GridAdo
- luisvasquezcl
GridAdo
Dear Roberto,
I am preparing a grid to work with Ado process and need to know where the keys of movement because it requires synchronizing the grid with the recordset.
At this point already loading data and sample correctly but I want to burn can also browse the records automatically.
Greetings
Luis Vasquez.
Greetings
Luis Vasquez.
- HMG Founder
Re: GridAdo
I'm afraid that I'm not sure about understand your question...luisvasquezcl wrote:Dear Roberto,
Greetings
Luis Vasquez.
Could you be so kind to clearify it a liitle?
TIA.
- luisvasquezcl
Re: GridAdo
I need to create procedures for processing the keys Up Dn Home End, this recordset I synchronize with the grid.
Look at h_grid but not encounter these procedures, can control where that?.
- HMG Founder
Re: GridAdo
Ok. Key events for grid are not implemented, but you could take a look at 'events' function (h_windows.prg). Movement keys are processed for browse (browse is based in Listviwe like grid). That could be useful for you.luisvasquezcl wrote:I need to create procedures for processing the keys Up Dn Home End, this recordset I synchronize with the grid.
- luisvasquezcl
Re: GridAdo
Ok Roberto,
Thanks
Thanks
- luisvasquezcl
Re: GridAdo
Dear Roberto,
I finished the grid.
I would like to see what Viera, give me your comments and criticisms and of course I do not know if much serious prentender inclusion in the library because I believe it will be very helpful to our colleagues.
Luis Vasquez.
Luis Vasquez.
- HMG Founder
Re: GridAdo
Please, upload to the forum so, all could view it and give you our impressions.luisvasquezcl wrote:Dear Roberto,
Luis Vasquez.
- luisvasquezcl
Re: GridAdo
Hi Friends
I have a little problem but now is fixed. 8).
The file is attached.
I wait for your comments.
Luis Vasquez.
Luis Vasquez.
- Grid_ado.zip
- (50.01 KiB) Downloaded 1126 times
- HMG Founder
Re: GridAdo
When you attempt to enter an invalid date, and you follow to the next field with <ENTER> the following error occurs:luisvasquezcl wrote:Hi Friends
Luis Vasquez.
Error BASE/1118 Argument error: DTOC</p><BR>
Called from DTOC(0)
Called from _SETITEM(1565)
Called from _HMG_SETGRIDCELLVALUE(1100)
Called from _HMG_GRIDINPLACEEDITOK(876)
Called from (b)_HMG_GRIDINPLACEEDIT(610)
Called from _DOCONTROLEVENTPROCEDURE(4381)
Called from EVENTS(467)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4046)
- luisvasquezcl
Re: GridAdo
Ok Roberto,
Im going to make more test and fixed problems.
Regards.
Regards.
