RUC SUNAT
edufloriv
RUC SUNAT
Post by edufloriv »
Saludos amigos,
Estoy tratando de compilar un ejemplo que compartieron hace algunos meses para hacer consultas de RUC acá en Perú:
* SISTEMA     :                                          *
* PRG         :                                          *
* CREADO      :                                          *
* ACTUALIZADO :                                          *
* AUTOR       :                                          *
* COMENTARIOS :                                          *
#include <minigui.ch>
FUNCTION MAIN
   DEFINE WINDOW Win_1;
      WIDTH 640 HEIGHT 460 ;
      TITLE 'Consulta RUC' ;
      ON INIT INISETS() ;
      MAIN
      DEFINE MAIN MENU
         POPUP "&Operaciones"
            ITEM '&1. Bajar captcha SUNAT'              ACTION BajarCaptcha()
         END POPUP
      END MENU
   CENTER WINDOW Win_1
   ACTIVATE WINDOW Win_1
* FUNCION...: INISETS
* COMENTARIO: INICIALIZA LOS SETEOS DEL SISTEMA.
PROC INISETS
SET BELL       Off
SET CONSOLE    Off
SET CURSOR     Off
SET DATE TO BRIT
SET DELETED    On
SET DELIMITERS Off
SET ECHO       Off
SET EPOCH TO 1990
SET MESSAGE TO 22 CENTER
SET SAFETY     Off
SET SCOREBOARD Off
SET TALK       Off
SET WRAP       On
SETMODE(25,80)
ALTD(0)
Func BajarCaptcha
LOCAL cOrigen := "www.sunat.gob.pe/cl-ti-itmrcosruc/captcha?accion=image"
LOCAL cDestin := "c:\infofarma\tmp\ruc_capcha.jpg"
   IF URLDownLoad( cOrigen , cDestin )
      MsgInfo('Descarga exitosa')
Func BuscaInfoRUC(cRuc,cCapcha)
local r
local i
local s
local nPos
local cN
local cD
local xL   := ''
local cF   := "test.txt"
local cUrl := "http://www.sunat.gob.pe/cl-ti-itmrconsruc/jcrS00Alias?accion=consPorRuc&nroRuc="+cRuc+" &codigo="+cCapcha+" &tipdoc=1"
if empty(cRuc)
   MsgStop("no ha ingresado RUC valido para consultar","Error")
   URLDownLoad(cUrl, cF)
   if file(cF)
      r:=MemoRead(cF)
      if at('El numero Ruc ingresado es invalido',r) > 0
         Msgwait("El numero Ruc ingresado es invalido o no existe",,1)
         Do while .t.
            i:=At( CRLF, r )
            If i=0
               exit
            Endif
            s:=Left( r, i-1)
            r:=Subs( r, i+2)
            If (nP := at('N&#xFA;mero Ruc.', s ) ) > 0
               cN := substr(s, nP+16)
               If (nP := at(trim(cRuc), cN ) ) > 0
                  cN := substr(cN, nP+14)
                  cN := strtran(cN,"<br/>","")
                  cN := strtran(cN,"</small>","")
                  cN := STRTRAN(cN,"&#209;", "Ñ")
                  cN := STRTRAN(cN,"&#xD1;", "Ñ")
                  cN := STRTRAN(cN,"&#193;", "Á")
                  cN := STRTRAN(cN,"&#201;", "É")
                  cN := STRTRAN(cN,"&#205;", "Í")
                  cN := STRTRAN(cN,"&#211;", "Ó")
                  cN := STRTRAN(cN,"&#218;", "Ú")
                  cN := STRTRAN(cN,"&#xC1;", "Á")
                  cN := STRTRAN(cN,"&#xC9;", "É")
                  cN := STRTRAN(cN,"&#xCD;", "Í")
                  cN := STRTRAN(cN,"&#xD3;", "Ó")
                  cN := STRTRAN(cN,"&#xDA;", "Ú")
               MsgInfo(cN)  // muestro la informacion que me interesa
               exit
            Endif
         Enddo
return nil
function URLDownLoad(cUrl, cSaveAs)
if ! URLDownloadToFile( 0, cUrl, cSaveAs, 0, 0 ) == 0
   retu.f.
retu.t.
DLL32 FUNCTION URLDownloadToFile(pCaller AS LONG,szURL AS STRING, szFileName AS STRING, dwReserved AS LONG, lpfnCB AS LONG);
AS LONG PASCAL;
FROM "URLDownloadToFileA";
LIB "urlmon.dll"  // <-- Linea 151
El compilador me lanza error :
Les agradeceré su ayuda amigos.
Saludos cordiales,
Eduardo Flores Rivas
LIMA - PERU
Re: RUC SUNAT
Hola Edu:
Dll32 FUNCTION es una función dentro de la librería contrib xhb .
Es necesario #include "hbdll.ch" y #require "xhb"
Y adicionar en el IDE de Hmg las rutas donde se encuentran los .ch de xharbour
Incpath
edufloriv
Re: RUC SUNAT
Post by edufloriv »
Hola Daniel,
Gracias por tu respuesta. Revisando el HMG no existe en harbour\include el archivo hbdll.ch, lo descargue de un post del año 2012 que encontré en un grupo pero parece no funcionar:
Te agradeceré me lo hagas llegar por favor. Me parece que no viene en la distribución del HMG.
Saludos cordiales y nuevamente gracias por tu tiempo amigo.
LIMA - PERU
Re: RUC SUNAT
Está dentro de harbour\contrib\xhb.
También en \harbour64\contrib\xhb
Sería mejor que descargues con la librería HBTip lo que necesitas
edufloriv
Re: RUC SUNAT
Post by edufloriv »
Hola Daniel,
Estoy revisando la documentación de hbtip. Dime, el ejemplo tipwget.prg serviría para mi caso de descargar desde el site de SUNAT ("http://www.sunat.gob.pe/cl-ti-itmrcosru ... cion=image") ? solo tengo experiencia trabajando con FTP no he trabajado aún con http.
Agradecido por tu tiempo,
Att.
LIMA - PERU
edufloriv
Re: RUC SUNAT
Post by edufloriv »
Hola Daniel,
Creo que esto es lo que necesito cierto, lo encontré aca en el foro:
PROCEDURE DownloadFromWWW
   param cURL, cLocalFileName
   LOCAL oCon, oUrl, i
   cLocalFileName := alltrim(cLocalFileName)
   oUrl := tURL():New( cUrl )
   IF Empty( oUrl )
      MsgBox("Invalid url " + cUrl)
      return
   IF oUrl:cProto != "http"
      MsgBox('This is a header test for http. Use an http address.')
      return
   END
   oCon := TipClientHttp():New( oUrl )
   oCon:nConnTimeout := 20000
   MsgBox("Connecting with "+ oUrl:cServer)
   IF oCon:Open( cUrl )
   MsgBox("Connection eshtablished." +chr(10)+"Press OK to retrieve" + oUrl:cPath +oUrl:cFile)
   oCon:WriteAll(cLocalFileName)
   MsgBox("Downloaded...")
    oCon:Close()
      MsgBox("Can't connect with "+ oUrl:cServer)
      IF oCon:SocketCon == NIL
         MsgBox("Connection not initiated")
      ELSEIF hb_InetErrorCode( oCon:SocketCon ) == 0
         MsgBox("Server sayed: "+ oCon:cReply)
         MsgBox("Error in connection: " + hb_InetErrorDesc( oCon:SocketCon ))
   END
Confirmame, pero creo que voy a hacer pruebas, saludos.
LIMA - PERU
edufloriv
Re: RUC SUNAT
Post by edufloriv »
Daniel saludos,
Voy progresando. Ya logré descargar el captcha, al principio no podia porque la dirección de la Sunat habia cambiado, ahora tengo así mi código:
* SISTEMA     :                                          *
* PRG         :                                          *
* CREADO      :                                          *
* ACTUALIZADO :                                          *
* AUTOR       :                                          *
* COMENTARIOS :                                          *
FUNCTION MAIN
      ON INIT INISETS() ;
      MAIN
      DEFINE MAIN MENU
            ITEM '&2. Captcha a .TXT'              ACTION CaptchaToTxt()
         END POPUP
      END MENU
   CENTER WINDOW Win_1
PROC INISETS
SET BELL       Off
SET CONSOLE    Off
SET CURSOR     Off
SET DATE TO BRIT
SET DELETED    On
SET DELIMITERS Off
SET ECHO       Off
SET EPOCH TO 1990
SET SAFETY     Off
SET SCOREBOARD Off
SET TALK       Off
SET WRAP       On
ALTD(0)
Func BajarCaptcha
//LOCAL cOrigen := "http://www.sunat.gob.pe/cl-ti-itmrcosruc/captcha?accion=image"
LOCAL cOrigen := "http://e-consultaruc.sunat.gob.pe/cl-ti-itmrconsruc/captcha?accion=image"
LOCAL cDestin := "c:\infofarma\tmp\captcha.jpg"
Func CaptchaToTxt
LOCAL cEjecutable := chr(34)+'c:\Tes\tesseract.exe'+chr(34)
LOCAL cParameters := chr(34)+'c:\infofarma\tmp\captcha.jpg c:\infofarma\tmp\captcha -psm 7'+chr(34)
   ShellExecute( 0 , "open" , cEjecutable , cParameters )
   MsgInfo('Transformación realizada.')
Func BuscaInfoRUC(cRuc,cCaptcha)
local r
local i
local s
local nPos
local cN
local cD
local xL   := ''
local cUrl := "http://e-consultaruc.sunat.gob.pe/cl-ti-itmrconsruc/jcrS00Alias?accion=consPorRuc&nroRuc="+cRuc+" &codigo="+cCaptcha+" &tipdoc=1"
//local cUrl := "http://www.sunat.gob.pe/cl-ti-itmrconsruc/jcrS00Alias?accion=consPorRuc&nroRuc="+cRuc+" &codigo="+cCapcha+" &tipdoc=1"
if empty(cRuc)
   if file(cF)
      r:=MemoRead(cF)
         Msginfo("El numero Ruc ingresado es invalido o no existe",,1)
         Do while .t.
            i:=At( CRLF, r )
            If i=0
               exit
            Endif
            s:=Left( r, i-1)
            r:=Subs( r, i+2)
               exit
            Endif
         Enddo
return nil
PROCEDURE URLDownLoad
   LOCAL oCon, oUrl, i
   IF Empty( oUrl )
      return
      return
      oCon:Close()
Ahora tengo el problema con el TESSERACT, no me genera el .TXT, (FUNC CaptchaToTxt) agradeceré su ayuda.
Saludos cordiales a todos,
LIMA - PERU
gvaronas
Re: RUC SUNAT
Post by gvaronas »
Hola:
El año pasado intente hacer algo de esto.
El hilo lo puse en el foro de harbour-users aqui:
https://groups.google.com/forum/#!msg/h ... bour-users
Aqui tambien puse el PRG con el que estuve probando.
Me base en esta pagina:
https://tisoft.wordpress.com/category/consultas-sunat/
El código se ejecuta bien, el Tessearct hace bien su trabajo y me devuelve el captcha en formato txt plano para poder armar mi consulta a
traves del TipClientHttp().
El problema es que la pagina que recojo en "datos.xml", siempre me trae los datos de la pagina de error, como si le hubiese dado mal el captcha.
Si hago la consulta en el navegador con el captcha que me da el Tessearct funciona perfectamente
Lamentablemente tengo problemas con el idioma y ya no pude preguntar y dar mas detalles de mi problema en el foro.
Te sugiero revises el PRG y lo pruebes, lo mas probable es que se trate de algún problema tonto que no soy capaz de descubrir.
Salu2,
GVS
edufloriv
Re: RUC SUNAT
Post by edufloriv »
Gvaronas, gracias por tu respuesta, me sirvió mucho tu código.
Aqui te lo paso con los nuevos links funcionales de la SUNAT. Efectivamente siempre devuelve la página de error, pero si pego la query directamente en el navegador devuelve los datos en el navegador sin problemas. Tendré que indagar más.
* SISTEMA     :                                          *
* PRG         :                                          *
* CREADO      :                                          *
* ACTUALIZADO :                                          *
* AUTOR       :                                          *
* COMENTARIOS :                                          *
FUNCTION MAIN
      ON INIT INISETS() ;
      MAIN
      DEFINE MAIN MENU
            ITEM '&1. Buscar RUC'                  ACTION TestRuc()
         END POPUP
      END MENU
   CENTER WINDOW Win_1
PROC INISETS
SET BELL       Off
SET CONSOLE    Off
SET CURSOR     Off
SET DATE TO BRIT
SET DELETED    On
SET DELIMITERS Off
SET ECHO       Off
SET EPOCH TO 1990
SET SAFETY     Off
SET SCOREBOARD Off
SET TALK       Off
SET WRAP       On
SETMODE(25,80)
ALTD(0)
Proc TestRuc
LOCAL cQueRUC  := '10074902419'
   ConsRUC( cQueRuc )
FUNCTION ConsRUC( cRuc )
LOCAL lOk := .T.
LOCAL oHttp
LOCAL cHtml
LOCAL qHttp
LOCAL cCaptcha := ''
   oHttp:= TIpClientHttp():new( "http://e-consultaruc.sunat.gob.pe/cl-ti-itmrconsruc/captcha?accion=image" )
   // Connect to the HTTP server
   IF oHttp:open()
      cHtml   := oHttp:readAll()
      Memowrit( "captcha.jpg" , cHtml )
      oHttp:close()
      // Convierto foto en texto
      cFile := "captcha"
      hb_run( "c:\tes\tesseract.exe captcha.jpg captcha -psm 7")
      // Leo el TXT
      cfile += '.txt'
      IF file( cFile )
         cCaptcha := hb_MemoRead( cFile )
         cCaptcha := ALLTRIM( cCaptcha )
         cCaptcha := LEFT(cCaptcha,4)
         Alert(cfile+' no existe')
      // Armo la consulta del RUC y Connect to the HTTP server
      qHttp:= "http://e-consultaruc.sunat.gob.pe/cl-ti-itmrconsruc/jcrS00Alias?accion=consPorRuc&nroRuc="+cRuc+"%20&codigo="+cCaptcha+"%20&tipdoc=1"
      MsgInfo(qHTTP)
      oHttp:= TIpClientHttp():new( qHttp )
      IF ! ( lOk := oHttp:open() )
         Alert( "Error de Conexión:; " + oHttp:lastErrorMessage() )
         RETURN lOk
      /* download the pagina de respuesta con los datos del RUC */
      Memowrit( "datos.html" , cHtml )
      oHttp:close()
RETURN lOk
Te informaré si consigo la obtención de los datos.
Saludos cordiales,
LIMA - PERU
