GetFormHandle(FormName) etc...
KDJ
Post by KDJ »
h_windows.prg wrote:
Function GetFormHandle (FormName)
Local mVar , i
	mVar := '_' + FormName
	i:=&mVar
	if i == 0
		Return 0
Return ( _HMG_SYSDATA [ 67  ] [ &mVar ] )
If you pass to this function a not defined FormName, run-time error occurs.
You can to avoid run-time error by a little improving the function. For example:
  LOCAL mVar := '_' + FormName
  IF (Type(mVar) == "N") .and. (&mVar > 0)
    RETURN ( _HMG_SYSDATA [ 67  ] [ &mVar ] )
RETURN 0
The same applies to similar functions:
GetWindowType(FormName)
GetFormName(FormName)
GetFormToolTipHandle(FormName)
GetMenuToolTipHandle(FormName)
GetFormIndex(FormName)
GetControlIndex(ControlName, ParentForm)
GetControlName(ControlName, ParentForm)
GetControlHandle(ControlName, ParentForm)
GetControlContainerHandle(ControlName, ParentForm)
GetControlParentHandle(ControlName, ParentForm)
GetControlId(ControlName, ParentForm)
GetControlType(ControlName, ParentForm)
GetControlValue(ControlName, ParentForm)
GetControlPageMap(ControlName, ParentForm)
_GetControlRow(ControlName, ParentForm)
_GetControlCol(ControlName, ParentForm)
_GetControlWidth(ControlName, ParentForm)
_GetControlHeight(ControlName, ParentForm)
_GetControlObject(ControlName, ParentForm)
_PlayPlayer(ControlName, ParentForm)
_StopPlayer(ControlName, ParentForm)
_ClosePlayer(ControlName, ParentForm)
_DestroyPlayer(ControlName, ParentForm)
_EjectPlayer(ControlName, ParentForm)
Re: GetFormHandle(FormName) etc...
Thanks!
These are internal functions, it is the responsibility of the programmer to check the validity of the parameters, otherwise they generate responses type black boxes that are very difficult to debug.
KDJ
Post by KDJ »
Claudio, thanks for the explanation.
So we should write in this way:
IF _IsWindowDefined(cForm)
nHandle := GetFormHandle(cForm)
or
IF IsWindowDefined(&cForm)
It right
srvet_claudio wrote: Sun Jan 29, 2017 5:07 pm These are internal functions, it is the responsibility of the programmer to check the validity of the parameters, otherwise they generate responses type black boxes that are very difficult to debug.
Perfect Claudio.
+ Just my opinion +
I understand what colleague Krzysztof means and understand what Claudio says as well.
I think the two are right and that by default, the programmer uses _FunctionName() to denote that it is an internal function and that it is possibly subject to change. But at this point in our progress, making a change seems difficult to accept, probably also due main reason have to provide for backwards compatibility and this displays more code ...
We have to be aware in adding that many things have been created and improved over time. It is always necessary to decide whether such a change or any other change is worth the effort.
For my concept although the risk of using these "internal functions" is understandable. They are and are nothing more than one function to more in the system. Of course the "internal" type of function that requires care. Sometimes the procedure is not complete in direct use or/and are subject to change its functionality. For more one reason, the use of pseudo-function is great.
But to say (or think in it) that the user can not use (I do not say here is the case), I think it only requires precaution. Nothing else... :? :roll:
HMG was designed to be a high level language, so it is assumed that the use of advanced or low level functions are done by people who know in depth how Windows works and therefore it is the responsibility of the programmer to perform a defensive programming.
Where is "like" button ?
hmgchang
Post by hmgchang »
Dear Friends,
How to tell the different :
1. GetControlContainerHandle(ControlName, ParentForm)
2. GetControlParentHandle(ControlName, ParentForm)
3. Will it be 1=2 ?
TIA
Best rgds
Chang
Just Hmg It !
