Hi Friends,
We are pleased to announce a new build of Harbour MiniGUI Extended Edition.
Here's a breakdown of some of the modifications in the build 18.02.
- The RadioGroup control supports an optional AUTOSIZE clause.
- The Report Generator by Roberto Lopez was moved to MiniGUI core.
- The Clipper Alert() compatible function was moved to MiniGUI core.
- Added the command CHECK TYPE [ SOFT ] <var1> AS <type1> [ ,
<var2> AS <type2> [ , <varN> AS <typeN> ] ] (synchronized with Official HMG).
- The function HttpConnect was modified to use TUrl and TIpClientHttp classes.
- Updated and improved the following libraries: TSBrowse, HbNetIO, SddODBC.
- Added the HbXlsXml Harbour extras library for export a data to XML format.
- Updated Harbour Compiler 3.2.0dev to a recent Git-version.
- Added the new interesting samples and updated some Advanced samples.
A setup of the build 18.02 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
There are also the private Minigui Ex builds for the following C-compilers
(by your request):
- MinGW 7.2.0 (32-bit) and Harbour 3.2.0dev;
- MinGW 7.2.0 (64-bit) and Harbour 3.4.0dev;
- MS Visual C++ 2017 (32-bit) and Harbour 3.2.0dev;
- Borland/Embarcadero C++ 7.3 (32-bit) and Harbour 3.2.0dev.
Thanks for your attention and support!
[MiniGUI Team]
Harbour MiniGUI Extended Edition build 18.02 is published
Re: Harbour MiniGUI Extended Edition build 18.02 is published
Thank you very much, Filatov. ![Wink ;)](./images/smilies/icon_e_wink.gif)
Thanks Grgrory!!
Thanks a lot, Grigory.
Anand
Anand
Thank you, Mr. Filatov !
Thank you, Grigory!
Nikos
Nikos
Nikos.
os: Windows Server 2019 - 64
Nikos.
Dear Masters....
What is the differents betwen :
1. hmg vs hmg extended ?
2. Steps to start using hmg extended ?
Tia
Rgds
Chang
Tia
Rgds
Chang
Just Hmg It !
Visit, it may clear
http://hmgforum.com/viewtopic.php?f=14& ... ence#p5670
viewtopic.php?f=2&t=2&p=21#p21
