Help
Source code related resources
zorpavns
DBs Used: DBF, SQL
Help
Post by zorpavns »
Help
How to index positive and negative numbers. So put them in a rising order.
When the number is converted to a string, it disappears like this:
-10000.00
20000.00
-5000.00
5000.00
Does anyone have an idea of ​​how to fit properly.
Thanks in advance
Marin
Re: Help
Post by Marin »
Hi zorpavns,
Try using:
INDEX ON VAL(char_field) to File_NTX.
Marin
zorpavns
DBs Used: DBF, SQL
Re: Help
Post by zorpavns »
What to do when a combined index is composed of letters and numbers
Marin
Re: Help
Post by Marin »
zorpavns wrote: Sun Feb 18, 2018 12:58 pm What to do when a combined index is composed of letters and numbers
Please kindly give an example of your index key resulting data. Up to now we were talking about numbers only, i guess...
zorpavns
DBs Used: DBF, SQL
Re: Help
Post by zorpavns »
Example index
vrs=Ch2
Sal=Numeric 19,2
vrs+str(sal,19,2)
trmpluym
Re: Help
Post by trmpluym »
Zorpavns,
There is a simple solution for this problem. You can simply add a large number to compensate the largest possible negative number.
For example when the field has got 4 positions add 99999 (five times 9).
STR(NumField+99999)
The index would be always positive and the sort order is correct.
Theo
ROBROS
Re: Help
Post by ROBROS »
Hi Zorpavns,
"Mixed" index: persnr is a "C", character field, date is "D", date field.
My index: index on persnr+dtos(date) to indexfile.
Robert
Re: Help
Try instead of str () to use a strzero ()
BeGeS
Re: Help
Post by BeGeS »
I would create this function:
FUNCTION NEGATEX(NUMERO)
LOCAL RESUL
 IF NUMERO<0
    RESUL:= "-" + STR(ABS(NUMERO),18,2)
    RESUL:= STR(NUMERO,19,2)
RETURN RESUL
Your index:
vrs+NEGATEX(sal)
zorpavns
DBs Used: DBF, SQL
Re: Help
Post by zorpavns »
Greeting.
You should need help
How to connect to Microsoft sql server and retrieve data
Thanks a lot
