Adding Context-menu to Splitbox
hmgchang
Post by hmgchang »
Dear HmgLovers,
Adding control context menu to c:\hmg.3.4.4\samples\controls\splitbox\splitbox_1.prg,
does not work as expected. am I missed something ?
 * http://www.hmgforum.com//
	DEFINE WINDOW Form_1 ;
		WIDTH 800 HEIGHT 600 ;
		TITLE 'HMG SplitBox Demo' ;
		MAIN ;
		FONT 'Arial' SIZE 10
		DEFINE STATUSBAR
			STATUSITEM 'HMG Power Ready - Click / Drag Grippers And Enjoy !'
		END STATUSBAR
		DEFINE MAIN MENU
			POPUP '&File'
				ITEM '&Disable ToolBar Button'		ACTION Form_1.SplitBox.ToolBar_1.Button_1.Enabled := .F.
				ITEM '&Enable ToolBar Button'		ACTION Form_1.SplitBox.ToolBar_1.Button_1.Enabled := .T.
				ITEM 'Get ToolBar Button Caption'	ACTION MsgInfo ( Form_1.SplitBox.ToolBar_1.Button_1.Caption )
				SEPARATOR
				ITEM 'Get EditBox Value'	ACTION MsgInfo ( Form_1.SplitBox.Edit_1.Value )
				ITEM 'Get Grid Value'		ACTION MsgInfo ( Str ( Form_1.SplitBox.Grid_1.Value ) )
				ITEM 'Get List Value'		ACTION MsgInfo ( Str ( Form_1.SplitBox.List_1.Value ) )
				SEPARATOR
				ITEM 'Set EditBox Value'	ACTION Form_1.SplitBox.Edit_1.Value := 'New Value'
				ITEM 'Set Grid Value'	ACTION Form_1.SplitBox.Grid_1.Value := 2
				ITEM 'Set List Value'	ACTION Form_1.SplitBox.List_1.Value := 5
				SEPARATOR
				ITEM 'Disable EditBox'	ACTION Form_1.SplitBox.Edit_1.Enabled := .f.
				ITEM 'Disable Grid'	ACTION Form_1.SplitBox.Grid_1.Enabled := .f.
				ITEM 'Disable List'	ACTION Form_1.SplitBox.List_1.Enabled := .f.
				SEPARATOR
				ITEM 'Enable EditBox'	ACTION Form_1.SplitBox.Edit_1.Enabled := .t.
				ITEM 'Enable Grid'	ACTION Form_1.SplitBox.Grid_1.Enabled := .t.
				ITEM 'Enable List'	ACTION Form_1.SplitBox.List_1.Enabled := .t.
				SEPARATOR
				ITEM 'Hide EditBox'	ACTION Form_1.SplitBox.Edit_1.Hide()
				ITEM 'Show EditBox'	ACTION Form_1.SplitBox.Edit_1.Show()
				SEPARATOR
				ITEM 'Exit'		ACTION Form_1.Release
			END POPUP
			POPUP '&Help'
				ITEM 'About'		ACTION MsgInfo ("HMG SplitBox Demo","A COOL Feature ;)")
			END POPUP
		END MENU
		DEFINE SPLITBOX
			DEFINE TOOLBAR ToolBar_1 BUTTONSIZE 85,85 FLAT
				BUTTON Button_1 CAPTION '&More ToolBars...' PICTURE 'button1.bmp' ACTION MsgInfo('Click! 1')  TOOLTIP 'ONE'
				BUTTON Button_2 CAPTION '&Button 2' PICTURE 'button2.bmp' ACTION MsgInfo('Click! 2')  TOOLTIP 'TWO'
				BUTTON Button_3 CAPTION 'Button &3' PICTURE 'button3.bmp' ACTION MsgInfo('Click! 3')  TOOLTIP 'THREE'
			END TOOLBAR
			LISTBOX List_1 ;
				WIDTH 200 ;
				HEIGHT 400 ;
				ITEMS {'Item 1','Item 2','Item 3','Item 4','Item 5'} ;
				VALUE 3  ;
				TOOLTIP 'ListBox 1'
			GRID Grid_1 ;
				WIDTH 200 ;
				HEIGHT 400 ;
				HEADERS {'Last Name','First Name'} ;
				WIDTHS {100,100};
				ITEMS { {'Simpson','Homer'} , {'Mulder','Fox'} } VALUE 1 ;
				TOOLTIP 'Grid Control'
			EDITBOX Edit_1 ;
				WIDTH 200 ;
				HEIGHT 400 ;
				VALUE 'EditBox!!' ;
				TOOLTIP 'EditBox' ;
				MAXLENGTH 255
  END SPLITBOX
  [b][color=blue]
  Define_Control_Context_Menu ("ToolBar_1")
  Define_Control_Context_Menu ("List_1")
  Define_Control_Context_Menu ("Grid_1")
  Define_Control_Context_Menu ("Edit_1")
 [/color][/b]
	CENTER WINDOW Form_1
	ACTIVATE WINDOW Form_1
[b][color=blue]
PROCEDURE Define_Control_Context_Menu (cComponent)
Do Case
   Case cComponent="Label_1"
        DEFINE CONTROL CONTEXTMENU &cComponent OF Form_1
            ITEM "Label 1" ACTION MsgInfo("Label 1")
            ITEM "Label 2" ACTION MsgInfo("Label 2")
            ITEM "Label 3" ACTION MsgInfo("Label 3")
        END MENU
   Case cComponent="Button_1"
            ITEM "Button 1" ACTION MsgInfo("Button 1")
            ITEM "Button 2" ACTION MsgInfo("Button 2")
            ITEM "Button 3" ACTION MsgInfo("Button 3")
        END MENU
   Case cComponent="Button_2"
            ITEM "Button 4" ACTION MsgInfo("Button 4")
            ITEM "Button 5" ACTION MsgInfo("Button 5")
            ITEM "Button 6" ACTION MsgInfo("Button 6")
        END MENU
   Case cComponent="Check_1"
            ITEM "Check 1" ACTION MsgInfo("Check 1")
            ITEM "Check 2" ACTION MsgInfo("Check 2")
            ITEM "Check 3" ACTION MsgInfo("Check 3")
        END MENU
   Case cComponent="List_1"
            ITEM "List 1" ACTION MsgInfo("List 1")
            ITEM "List 2" ACTION MsgInfo("List 2")
            ITEM "List 3" ACTION MsgInfo("List 3")
        END MENU
   Case cComponent="Combo_1"
            ITEM "Combo 1" ACTION MsgInfo("Combo 1")
            ITEM "Combo 2" ACTION MsgInfo("Combo 2")
            ITEM "Combo 3" ACTION MsgInfo("Combo 3")
        END MENU
   Case cComponent="CheckBtn_1"
            ITEM "CheckBtn 1" ACTION MsgInfo("CheckBtn 1")
            ITEM "CheckBtn 2" ACTION MsgInfo("CheckBtn 2")
            ITEM "CheckBtn 3" ACTION MsgInfo("CheckBtn 3")
        END MENU
   Case cComponent="Grid_1"
            ITEM "Grid 1" ACTION MsgInfo("Grid 1")
            ITEM "Grid 2" ACTION MsgInfo("Grid 2")
            ITEM "Grid 3" ACTION MsgInfo("Grid 3")
        END MENU
   Case cComponent="Slider_1"
            ITEM "Slider 1" ACTION MsgInfo("Slider 1")
            ITEM "Slider 2" ACTION MsgInfo("Slider 2")
            ITEM "Slider 3" ACTION MsgInfo("Slider 3")
        END MENU
   Case cComponent="Image_1"
            ITEM "Image 1" ACTION MsgInfo("Image 1")
            ITEM "Image 2" ACTION MsgInfo("Image 2")
            ITEM "Image 3" ACTION MsgInfo("Image 3")
        END MENU
   Case cComponent="RadioGroup_1"
            ITEM "RadioGroup 1" ACTION MsgInfo("RadioGroup 1")
            ITEM "RadioGroup 2" ACTION MsgInfo("RadioGroup 2")
            ITEM "RadioGroup 3" ACTION MsgInfo("RadioGroup 3")
        END MENU
   Case cComponent="Tab_1"
            ITEM "Tab 1" ACTION MsgInfo("Tab 1")
            ITEM "Tab 2" ACTION MsgInfo("Tab 2")
            ITEM "Tab 3" ACTION MsgInfo("Tab 3")
        END MENU
   Case cComponent="ProgressBar_1"
            ITEM "ProgressBar 1" ACTION MsgInfo("ProgressBar 1")
            ITEM "ProgressBar 2" ACTION MsgInfo("ProgressBar 2")
            ITEM "ProgressBar 3" ACTION MsgInfo("ProgressBar 3")
        END MENU
   Case cComponent="ToolBar_1"
            ITEM "ToolBar 1" ACTION MsgInfo("ToolBar 1")
            ITEM "ToolBar 2" ACTION MsgInfo("ToolBar 2")
            ITEM "ToolBar 3" ACTION MsgInfo("ToolBar 3")
        END MENU
   Case cComponent="StatusBar"
            ITEM "StatusBar 1" ACTION MsgInfo("StatusBar 1")
            ITEM "StatusBar 2" ACTION MsgInfo("StatusBar 2")
            ITEM "StatusBar 3" ACTION MsgInfo("StatusBar 3")
        END MENU
   Case cComponent="Spinner_1"
            ITEM "Spinner 1" ACTION MsgInfo("Spinner 1")
            ITEM "Spinner 2" ACTION MsgInfo("Spinner 2")
            ITEM "Spinner 3" ACTION MsgInfo("Spinner 3")
        END MENU
Endcase
[/color][/b]
Pls advise
TIA
best rgds,
Chang
Just Hmg It !
hmgchang
Re: Adding Context-menu to Splitbox
Post by hmgchang »
btw... what happen to my BBcode ?
I want to make / show different color to the code I added...
Pls advise how....
TIA
Just Hmg It !
hmgchang wrote: Mon May 28, 2018 8:26 am Adding control context menu to c:\hmg.3.4.4\samples\controls\splitbox\splitbox_1.prg,
Hi Chang
IMHO problem is: SplitBox is a container, not a control :(
Note: If you wondering "what is container ?" frankly I don't know :?
Happy HMGing :D
As the same name says container holds its contain, hahaha
Si la idea es utilizar SPLITBOX, parece que no se puede.
Haciendolo de la forma "normal" si.
If the idea is to use SPLITBOX, it seems that you can not.
Doing it in the "normal" way, yes.
		MAIN ;
		DEFINE STATUSBAR
		END STATUSBAR
		DEFINE MAIN MENU
			POPUP '&File'
				SEPARATOR
				SEPARATOR
				SEPARATOR
				SEPARATOR
				SEPARATOR
				SEPARATOR
			END POPUP
			POPUP '&Help'
			END POPUP
		END MENU
      @ 50,20 BUTTON B1 OF Form_1 CAPTION "cCaption" ACTION NIL WIDTH 50 HEIGHT 50 TOOLTIP "cToolTipText"
      DEFINE CONTROL CONTEXT MENU B1 OF Form_1
            ITEM "Button1.1" ACTION MsgInfo("Button1.1")
            ITEM "Button1.2" ACTION MsgInfo("Button1.2")
            ITEM "Button1.3" ACTION MsgInfo("Button1.3")
      END MENU
Post by EduardoLuis »
Hi HMGCHANG:
Unfortunately it's impossible to perform a context menu on any container.-
Splitbox is a container (as master Esgici said).-
Context menues could be apply to controls.-
With regards
Eduardo
hmgchang
Post by hmgchang »
Dear Friends,
Thanks ...
Happy Vesak...
@Esgici :
1. there are Context-Menu and Control Context-Menu, but both failed on Splitbox
2. Sure Splitbox is a container. ie. try this : msgDebug( Form_1.Splitbox.List_1.Value) ---> ok
3. as a container : Form_1.handle -> ok, but Splitbox.handle -> not ok
4. as a control : Form_1.List_1.handle -> ok, but Form_1.Splitbox.handle -> not ok
5. my intention is to have a context-menu on control that happen to be in a form that have a Splitbox feature.
TIA
best rgds,
Chang
Just Hmg It !
hmgchang wrote: Mon May 28, 2018 10:42 pm Dear Friends,
Thanks ...
Happy Vesak...
@Esgici :
TIA
best rgds,
Chang
Yes, apparently Splitbox is not a window (form) nor a control; so its impossible (at last for now) to define a context menu for it :(
Who know, maybe a day ...
By the way, Ramadan mubarak to you too :D
hmgchang
Post by hmgchang »
Thank you Mr. Esgici...
I don't need context menu for Splitbox
i want to have Control Context Menu for a control
that happen to be in a form with a splitbox feature.
ps. finally... bbCode works...
TIA
best rgds,
Chang
Just Hmg It !
