SET_HMGPATH
SET_HMGPATH
Hi all,
This application is to help you to SET (create or update) the variable environment HMGPATH.
Usefull for building proposes which contains where (Folder name. Full path) your HMG has been installed.
HMGPATH.rar
Executable and source files
(1.23 MiB) Downloaded 795 times
I hope it be useful. :)
Re: SET_HMGPATH
SET_HMPATH now is available. :)
I know we could improve this app specially at vbs routine when there are two procedure to execute.
I preferred to use in VBScript fue registry writing.
It's more safe. :)
Re: SET_HMGPATH
Nothing could be safe when played with registry :mrgreen:
Re: SET_HMGPATH
esgici wrote: Mon May 29, 2017 6:07 pm Nothing could be safe when played with registry :mrgreen:
I mean being "more" secure to change the registry with vbs than with Harbour, in my opinion.
You Esgici thinks that it is not "playing" with the registry of your Windows, but the own Windows and programs sometimes used by yourself make changes at all times...
This registry change routine is just to create an environment variable. ONLY.
So it is perfectly permissible. I do not see here anyone "playing" with the registry... :?
Does not your ramadan start today ?
So, you must remember that before throwing loose every muslim should practice (at least in these moments) deep brotherhood instead... :?
dragancesu
DBs Used: DBF, MySQL, Oracle
Re: SET_HMGPATH
Post by dragancesu »
Well done
Steed
Re: SET_HMGPATH
Post by Steed »
Thanks
asharpham
Re: SET_HMGPATH
Post by asharpham »
What does SET_HMGPATH actually do? Do I run it as an independant program or do I include it as a #include in my source files? I really am a beginner in this area.
Alan
