Little wizard for create controls
- dragancesu
IDE is a useful program but I do not like the result (prg + FMG) it rarely use
I see that many people use when they need to create a control and then to infiltrate program
I did something similar to create several controls so look
Program create test.prg , then copy-paste code into your program
- wizard.zip
- (36.73 KiB) Downloaded 405 times
Re: Little wizard for create controls
Thx Dragan !
Dragan,
In radio_wiz.prg LABEL lab_5 interferes with Radio_1. This makes it impossible to change from horizontal to vertical.
All labels are too long which makes mouse-pointing useless. Only TAB can change focus now.
- dragancesu
Thank you, I see problem but don't see solution
This how I do it:
Make labels temporary:
Then you will see where overlapses, then use correct WIDTH .. in order to avoid overlapse!
@ 50,50 LABEL lab_1 VALUE "START AT , " BACKCOLOR GREEN
When a label is too long (with same backcolor as form) it will overlapse edit/radio/etc. causing the above problems...
Thank you Dragan
Nikos.
os: Windows Server 2019 - 64
Nikos.
