IDE or manually write source?
bobgen
DBs Used: DBF, SQLite
Post by bobgen »
I'm a beginner at HMG and ask for advice: is it a recommendation to use IDE or manually write source?
I have a lot of experience with Clipper.
Thanks.
Re: IDE or manually write source?
IMO, it's better to use IDE if you want to quickly start.
Sometimes I need to define some forms manually, sometimes I need to add some controls to form defined via IDE.
dragancesu
DBs Used: DBF, MySQL, Oracle
Post by dragancesu »
Welcome to the world of HMG
Try it both ways, you'll see what's better. PersWelcome to the world of HMG
HMG has plenty clipper syntax but also many control windows that can be written in two ways, it's a little confusing beginners (like me). Try one, try the other way, so you see what you prefer, both are good, a matter of taste
Greeting
Welcome from India
bobgen wrote: Tue Jun 13, 2017 8:59 am is it a recommendation to use IDE or manually write source?
Hello,
There is not a strong claim to use IDE but it is a helpful tool for designing of your forms.
BTW You can place the controls on form manually as it's showed in the following sample code:
#include "minigui.ch"
STATIC Sys_BackColor
STATIC Sys_FontColor
Procedure Main()
LOCAL mNumLine
SET EPOCH TO Year(Date())-50
Sys_BackColor:= {255,255,255}
Sys_FontColor:= {  0,  0,  0}
DEFINE WINDOW Template01;
       AT 186,389;
       WIDTH 500;
       HEIGHT 600;
       TITLE 'Title';
       MAIN
   ON KEY ESCAPE ACTION thiswindow.RELEASE
   mNumLine:= 0
   @ mNumLine+=  10,  20 FRAME           FRAME_1  ;
                         CAPTION 'FRAME_1'   ;
                         WIDTH 340   ;
                         HEIGHT 390
   @ mNumLine+=  10, 380 BUTTONEX        BUTTONEX_1  ;
                         CAPTION '&Accept'   ;
                         PICTURE 'Aceptar16'   ;
                         WIDTH 100   ;
                         HEIGHT 25   ;
                         ACTION NIL   ;
                         TOOLTIP 'Accept current data'
   @ mNumLine+=  20,  50 LABEL           LABEL_1  ;
                         VALUE 'LABEL_1'   ;
                         WIDTH 100   ;
                         HEIGHT 15
   @ mNumLine+=   0, 170 GETBOX          GETBOX_1  ;
                         VALUE 'GETBOX_1'   ;
                         WIDTH 100   ;
                         HEIGHT 20   ;
                         BACKCOLOR Sys_BackColor   ;
                         FONTCOLOR Sys_FontColor
   @ mNumLine+=  20, 380 BUTTONEX        BUTTONEX_2  ;
                         CAPTION '&Cancel'   ;
                         PICTURE 'CANCELAR16'   ;
                         WIDTH 100   ;
                         HEIGHT 25   ;
                         ACTION NIL   ;
                         TOOLTIP 'Cancel current data'
   @ mNumLine+=  10,  50 LABEL           LABEL_2  ;
                         VALUE 'LABEL_2'   ;
                         WIDTH 100   ;
                         HEIGHT 15
   @ mNumLine+=   0, 170 GETBOX          GETBOX_2  ;
                         VALUE 'GETBOX_2'   ;
                         WIDTH 100   ;
                         HEIGHT 20   ;
Template01.CENTER
Template01.ACTIVATE
Note that above sample for using in the HMG Extended Edition only :oops:
Hi Bobgen,
Welcome from Belgium!
bobgen wrote: Tue Jun 13, 2017 8:59 am I'm a beginner at HMG and ask for advice: is it a recommendation to use IDE or manually write source?
Thanks.
Hi Bobgen
Welcome to wonderful world of HMG 8-)
My preference is almost always use IDE, unless requires manual intervention on my code, form(s) or building process.
Salute from Turkiye,
franco
Post by franco »
Welcome from Canada,
Franco
All The Best,
Franco
Canada
bobgen
Post by bobgen »
Thank you for the answers and good wishes.
I think I'm going to work in the IDE, and if necessary write the code manually. I've tried both variants and I do not have any problems.
Bobgen
hmgaams57
Post by hmgaams57 »
Welcome from Algeria
Said
