convert draw line to HPDFPRINT LINE
jairpinho
Post by jairpinho »
I have a graph on the screen created with draw line I need to generate this graph in a pdf file I'm trying HPDFPRINT LINE without success
draw line in at x1,x2 to y1,y2
@ row ,col hpdfprint line to tRow , tCol
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: convert draw line to HPDFPRINT LINE
In my app, code like this, works OK:
@ nRow, nCol HPDFPRINT LINE to nRow+nMaxRowHeight+nHeight, nCol+nWidth ;
								PENWIDTH 0.1 COLOR BLACK
jairpinho
Post by jairpinho »
mol wrote: Thu Sep 07, 2017 5:44 am In my app, code like this, works OK:
could describe the variables
nMaxRowHeight ?
nHeight ?
nWidth ?
check my code
tendencia.zip
(1.71 KiB) Downloaded 716 times
function drawshapes()
local lSuccess := .f.
local cLB := chr( 10 )
lOCAL cArquivo, cData
Local cFonte1:= "Helvetica"
Local nFonte_size00 := 8
Local nFonte_size0 := 9
Local nFonte_size1 := 10
Local nFonte_size2 := 11
Local nFonte_size3 := 12
Local nFonte_size4 := 14
Local nFonte_size5 := 15
Local I := 1
LOCAL x_x1 := 500 , x_y1 := 300 , x_x2:= 500 , x_y2:= 800
LOCAL y_x1 := 30 , y_y1 := 400 , y_x2:= 600 , y_y2:= 400
local x1:=mathematica.text_1.value
local y1:=mathematica.text_2.value
	x2 := mathematica.text_3.value     // tempo decorrente
	y2:= mathematica.text_4.value     // tempo decorrente
	draw line in window mathematica at x_x1-y1,y_y2+x1 to x_x1-y2,y_y2+x2 pencolor {255,0,0} penwidth 2
		//x2:= x1
		//y2:= y1
cArquivo:= DiskName()+ ":\"+CurDir() + "\Relatorio"+ ".pdf"
   SELECT HPDFDOC cArquivo TO lSuccess ORIENTATION HPDF_ORIENT_LANDSCAPE PAPERSIZE HPDF_PAPER_A4
   SET HPDFDOC  COMPRESS ALL
   SET HPDFDOC  PAGEMODE TO OUTLINE
   SET HPDFINFO AUTHOR      TO 'Jair Pinho'
   SET HPDFINFO CREATOR     TO 'Jair Pinho'
   SET HPDFINFO TITLE      TO 'Relaório'
   SET HPDFINFO SUBJECT     TO 'Criado com LibHaru/HPDF Library'
   SET HPDFINFO KEYWORDS    TO 'HMG, HPDF, Documentation, LibHaru, Harbour, MiniGUI'
   SET HPDFINFO DATECREATED TO date() TIME time()
   SET HPDFDOC  ENCODING TO "WinAnsiEncoding"
   if lSuccess
        START HPDFPAGE
        SET HPDFDOC PAGEOUTLINE TITLE "Relatorio de Tendencias"
			@ 140 , 010  HPDFPRINT LINE TO  140 , 280 PENWIDTH 0.5 COLOR { 255, 0, 0 } // linha x  mm  inicia em cima top = 0
			@ 010 , 050  HPDFPRINT LINE TO  160 , 050 PENWIDTH 0.5 COLOR { 255, 0, 0 }   // linha y  mm inicia em cima top = 0
			@ 297-x1, 210-y1  HPDFPRINT LINE TO 297-x2 , 210-y2 PENWIDTH 2 COLOR { 255, 0, 0 }
		END HPDFPAGE
		END HPDFDOC
 execute file cArquivo
Jair Pinho
These are my private variables computed via application. Nothing special. That's a piece of code which really works ok
jairpinho wrote: Thu Sep 07, 2017 6:26 pm
nMaxRowHeight ?
nHeight ?
nWidth ?
check my code tendencia.zip
Local I := 1
		//x2:= x1
		//y2:= y1
   if lSuccess
        START HPDFPAGE
		END HPDFPAGE
		END HPDFDOC
You didn't attach mathematica.fmg file.
I've donloaded your sample, I've cutted every piece of code which draws in mathematica form and I got .pdf file with to line - horizontal and vertical with width 0.5 mm.
Then I've changed horizontal line to 5 mm and I got it.
function main
Private x2 := 0 //inicializa com zero e depois a funcao incrementa
Private y2 := 0 // inicializa com zero e depois a funcao incrementa
private pos	:= .f.
IF !IsWindowDefined(mathematica)
					Load Window mathematica
					 draw line in window mathematica at x_x1,x_y1 to x_x2,x_y2 pencolor {0,0,0} penwidth 1  // linha x
					draw line in window mathematica at y_x1,y_y1 to y_x2,y_y2 pencolor {0,0,0} penwidth 1  // linha y
                    Center	WINDOW  mathematica
                    ACTIVATE 	WINDOW 	mathematica
Else
	mathematica.Center
	mathematica.Restore
Endif
drawshapes()
return nil
Local I := 1
//local x1:=mathematica.text_1.value
//local y1:=mathematica.text_2.value
y1 := 10
x1:=10
//	x2 := mathematica.text_3.value     // tempo decorrente
//	y2:= mathematica.text_4.value     // tempo decorrente
	//draw line in window mathematica at x_x1-y1,y_y2+x1 to x_x1-y2,y_y2+x2 pencolor {255,0,0} penwidth 2
		//x2:= x1
		//y2:= y1
   if lSuccess
        START HPDFPAGE
			@ 140 , 010  HPDFPRINT LINE TO  140 , 280 PENWIDTH 5 COLOR { 255, 0, 0 } // linha x  mm  inicia em cima top = 0
		END HPDFPAGE
		END HPDFDOC
jairpinho
Post by jairpinho »
mol wrote: Thu Sep 07, 2017 7:18 pm I've donloaded your sample, I've cutted every piece of code which draws in mathematica form and I got .pdf file with to line - horizontal and vertical with width 0.5 mm.
function main
private pos	:= .f.
Else
	mathematica.Center
	mathematica.Restore
Endif
drawshapes()
return nil
Local I := 1
y1 := 10
x1:=10
		//x2:= x1
		//y2:= y1
   if lSuccess
        START HPDFPAGE
		END HPDFPAGE
		END HPDFDOC
I need the pdf to be the same as the lines generated with draw line
prg manual
tendencia.zip
(2.39 KiB) Downloaded 745 times
prg auto
Main.zip
(3.51 KiB) Downloaded 744 times
Jair Pinho
