Printing on 10"x6" paper
I want to print cash memo or money receipts on 10"x6" (ie., 10" width and 6" height) paper. How can I use this paper size programatically?
TIA.
Re: Printing on 10"x6" paper
Had you used "PRINTER_PAPER_USER"?
From HMG Doc.
SELECT PRINTER <cPrinter> | DEFAULT
    [ TO <lSuccessVar> ]
    [ ORIENTATION <nOrientation> ]
    [ PAPERSIZE <nPaperSize> ]
    [ PAPERLENGTH <nPaperLength> ]
    [ PAPERWIDTH <nPaperWidth> ]
    [ COPIES <nCopies> ]
    [ DEFAULTSOURCE <nDefaultSource> ]
    [ QUALITY <nQuality> ]
    [ COLOR <nColor> ]
    [ DUPLEX <nDuplex> ]
    [ COLLATE <nCollate> ]
    [ PREVIEW ]
PAPERLENGTH / PAPERWIDTH: Sets a custom paper length/width (millimeters).
To use custom paper size, you must specify PRINTER_PAPER_USER as paper size.
Hello Rathi,
Thanks a lot. I should check documentation before asking :) . Now, it works fine with following code. :D
	SELECT PRINTER mPrinter ORIENTATION PRINTER_ORIENT_PORTRAIT PREVIEW PAPERSIZE PRINTER_PAPER_USER PAPERLENGTH (6*25.4) PAPERWIDTH (10*25.4)
bels79
DBs Used: DBF, MySQL
Post by bels79 »
asked to print back and forth in the " SELECT PRINTER PREVIEW mPrinter ORIENTATION PRINTER_ORIENT_PORTRAIT PAPERSIZE PRINTER_PAPER_USER PAPERLENGTH ( 6 * 25.4 ) PAPERWIDTH ( 10 * 25.4 ) " add command ---> DUPLEX 1 ?
and how to let the print right justify
tq
