Harbour MiniGUI Extended Edition build 17.12 is published
Hi Friends,
I am very glad to announce a new release of Harbour MiniGUI Extended Edition.
A setup of the build 17.12 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
The upgrade to this build is highly recommended.
There are the private Minigui Ex builds also for the following C-compilers
by your request:
- MinGW 7.2.0 (32-bit) and Harbour 3.2.0dev;
- MinGW 7.2.0 (64-bit) and Harbour 3.4.0dev;
- MS Visual C++ 2017 (32-bit) and Harbour 3.2.0dev;
- Borland/Embarcadero C++ 7.3 (32-bit) and Harbour 3.2.0dev.
Thanks for your attention and support!
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 17.12 is published
Thanks Grigory !
Thanks Grigory,
Steed
Post by Steed »
Thanks
quartz565
Post by quartz565 »
Thank you Grigory !
Nikos.
os: Windows Server 2019 - 64
gfilatov wrote: Mon Dec 18, 2017 9:18 am Hi Friends,
Thanks for your great work Grigory!
Dear Roberto,
Thank you very much for your kind words, Master!
The most major modification in this build is a posibility to load the resources from an external DLL.
It is possible now to load the following resources from DLL:
the dialogs, menu with accelerators, icons, images, animates,
cursors and sounds.
Anand
Post by Anand »
Looking forward to using it.
Thanks Grigory
Anand
Anand
vagblad
DBs Used: MySQL,DBF
Post by vagblad »
Thanks for the great work Grigory!
Tested the dll feature already and it works like a charm. This feature is a big update indeed.
Vagelis Prodromidis
