Hello All....
Is it possible to de_compile exe file build with hmg to source code ?
TIA
Rgds
Chang
Decompiling hmg exe
Decompiling hmg exe
Just Hmg It !
Re: Decompiling hmg exe
Not known, but you can not do that
- dragancesu
if you succeed write how you did it
Clipper has p-code not a real compiler
The harbour works differently, the clipper program translates into c ++ and then compiles
Search "decompile c++", but the result is ASM code or using debugger
No. Clipper compiled exe can be and I have, de-compiled as they were p-code. I have got full source code from the exe.
Hmg compiled exe are more like C++ exe, which will not give hmg source code but assembler codes.
Anand
