Visual Attribute for every control
shridhar
Post by shridhar »
As many GUI softwares (e.g. Oracle Developer 2000) has provide Visual Attribute property for each control. The visual attribute property help to developer to show control to user in the same fashion in the entire application. for example a Button control having hight & width. let assume that we have created Visual attribute named VA_BUTTON having hight = 20 , width = 90 later we can use this visual attribute property to define each button.
Might be in our HMG the code will look like as per given below.
DEFINE VISUAL ATTRIBUTE VA_BUTTON
WIDTH = 40
HIGHT = 90
END VISUAL ATTRIBUTE
DEFINE BUTTON PB_EXAMPLES
VISUAL ATTRIBUTE = VA_BUTTON
END
Re: Visual Attribute for every control
Perhaps a nice idea. Thanks Shridhar.
Hello Shridhar,
shridhar wrote:As many GUI softwares (e.g. Oracle Developer 2000) has provide Visual Attribute property for each control. The visual attribute property help to developer to show control to user in the same fachion in entire application. for example a Button control having hight & width. let assue that we have created Visual attribute named VA_BUTTON having hight = 20 , width = 90 later we can use this visual attribute property to define each button.
WIDTH = 40
HIGHT = 90
END
IMHO, you are talking about CLASS INHERITANCE. Please correct me if I am wrong :)
shridhar
Post by shridhar »
Yes Sudip.. ! its near to OOP style,but I believe that HMG can adopt this style. I think Master will help us.
shridhar wrote:Yes Sudip.. ! its near to OOP style,but I believe that HMG can adopt this style. I think Master will help us.
Thanks a lot Sridhar! I also believe that. :)
IMHO, we can also implement this using array with fixed element numbers, eg., for HEIGHT, WIDTH etc. :)
