label at runtime
jairpinho
label at runtime
Post by jairpinho »
Hello, I need to create 100 label at runtime, after the main window is already active to add in a graphic
Jair Pinho
HMG ALTA REVOLUÇÃO xBASE
HMG xBASE REVOLUTION HIGH
http://www.hmgforum.com.br
Re: label at runtime
Hi.
Do you mean this behaviour?
    DEFINE WINDOW main AT 108 , 360 WIDTH 550 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "" ICON NIL MAIN CURSOR NIL ON INIT Nil ON RELEASE Nil ON INTERACTIVECLOSE Nil ON MOUSECLICK Nil ON MOUSEDRAG Nil ON MOUSEMOVE Nil ON SIZE Nil ON MAXIMIZE Nil ON MINIMIZE Nil ON PAINT Nil BACKCOLOR Nil NOTIFYICON NIL NOTIFYTOOLTIP NIL ON NOTIFYCLICK Nil ON GOTFOCUS Nil ON LOSTFOCUS Nil ON SCROLLUP Nil ON SCROLLDOWN Nil ON SCROLLLEFT Nil ON SCROLLRIGHT Nil ON HSCROLLBOX Nil ON VSCROLLBOX Nil
    DEFINE BUTTON Button_1
        ROW    280
        COL    30
        WIDTH  100
        HEIGHT 28
        ACTION AddPict()
        CAPTION "Picture"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
    DEFINE BUTTON Button_2
        ROW    280
        COL    410
        WIDTH  100
        HEIGHT 28
        ACTION AddLabels()
        CAPTION "Labels"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
        Main.Center
        Main.Activate
FUNCTION addPict()
IF IsControlDefined ( "Image_1" , "Main" )
	Main.Image_1.Release
DEFINE IMAGE Image_1
	PARENT Main
        ROW    30
        COL    60
        WIDTH  420
        HEIGHT 220
        PICTURE "img.jpg"
        HELPID Nil
        VISIBLE .T.
        STRETCH .T.
        ACTION Nil
    END IMAGE
FUNCTION AddLabels()
Local i, cLabelName
Local isControl:=IsControlDefined ( "L_1" , "Main")
FOR i=1 TO 100
	cLabelName:='L_'+ALLTRIM(STR(i))
	IF isControl
		DoMethod("Main", cLabelName, "Release")
	    DEFINE LABEL &cLabelName
		PARENT Main
	        ROW    30+(20*int(i/10))
        	COL    60+(40*(i%10))
	        WIDTH  30
        	HEIGHT 20
        	VALUE ALLTRIM(STR(i))
	        FONTNAME "Arial"
        	FONTSIZE 9
	        VISIBLE .T.
	    END LABEL
NEXT i
By the way, I noticed the strange behavior of the IsControlDefined function:
IsControlDefined ( cLabelName , "Main") does not return "true" for the label controls already defined :shock:
Local i, cLabelName
FOR i=1 TO 100
	IF IsControlDefined ( cLabelName , "Main")
		PARENT Main
        	COL    60+(40*(i%10))
	        WIDTH  30
        	HEIGHT 20
	        FONTNAME "Arial"
        	FONTSIZE 9
	        VISIBLE .T.
	    END LABEL
NEXT i
jairpinho
Post by jairpinho »
edk wrote: Tue Sep 05, 2017 8:45 pm Hi.
        ROW    280
        COL    30
        WIDTH  100
        HEIGHT 28
        ACTION AddPict()
        CAPTION "Picture"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
        ROW    280
        COL    410
        WIDTH  100
        HEIGHT 28
        ACTION AddLabels()
        CAPTION "Labels"
        FONTNAME "Arial"
        FONTSIZE 9
        TOOLTIP ""
        FONTBOLD .F.
        FONTITALIC .F.
        FONTUNDERLINE .F.
        FONTSTRIKEOUT .F.
        ONGOTFOCUS Nil
        ONLOSTFOCUS Nil
        HELPID Nil
        FLAT .F.
        TABSTOP .T.
        VISIBLE .T.
        TRANSPARENT .F.
        MULTILINE .F.
        PICTURE Nil
        PICTALIGNMENT TOP
    END BUTTON
        Main.Center
        Main.Activate
FUNCTION addPict()
	PARENT Main
        ROW    30
        COL    60
        WIDTH  420
        HEIGHT 220
        PICTURE "img.jpg"
        HELPID Nil
        VISIBLE .T.
        STRETCH .T.
        ACTION Nil
    END IMAGE
Local i, cLabelName
FOR i=1 TO 100
	IF isControl
		PARENT Main
        	COL    60+(40*(i%10))
	        WIDTH  30
        	HEIGHT 20
	        FONTNAME "Arial"
        	FONTSIZE 9
	        VISIBLE .T.
	    END LABEL
NEXT i
Local i, cLabelName
FOR i=1 TO 100
		PARENT Main
        	COL    60+(40*(i%10))
	        WIDTH  30
        	HEIGHT 20
	        FONTNAME "Arial"
        	FONTSIZE 9
	        VISIBLE .T.
	    END LABEL
NEXT i
thank you edk worked perfect, I need now the label in the vertical position
Jair Pinho
Try with:
IsControlDefined ( Image_1 , Main )
without quotes in the names of controls and windows
jairpinho
Post by jairpinho »
srvet_claudio wrote: Wed Sep 06, 2017 2:49 am Try with:
edk works as Mr Claudio explained IsControlDefined (Image_1, Main)
Thank you Claudio
Jair Pinho
Because IsControlDefined () is pseudo-function
Should be
FUNCTION addPict()
IF IsControlDefined ( Image_1 , Main )
and
Local i, cLabelName
FOR i=1 TO 100
IF _IsControlDefined ( cLabelName , "Main")
jairpinho
Post by jairpinho »
Jair Pinho
I've created my own label control with vertical center option, but I haven't found method to create vertical orientated label.
Maybe Claudio or Grigory knows if it's possible.
Maybe try use Claudio's bos taurus.
IMO, this is possible only using graphics tools.
