SELECT PRINTER PREVIEW
edufloriv
Post by edufloriv »
Saludos amigos,
Tengo un problema con el PREVIEW del SELECT PRINTER:
1 - Se abre la vista previa en pantalla.
2 - El usuario hace click accidentalmente en la ventana que esta detrás, perdiendo el enfoque y la ventana del preview se va atras.
3 - Al desaparecer del frente, el usuario piensa que se ha cerrado y vuelve a generar el preview.
4 - Se cierra todo el sistema.
   SELECT PRINTER DEFAULT ;
      ORIENTATION PRINTER_ORIENT_PORTRAIT ;
      PAPERSIZE   PRINTER_PAPER_A4 ;
      QUALITY     PRINTER_RES_DRAFT ;
      PREVIEW
   START PRINTDOC NAME cDocNam
Se genera este errorlog.html :
Date:22/05/18 Time: 15:21:22
Error BASE/1083 Error de argumento: *
Called from _HMG_PRINTER_PREVIEW_ONPAINT(5737)
Called from (b)_HMG_PRINTER_SHOWPREVIEW(5000)
Called from _DOWINDOWEVENTPROCEDURE(6091)
Called from EVENTS(1493)
Called from DOMESSAGELOOP(0)
Called from _HMG_PRINTER_SHOWPREVIEW(5283)
Called from NOTAPRINT(1091)
Called from NOTAREPRINT(995)
Called from (b)NOTASDEINGRESO(70)
Called from EVENTS(828)
Called from NOTASDEINGRESO(313)
Called from ABREMODULO(365)
Called from EJECUTAOPCION(335)
Called from (b)MAIN(143)
Called from EVENTS(1816)
Called from MAIN(211)
Adicionalmente se genera este archivo hb_out.log :
Application Internal Error - D:\EdDocs\HMGCom\InfoFarmaC\INFOFARMA.exe
Terminated at: 2018-05-22 15:21:23
Error irrecuperable 9003: Demasiadas llamadas recursivas al controlador de errores
Called from TYPE(0)
Called from _ISCONTROLDEFINED(1143) in source\h_controlmisc.prg
Called from _HMG_PRINTER_PREVIEW_ONPAINT(5678) in source\h_controlmisc.prg
Called from (b)_HMG_PRINTER_SHOWPREVIEW(5000) in source\h_controlmisc.prg
Called from _DOWINDOWEVENTPROCEDURE(6091) in source\h_windows.prg
Called from EVENTS(1493) in source\h_windows.prg
Called from C_MSGSTOP(0)
Called from SHOWERROR(181) in source\ErrorSys.prg
Called from DEFERROR(129) in source\ErrorSys.prg
Called from (b)ERRORSYS(66) in source\ErrorSys.prg
Called from _HMG_PRINTER_PREVIEW_ONPAINT(5737) in source\h_controlmisc.prg
Called from _ACTIVATEWINDOW(5717) in source\h_windows.prg
Called from _HMG_PRINTER_SHOWPREVIEW(5283) in source\h_controlmisc.prg
Called from NOTAPRINT(1091) in INFOFARMA.prg
Called from NOTAREPRINT(995) in INFOFARMA.prg
Called from (b)NOTASDEINGRESO(70) in INFOFARMA.prg
Called from _DOCONTROLEVENTPROCEDURE(6056) in source\h_windows.prg
Called from EVENTS(828) in source\h_windows.prg
Called from NOTASDEINGRESO(313) in INFOFARMA.prg
Called from ABREMODULO(365) in INFOFARMA.prg
Called from EJECUTAOPCION(335) in INFOFARMA.prg
Called from (b)MAIN(143) in INFOFARMA.prg
Called from EVENTS(1816) in source\h_windows.prg
Called from MAIN(211) in INFOFARMA.prg
¿ Hay forma de detectar si la ventana del preview ya esta abierta ? de esa forma podria evitar que ejecuten el proceso de nuevo y mejor aún si la puedo colocar al frente.
Se que tengo esto :
IF IsWindowDefined(Win_Preview) = .T.
   MINIMIZE WINDOW Win_Preview
   RESTORE WINDOW Win_Preview
Pero no sé el nombre de la ventana del Preview.
Agradeceré su ayuda amigos.
Att.
Eduardo Flores Rivas
LIMA - PERU
edufloriv
Re: SELECT PRINTER PREVIEW
Post by edufloriv »
Amigos,
Gracias, encontré la solución:
   IF IsWindowDefined( _HMG_PRINTER_SHOWPREVIEW ) = .T.
      MINIMIZE WINDOW _HMG_PRINTER_SHOWPREVIEW  // <- Este es el nombre de la ventana del preview
      RESTORE WINDOW _HMG_PRINTER_SHOWPREVIEW
   SELE HNOTA
   SET ORDER TO TAG HNxNume
   DBSEEK( cQueNota )
      PREVIEW
Con esto logré evitar la salida del sistema, pero sería bueno reportar el bug. ¿ A quién puedo reportarlo ?
Un saludo cordial a todos.
Att.
LIMA - PERU
