Harbour MiniGUI Extended Edition build 18.03 is published
Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 18.03.
* Fixed missed update of a dynamic color at column sorting in a GRID control.
* Added the new read/write properties 'GradientFill' and 'GradientOver'
for ButtonEx control.
* Added the minor optimizations for a speed (and stability) improvement
in the some internal functions.
* Updated and improved the internal OOP classes.
* Added the new library 'PDF Printer' (based upon the Harbour HaruPDF class).
* Updated and improved the following libraries:
HMG_HPDF (synchronized with Official HMG and recent improvements by Edward),
TSBrowse.
* Updated a download module in HMGS-IDE.
* Updated Harbour Compiler 3.2.0dev to a recent Git-version.
* Added the new interesting samples and updated some Advanced samples.
A setup of the build 18.03 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
There are also the private Minigui Ex builds for the following C-compilers
(by your request):
- MinGW 7.3.0 (32-bit) and Harbour 3.2.0dev;
- MinGW 7.3.0 (64-bit) and Harbour 3.4.0dev;
- MS Visual C++ 2017 (32-bit) and Harbour 3.2.0dev;
- Borland/Embarcadero C++ 7.3 (32-bit) and Harbour 3.2.0dev.
Thanks for your attention and support!
[MiniGUI Team]
TSBrowse.
the following URL:
(by your request):
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 18.03 is published
I hope your health has improved and I thank you very much for this version 18.03
Said, Algiers
Said, Algiers
Thanks Grigory, for the new version.
Anand
Anand
- luisvasquezcl
Thanks grigory, congratulation.
best regards,
Luis Vasquez
best regards,
Luis Vasquez
Thanks Grigory!
Nikos.
os: Windows Server 2019 - 64
Nikos.
I can't download Borland C++ 5.5.1
Links in readme.txt don't work, or go to Borland 10.1 compiler.
Where can I find this old compiler?
Excelente trabajo. ¡¡Muchas gracias!!
