Drag grid item to another grid
Re: Drag grid item to another grid
mol wrote: Fri Jan 11, 2019 9:45 pm We have no leader now, who will create new versions.
It's really sad.
Thanks Edward for your great work!
like
like
Except leaderless status :(
We have a forum builder admin, it isn't :?
There is a problem with <ParentWindowName>.<TreeControlName>.GetPathValue ( nValue ) --> anPathValue | NIL get property.
When I call it, runtime error is generated:
Error BASE/1132 Błąd zakresu tablicy: Nieprawidłowa liczba argumentów - Error array range - Incorrect number of parameters
Called from OBSLBLEDU(758)
Called from (b)MAIN(239)
Called from TREEITEMGETHANDLE(442)
Called from TREEITEMGETPATHVALUE(598)
Called from _TREE_GETPROPERTY(10062)
Called from GETPROPERTY(8361)
Called from line: MsgDebug(this.Value, MainForm.Tree.GetPathValue(this.Value))
mol wrote: Tue Jan 15, 2019 3:03 pm There is a problem with <ParentWindowName>.<TreeControlName>.GetPathValue ( nValue ) --> anPathValue | NIL get property.
I can't reproduce it. :( Get path by DblClick on node/item
Function main()
EnableDragAndDrop()
	DEFINE WINDOW Form_1 ;
		WIDTH 700 ;
		HEIGHT 500 ;
		TITLE 'TreeView Simple Sample Drag And Drop' ;
		MAIN
		@ 30,10 LABEL Label_2 VALUE "Tree #1." AUTOSIZE
		DEFINE TREE Tree_1 ;
				AT 50,10 ;
				WIDTH 200 HEIGHT 400 ;
				VALUE 227 ;
				ON GOTFOCUS Drag_Tree1() ;
				ON CHANGE Form_1.Title:='Tree #1, Item # '+hb_valtostr(Form_1.tree_1.Value)+" , ItemName " +Form_1.tree_1.Item(Form_1.Tree_1.Value) ;
	               ON DBLCLICK MsgDebug (Form_1.Tree_1.Value, Form_1.Tree_1.GetPathValue (Form_1.Tree_1.Value)) ;
				ITEMIDS
			NODE 'Item 1' ID 1
				TREEITEM 'Item 1.1' ID 11
				TREEITEM 'Item 1.2' ID 12
				TREEITEM 'Item 1.3' ID 13
			END NODE
			NODE 'Item 2' ID 2
				TREEITEM 'Item 2.1' ID 21
				NODE 'Item 2.2' ID 22
					TREEITEM 'Item 2.2.1' ID 221
					TREEITEM 'Item 2.2.2' ID 222
					TREEITEM 'Item 2.2.3' ID 223
					TREEITEM 'Item 2.2.4' ID 224
					TREEITEM 'Item 2.2.5' ID 225
					TREEITEM 'Item 2.2.6' ID 226
					TREEITEM 'Item 2.2.7' ID 227
					TREEITEM 'Item 2.2.8' ID 228
				END NODE
				TREEITEM 'Item 2.3' ID 23
			END NODE
			NODE 'Item 3' ID 3
				NODE 'Item 3.1' ID 31
					TREEITEM 'Item 3.1.1' ID 311
					NODE 'Item 3.1.2' ID 312
						TREEITEM 'Item 3.1.2.1' ID 3121
						TREEITEM 'Item 3.1.2.2' ID 3122
					END NODE
					TREEITEM 'Item 3.1.3' ID 313
				END NODE
				TREEITEM 'Item 3.2' ID 32
				NODE 'Item 3.3' ID 33
					TREEITEM 'Item 3.3.1' ID 331
					TREEITEM 'Item 3.3.2' ID 332
				END NODE
			END NODE
		END TREE
	MsgInfo( "Do tree items use IDs? " + hb_valToStr( _IsTreeItemIDs ( 'Tree_1', 'Form_1' ) ))
	ACTIVATE WINDOW Form_1
Function Drag_Tree1()
Local cDragFName := HMG_DaD_Drag_Window()
Local cDragCName := HMG_DaD_Drag_Control()
Local cDropFName := HMG_DaD_Drop_Window()
Local cDropCName := HMG_DaD_Drop_Control()
Local nDragTreeValue := HMG_DaD_DragTreeValue()
Local nDropTreeValue := HMG_DaD_DropTreeValue()
Local lIsDraggedWithRightButton := HMG_Is_RButtonDaD()
Local lIsDraggedWithShiftButton := HMG_Is_ShiftDaD()
IF HMG_Is_DaD()
	HMG_Release_DaD()
	DO CASE
		CASE cDragFName == cDropFName .AND. cDragFName == 'Form_1' .AND. cDragCName == cDropCName .AND. cDragCName == 'Tree_1' .AND. nDragTreeValue <> nDropTreeValue
			Tree_UpDate ( cDragFName, cDragCName, nDragTreeValue, cDropCName, cDropFName, nDropTreeValue, .F. /* no copying at IDs -> you have to send some new iID some way ?!? */, !lIsDraggedWithShiftButton )
		ENDCASE
FUNCTION Tree_UpDate ( cDragFName, cDragCName, nDragTreeValue, cDropCName, cDropFName, nDropTreeValue, lCopy, lAdd )
Local aDragItems := _GetTreeItemStru( cDragFName, cDragCName, nDragTreeValue )
//Notice: Version for tree IDs ONLY
IF nDropTreeValue == 0 .AND. !MsgYesNo("Do you want to add an item as Root?", "Dropped in an empty area.", .T.)
	RETURN Nil
IF !EMPTY ( aDragItems )
	DoMethod (cDragFName, cDragCName, "DisableUpdate")
	DoMethod (cDropFName, cDropCName, "DisableUpdate")
	//remove first to prevent duplicate id from appearing
	DoMethod (cDragFName, cDragCName, "DeleteItem", nDragTreeValue)
	IF lAdd		//add item
		AEVAL ( aDragItems, { |x| IF ( x[3] == 0, ;
									DoMethod (cDropFName, cDropCName, "AddItem", x[2] , nDropTreeValue /* add on the drop position */, x[1] /* original id */ ) , ;
									DoMethod (cDropFName, cDropCName, "AddItem", x[2] ,  x[3] /* add to the parent position */  , x[1] /* original id */ ) ) } )
	ELSE			//insert
		_InsertItem ( cDropCName, cDropFName, aDragItems[1][2] , nDropTreeValue , aDragItems[1][1] /* original id */)
		hb_ADel( aDragItems, 1, .T. )
		AEVAL ( aDragItems, { |x| DoMethod (cDropFName, cDropCName, "AddItem", x[2] , x[3] /* add to the parent position */ , x[1] /* original id */ )  } )
	DoMethod (cDropFName, cDropCName, "SetDefaultAllNodeFlag")
	DoMethod (cDragFName, cDragCName, "EnableUpdate")
	DoMethod (cDropFName, cDropCName, "EnableUpdate")
FUNCTION _GetTreeItemStru( cFormName, cTreeName, nTreeValue )
Local ix := 0
Local aTreeStru := {}, aChild
Local nParent := 0, nItem := 1
IF nTreeValue = 0 //New root
	nTreeValue := 1
IF IsControlDefined ( &cTreeName, &cFormName )
	ix := GetControlIndex (cTreeName , cFormName )
	AADD (aTreeStru, { nTreeValue, GetProperty (cFormName, cTreeName, "Item", nTreeValue), nParent } )
	Do While nItem <= LEN ( aTreeStru )
		nParent := aTreeStru [nItem] [1]
		aChild := GetProperty ( cFormName, cTreeName, "ChildValue", nParent )
		nItem ++
		IF hb_isArray ( aChild )
			AEVAL (aChild, { |x| AADD( aTreeStru, { x, GetProperty (cFormName, cTreeName, "Item", x), nParent } ) } )
	EndDo
IF _IsTreeItemIDs ( cTreeName, cFormName ) .AND. ix > 0
	ASORT ( aTreeStru, , , { |x, y| ascan ( _HMG_SYSDATA [ 25 ] [ix] , x[1] ) < ascan ( _HMG_SYSDATA [ 25 ] [ix] , y[1] ) } )
	ASORT ( aTreeStru, , , { |x, y| x[1] < y[1] } )
//*** Structure of aTreeStru***************
//* { { nItem, cItemText, nParentItem } , ... }
Return aTreeStru
jairpinho
Post by jairpinho »
edk wrote: Sat Dec 16, 2017 10:10 pm Next version.
Support for dragging GRID column headers has been added.
Due to the ON HEADCLICK event handler, dragging is possible with the right mouse button only.
Within the same Grid, dragging the header changes the order of the columns.
Dragging a column header from GRID Form_1 to Grid Form_2 or Form_3 adds a new column.
By the way, I found a bug in the operation of the AddColumnEx method.
If we add a new column between existing ones, after inserting the column, the neighbor column's caption also changes.
You can test this eg in \SAMPLES\Controls\Grid\GRID_40 changing in file demo.prg line No. 108 from
@ 250,  55 BUTTON Button_1 CAPTION "AddCol" ACTION Form_1.Grid_1.AddColumnEx (Nil, "Col"+alltrim(str(++n)), 100, NIL, {'TEXTBOX','NUMERIC','$ 999,999'})
to
@ 250,  55 BUTTON Button_1 CAPTION "AddCol" ACTION Form_1.Grid_1.AddColumnEx (2, "Col"+alltrim(str(++n)), 100, NIL, {'TEXTBOX','NUMERIC','$ 999,999'})
Dragging GRID columns is possible only within currently visible columns and only from GRID, in which Items are.
In addition, the problem with ScrollBar in GRID was revealed. By moving the mouse pointer to ScrollBar the handle does not change, and the program "Sees" as if it was still on GRID, moving the slider horizontally may result in a drag effect.
I'm really sorry for the imperfections of my DragAndDrop.
Certainly better results could be obtained using the C language, but this is beyond my reach.
edk, fantastic work congratulations
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
jairpinho
Post by jairpinho »
hello, I need to use drag grid in the same grade could help someone
Jair Pinho
