) WIDTH 70 HEIGHT 22 ;
		DEFINE CONTEXT MENU
			SEPARATOR
			ITEM '&Stick a sheet' ACTION CompactNotes(cForm, nId, nColor)
		END MENU
	AADD( cActForm, cForm )
Procedure CompactNotes(cForm, nForm, nColor)
   Local h := GetFormHandle( cForm ), dDate, cTime
   Local cText1 := GetProperty ( cForm , 'Text_1', 'Value' ), ;
	   cText2 := GetProperty ( cForm , 'Text_2', 'Value' ), ;
	   cText3 := GetProperty ( cForm , 'Text_3', 'Value' ), ;
	   cText4 := GetProperty ( cForm , 'Text_4', 'Value' )
   Seek nForm
   IF FOUND()
	dDate := FIELD->DATE
	cTime := FIELD->TIME
	lExit := .t.
	DoMethod ( cForm , 'Release' )
	Doevents()
		AT SaveRow+22, SaveCol ;
		WIDTH 196 HEIGHT 106 ;
		CHILD ;
		TOPMOST NOCAPTION ;
		ON INIT (lExit := .f.) ;
		ON MOUSECLICK ( DoMethod( cForm ,'Release'), Doevents(), ADEL( aWindows, nForm ), ;
			ASIZE( aWindows, Len(aWindows) - 1 ), nSheets--, ;
			LoadNotes( nForm, dDate, cTime, SaveRow, SaveCol, nColor, ;
			cText1, cText2, cText3, cText4 ), _ActivateWindow( {cForm} ) ) ;
			ACTION ( DoMethod( cForm,'Release' ), Doevents(), ADEL( aWindows, nForm ), ;
		@ 30,12 LABEL Label_2 VALUE cText2 WIDTH 168 HEIGHT 22 ;
			ACTION ( DoMethod( cForm ,'Release'), Doevents(), ADEL( aWindows, nForm ), ;
		@ 54,12 LABEL Label_3 VALUE cText3 WIDTH 168 HEIGHT 22 ;
		@ 78,12 LABEL Label_4 VALUE cText4 WIDTH 168 HEIGHT 22 ;
	MsgStop( "Empty notes!", "Stop!" )
Function CheckTopLeftCorner()
   Local aPos := GetCursorPos()
   IF aPos[1] = 0 .AND. aPos[2] = 0
	IF lHidden
		ShowNotes()
		HideNotes()
Return NIL
Procedure SysWait(nWait)
Local iTime := Seconds()
	DEFAULT nWait TO .1
	Do While Seconds() - iTime < nWait
		DO EVENTS
	EndDo
In hope that helps.
hmgchang
Post by hmgchang »
Thanks Mr. Filatov,
I updated the notes.prg and built,
unsuccessful with this build.log
hbmk2: Compiling Harbour sources...
Harbour 3.2.0dev (r1703241902)
notes.prg(28) Warning W0002  Ambiguous reference, assuming memvar 'NSHEETS'
notes.prg(28) Warning W0002  Ambiguous reference, assuming memvar 'LHIDDEN'
notes.prg(28) Warning W0002  Ambiguous reference, assuming memvar 'LSOUND'
notes.prg(28) Warning W0002  Ambiguous reference, assuming memvar 'LEXIT'
notes.prg(47) Warning W0001  Ambiguous reference 'LEXIT'
notes.prg(51) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(73) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(88) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(89) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(94) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(172) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(189) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(197) Warning W0001  Ambiguous reference 'LEXIT'
notes.prg(201) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(203) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(230) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(280) Warning W0001  Ambiguous reference 'LSOUND'
notes.prg(309) Warning W0001  Ambiguous reference 'LHIDDEN'
notes.prg(328) Warning W0001  Ambiguous reference 'LHIDDEN'
notes.prg(344) Warning W0002  Ambiguous reference, assuming memvar 'CACTFORM'
notes.prg(382) Warning W0001  Ambiguous reference 'CACTFORM'
notes.prg(383) Warning W0001  Ambiguous reference 'CACTFORM'
notes.prg(393) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(394) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(399) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(413) Error E0030  Syntax error "syntax error at 'CFORM'"
notes.prg(457) Warning W0001  Ambiguous reference 'CACTFORM'
notes.prg(471) Warning W0002  Ambiguous reference, assuming memvar 'CACTFORM'
notes.prg(478) Warning W0001  Ambiguous reference 'LEXIT'
notes.prg(494) Error E0030  Syntax error "syntax error at 'CFORM'"
notes.prg(494) Warning W0001  Ambiguous reference 'LEXIT'
notes.prg(494) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(501) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(507) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(513) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(519) Warning W0001  Ambiguous reference 'NSHEETS'
notes.prg(536) Warning W0001  Ambiguous reference 'LHIDDEN'
3 errors
No code generated.
hbmk2[notes]: Error: Running Harbour compiler (embedded). 1
(C:\hmg.3.4.4\harbour\bin\harbour.exe) -n2 notes.prg -w1 -DHBMK_HAS_HMG32=1 -q -o.hbmk\win\mingw\ -iC:\hmg.3.4.4\harbour\include -i. -iC:\hmg.3.4.4\include
this is the error lines,
I think its about using macro at DEFINE WINDOW &cForm.
I remember it used to work with previous version of HMG.
Just Hmg It !
hmgchang
Post by hmgchang »
Good Morning Friends,
I still stuck in this :
Anyone pls advise on how to name a window by variable
TIA
best rgds,
Chang
Just Hmg It !
