Communication via http
Hi guys!
I've realised my first Arduino project. It will switch on/off lamp indicators depend on barcode scanner read in the warehouse.
Barcode scanner sends barcode to computer, computer sends info to my arduino which lamp should be switched on.
I've created http server which wait for info from computer via http.
I can control lamps via internet browser, calling arduino server: http://192.168.20.190/BRAMKA=3
I want to create simple application, which can call such a page.
Second problem is to act as http server to read info from wifi barcode reader.
Can anybody provide simplest http server application?
regards, Marek
regards, Marek
Re: Communication via http
Marek,
Can you please explain more about what you want?
I have a NETIO server but I don't think you mean that.
I need to build app, which will wait for transmision at eg. 80 port.
- srvet_claudio
I remember your work. But, I need minimum solution
I've simplified my procedure to control lamps:
I can switch on/off 32 sending www request:
Now, I need to create server, which will wait for request from codebar scanner
PROCEDURE SendRequestViaWWW
param cURL
local lSilent := .f.
LOCAL oCon, i
local ret := .f.
local cOdp:=""
for i:=1 to 3
// number of tries
oCon := TipClientHttp():New( cUrl )
IF oCon:Open()
cOdp := oCon:ReadAll()
msgdebug("Connected?", cOdp)
oCon:close()
ret := .t.
exit
next i
if !ret
MsgBox("Error in connection " + oCon:lastErrorMessage())
RETURN ret
SendRequestViaWWW("http://192.168.20.190/BRAMKA=16")
Marek, maybe this will be helpful: micro web server on hb (uhttpd)
https://github.com/harbour/core/tree/ma ... as/httpsrv
and
https://github.com/vszakats/harbour-cor ... ib/hbhttpd
and
I've created my solution. It's very small and it's doing what I want.
A month ago, I even didnt dream I'll be able to control some devices from harbour app via wifi.
I'll present my app later.
So I'm waiting impatiently
