Harbour MiniGUI Extended Edition build 17.08 is published
Hi Friends,
I am glad to announce a new version of Harbour MiniGUI Extended Edition.
A setup of the build 17.08 for Borland C++ 5.5.1 is published at
the following URL:
There are also an extra xHarbour.org-based archive for this build and
Minigui Ex build for the free Embarcadero C++ 10.1 Berlin compiler at
the Minigui's download page.
Note that there is a working Minigui demo for PageScript32 trial DLL at
http://hmgextended.com/files/MISC/ps32demo.zip
It is possible to prepare the Minigui Ex builds also for the following
C-compilers by your request:
- MinGW 7.1.0 32-bit and Harbour 3.4.0dev;
- MinGW 7.1.0 64-bit and Harbour 3.4.0dev;
- MS VisualC 2015 32-bit and Harbour 3.2.0dev;
- MS VisualC 2017 32-bit and Harbour 3.2.0dev;
- PellesC 8.0 and xHarbour 1.2.3 build 10204.
Thanks for your attention and support!
[MiniGUI Team]
Re: Harbour MiniGUI Extended Edition build 17.08 is published
Great! Thanks Grigory, very much!
BeGeS
Post by BeGeS »
Я радий привітати вас перший раз, пан Філатов.
Дякую за вашу роботу.
I am glad to congratulate you for the first time, Mr. Filatov.
Thank you for your work.
gfilatov wrote: Thu Aug 31, 2017 9:46 am Hi Friends,
Dear Grigory Filatov
Can you help us to convert ps32demo to HMG
bpd2000 wrote: Thu Aug 31, 2017 1:06 pm
Hi Dave,
What help you are need :?:
You can do it yoursselves. :o
There are the all needed sources in the MiniGUI Ex distribution. 8-)
You should write a config file .HBC for hbmk2 utility only.
BTW I have a working 64-bits PS demo for MinGW64 compiler also.
quartz565
Post by quartz565 »
Thank you Grigory !
Nikos.
os: Windows Server 2019 - 64
Great Grigory,
congratulation for new release.
best regards,
Luis Vasquez
hmgaams57
Post by hmgaams57 »
Many thanks Grigory! Great job as usual.
Said
Steed
Post by Steed »
Thanks
Anand
Post by Anand »
Great ! Thanks.
Anand
Anand
