Hi everyone....
Any function to rename a directory ?
Or how to do it with hmg coding ?
Tia
Best rgds
Chang
Rename a directory
Rename a directory
Just Hmg It !
Re: Rename a directory
Hi Chang
FRename( cOldFile/folder, cNewFile/folder )
Do not end a file or directory name with a space or a period.
Although the underlying file system may support such names, the Windows shell and user interface does not.
Directory names are stored by the file system as a special type of file, but naming rules for files also apply to directory names.
Carlos
Carlos
- mustafa
Hi Chang
Carlos Britos best option
another alternative option
xange1 := "C:\Test\New_Folder1"
xange2 := "C:\Test\New_Folder2"
FRENAME( xange1 , xange2 )
RENAME &xange1 TO &xange2
Thanks Mr. Carlos and Mr. Mustafa
It works as suggested...
My problem is :
I need to rename the current directory
any suggestions
TIA
best rgds
Chang
My problem is :
FRename( "..\abc", "..\def")
any suggestions
TIA
best rgds
Chang
Just Hmg It !
Chang, if you are running the exe from current directory or any file opened in current directory, win os will not allow you to rename the current directory.
Anand
Anand
