Función PING en Harbour / PING function in Harbour
edufloriv
Post by edufloriv »
Saludos amigos,
En el área de almacén tengo el problema que apagan el router y cuando inician su módulo les lanza un error porque evidentemente no hay conexión con el servidor. Quería consultarles si existe en Harbour una función similar a "Ping" del DOS, para verificar la disponibilidad de la red. Sé que puedo hacer un .batch y ejecutarlo con EXECUTE FILE pero quise consultarles si conocen alguna función en Harbour que haga lo mismo.
Agradeciendo su ayuda, reciban mis cordiales saludos.
Greetings, friends
In the warehouse area I have the problem that they turn off the router and when they start their module it throws an error because obviously there is no connection to the server. I wanted to ask if there is a function in Harbor similar to "Ping" of DOS, to verify the availability of the network. I know I can do a .batch and execute it with EXECUTE FILE but I wanted to ask if you know any function in Harbour that does the same.
Thank you for your help, receive my cordial greeting.
Eduardo Flores Rivas
LIMA - PERU
Re: Función PING en Harbour / PING function in Harbour
Quizá algo de aquí pueda servir...
Maybe something here can serve ...
http://www.hmgforum.com/viewtopic.php?f ... tem#p32282
Ping command in Harbour is here
Attached working example, change xurl := "www.google.com" to xurl := 192.168.1.1 etc.
Check Internet connectivity through PING command and it is reliable
From bpd2000
Expert help from KDJ
FUNCTION MAIN()
   Local xerrdescription , xurl := "www.google.com"
   xerrdescription := HB_PING(xurl)
   Do Case
      Case xerrdescription = 0
       MSGINFO("Ping to " + xurl + " Succesful", "Internet Connection Available")
      Case xerrdescription = 11001
       MSGINFO("The reply buffer was too small.")
      Case xerrdescription = 11002
       MSGINFO("The destination network was unreachable.")
      Case xerrdescription = 11003
       MSGINFO("The destination host was unreachable.")
      Case xerrdescription = 11004
       MSGINFO("The destination protocol was unreachable.")
      Case xerrdescription = 11005
       MSGINFO("The destination port was unreachable.")
      Case xerrdescription = 11006
       MSGINFO("Insufficient IP resources were available.")
      Case xerrdescription = 11007
       MSGINFO("A bad IP option was specified.")
      Case xerrdescription = 11008
       MSGINFO("A hardware error occurred.")
      Case xerrdescription = 11009
       MSGINFO("The packet was too big.")
      Case xerrdescription = 11010
       MSGINFO("The request timed out." + hb_osnewline() +"Internet Connection Not Available")
      Case xerrdescription = 11011
       MSGINFO("A bad request.")
      Case xerrdescription = 11012
       MSGINFO("A bad route.")
      Case xerrdescription = 11013
       MSGINFO("The time to live (TTL) expired in transit.")
      Case xerrdescription = 11014
       MSGINFO("The time to live expired during fragment reassembly.")
      Case xerrdescription = 11015
       MSGINFO("A parameter problem.")
      Case xerrdescription = 11016
       MSGINFO("Datagrams are arriving too fast to be processed" + hb_osnewline() + ;
       " and datagrams may have been discarded.")
      Case xerrdescription = 11017
       MSGINFO("An IP option was too big.")
      Case xerrdescription = 11018
       MSGINFO("A bad destination.")
      Case xerrdescription = 11050
        MSGINFO("A general failure" + hb_osnewline() + ;
          "This error can be returned for some malformed ICMP packets.")
      Otherwise
        msginfo("Internet Connection Not Available")
    ENDCASE
//https://groups.google.com/forum/#!topic/harbour-users/Jag2rPxWK_U
#pragma BEGINDUMP
#include <hbapi.h>
#include <winsock2.h>
#include <iphlpapi.h>
#include <icmpapi.h>
int hb_Ping( const char * cp )
    HANDLE hIcmpFile;
    unsigned long ipaddr = INADDR_NONE;     // corrected by KDJ
    DWORD dwRetVal;
    char SendData[32] = "Data Buffer";
    LPVOID ReplyBuffer;
    DWORD ReplySize;
    if( isalpha( cp[0] ) )      //host address is a name
       WSADATA wsaData;
       int     iResult;
       iResult = WSAStartup( MAKEWORD(2, 2), &wsaData );
       if( iResult == 0 )
          struct hostent *remoteHost = gethostbyname( cp );
          if( remoteHost != NULL )
             ipaddr = *(unsigned long *) remoteHost->h_addr_list[0];
          WSACleanup();
       ipaddr = inet_addr( cp );
    if (ipaddr == INADDR_NONE)
        return 1;
    hIcmpFile = IcmpCreateFile();
    if (hIcmpFile == INVALID_HANDLE_VALUE)
        return 2;
    ReplySize = sizeof(ICMP_ECHO_REPLY) + sizeof(SendData);
    ReplyBuffer = (VOID*) malloc(ReplySize);
    if (ReplyBuffer == NULL)
        IcmpCloseHandle(hIcmpFile);
        return 3;
    dwRetVal = IcmpSendEcho(hIcmpFile, ipaddr, SendData, sizeof(SendData),
        NULL, ReplyBuffer, ReplySize, 1000);
    free(ReplyBuffer);
    if (dwRetVal == 0)
        return GetLastError();
    return 0;
HB_FUNC( HB_PING )
   hb_retni( hb_Ping( hb_parc( 1 ) ) );
#pragma ENDDUMP
