PathCompactPath
PathCompactPath
e.g. "C:\Program...\Adobe"
The GRID headers give the same effect, but we do not have this function available to the user in HMG yet. :|
It would be useful as in these cases:
  1. Here is a solution: https://www.codeproject.com/articles/36 ... it-control
  2. In Minigui Extended there is another solution, like as this code:
    // Jacek Kubica <kubica@wssk.wroc.pl> HMG 1.1 Experimental Build 11a
    // cFile - string to be compacted (may be for example fullpath, path or file name)
    // nMax  - required string size (characters count)
    // _GetCompactPath("C:\Program Files\Adobe",20) -> "C:\Program...\Adobe"
    FUNCTION _GetCompactPath ( cFile, nMax )
    LOCAL cShort := Space( hb_IsNumeric( nMax, nMax + 1, 64 ) )
    Return iif( GetCompactPath( @cShort, cFile, hb_IsNumeric( nMax, nMax, 63 ), NIL ) > 0, cShort, cFile )
    // Grigory Filatov <gfilatov@inbox.ru> HMG 1.1 Experimental Build 11a
    typedef INT ( WINAPI * _GETCOMPACTPATH )( LPTSTR pszOut, LPTSTR pszSrc, INT cchMax, DWORD dwFlags );
    HB_FUNC( GETCOMPACTPATH )
       HINSTANCE handle = LoadLibrary( "shlwapi.dll" );
       if( handle )
          _GETCOMPACTPATH pFunc;
          pFunc = ( _GETCOMPACTPATH ) GetProcAddress( handle, "PathCompactPathExA" );
          hb_retni( pFunc( ( LPTSTR ) hb_parc( 1 ), ( LPTSTR ) hb_parc( 2 ), ( INT ) hb_parni( 3 ), ( DWORD ) hb_parnl( 4 ) ) );
          FreeLibrary( handle );
We would need to convert this code to UNICODE/ANSI and I imagine we need to use HMG_DEFINE_DLL_FUNC but I do not know how to adapt it to HMG. :oops:
IMHO, first option is better doing in pixels not in pixel considering GetFontSize. :?
I think it would be useful to have a solution where prevent texts from being truncated.
Re: PathCompactPath
Include the header file:
#include "Shlwapi.h"
and call direct the func:
PathCompactPath or PathCompactPathEx
see:
https://msdn.microsoft.com/en-us/librar ... s.85).aspx
PathCompactPath
So simple like that ?
I will check tomorrow. Really tired now for testing.
I got already before but I suppose to make it in ANSI mode... It's what I think.
Thank Claudio.
KDJ
Re: PathCompactPath
Post by KDJ »
This can be done without coding in C.
Example:
#include 'hmg.ch'
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  DEFINE WINDOW MainWA;
    MAIN;
    WIDTH  380;
    HEIGHT 230;
    TITLE  'Path Compact';
    NOMAXIMIZE;
    NOSIZE
    DEFINE LABEL PathLA
      ROW     10
      COL     10
      WIDTH  350
      HEIGHT  13
      VALUE  'Path to compact:'
    END LABEL
    DEFINE TEXTBOX PathTE
      ROW        25
      COL        10
      WIDTH     310
      HEIGHT     20
      MAXLENGTH 259
      VALUE     CurDir()
      ONCHANGE  CompactPaths()
    END TEXTBOX
    DEFINE BUTTON PathBU
      ROW      25
      COL     330
      WIDTH    30
      HEIGHT   20
      CAPTION '>>'
      ACTION  SetPath()
    END BUTTON
    DEFINE LABEL CompCharLA
      ROW     55
      COL     10
      WIDTH  350
      HEIGHT  13
      VALUE  'Compact path - length in characters:'
    END LABEL
    DEFINE TEXTBOX CompCharTE
      ROW        70
      COL        10
      WIDTH     310
      HEIGHT     20
      MAXLENGTH 259
      READONLY  .T.
      DISABLEDBACKCOLOR {224, 224, 224}
      ONGOTFOCUS SendMessage(MainWA.CompCharTE.HANDLE, 177 /*EM_SETSEL*/, 0, -1)
    END TEXTBOX
    DEFINE TEXTBOX CharsTE
      ROW         70
      COL        330
      WIDTH       30
      HEIGHT      20
      VALUE       30
      DATATYPE   NUMERIC
      RIGHTALIGN .T.
      INPUTMASK  '999'
    END TEXTBOX
    DEFINE LABEL CompPixLA
      ROW    100
      COL     10
      WIDTH  350
      HEIGHT  13
      VALUE  'Compact path - length in pixels:'
    END LABEL
    DEFINE TEXTBOX CompPixTE
      ROW       115
      COL        10
      WIDTH     310
      HEIGHT     20
      MAXLENGTH 259
      READONLY  .T.
      ONGOTFOCUS SendMessage(MainWA.CompPixTE.HANDLE, 177 /*EM_SETSEL*/, 0, -1)
    END TEXTBOX
    DEFINE TEXTBOX PixelsTE
      ROW        115
      COL        330
      WIDTH       30
      HEIGHT      20
      VALUE      120
      DATATYPE   NUMERIC
      INPUTMASK  '999'
      RIGHTALIGN .T.
    END TEXTBOX
    DEFINE LABEL CompWndLA
      ROW    145
      COL     10
      WIDTH  350
      HEIGHT  13
      VALUE  'Compact path to control width:'
    END LABEL
    DEFINE TEXTBOX CompWndTE
      ROW       160
      COL        10
      WIDTH     310
      HEIGHT     20
      MAXLENGTH 259
      READONLY  .T.
      ONGOTFOCUS SendMessage(MainWA.CompWndTE.HANDLE, 177 /*EM_SETSEL*/, 0, -1)
    END TEXTBOX
    DEFINE TEXTBOX WidthTE
      ROW        160
      COL        330
      WIDTH       30
      HEIGHT      20
      VALUE      160
      DATATYPE   NUMERIC
      INPUTMASK  '999'
      RIGHTALIGN .T.
      ONCHANGE   (MainWA.CompWndTE.WIDTH := If(MainWA.WidthTE.VALUE < 0, 0, MainWA.WidthTE.VALUE), CompactPaths())
    END TEXTBOX
    ON KEY ESCAPE ACTION MainWA.RELEASE
  MainWA.CENTER
  MainWA.ACTIVATE
FUNCTION SetPath()
  LOCAL cPath := GetFile()
  IF ! Empty(cPath)
    MainWA.PathTE.VALUE := cPath
FUNCTION CompactPaths()
  IF IsControlDefined(CompCharTE, MainWA)
    MainWA.CompCharTE.VALUE := GetCompactPathChar(MainWA.PathTE.VALUE, MainWA.CharsTE.VALUE)
  IF IsControlDefined(CompPixTE, MainWA)
    MainWA.CompPixTE.VALUE := GetCompactPathPix(MainWA.PathTE.VALUE, MainWA.PixelsTE.VALUE, MainWA.CompPixTE.HANDLE)
  IF IsControlDefined(CompWndTE, MainWA)
    MainWA.CompWndTE.VALUE := GetCompactPathWnd(MainWA.PathTE.VALUE, MainWA.CompWndTE.HANDLE)
FUNCTION GetCompactPathChar(cPath, nChars)
  LOCAL cPathComp
  IF ++nChars < 0
    nChars := 0
  cPathComp := Space(nChars)
RETURN If(HMG_CallDLL('Shlwapi.dll', 0, 'PathCompactPathEx', @cPathComp, cPath, nChars, NIL) == 0, cPath, cPathComp)
FUNCTION GetCompactPathPix(cPath, nPixels, nHWnd)
  LOCAL nHDC   := GetDC(nHWnd)
  LOCAL nHFont := HMG_CallDLL('Gdi32.dll', 0, 'SelectObject', nHDC, SendMessage(nHWnd, 49 /*WM_GETFONT*/, 0, 0))
  IF nPixels < 0
    nPixels := 0
  HMG_CallDLL('Shlwapi.dll', 0, 'PathCompactPath', nHDC, @cPath, nPixels)
  HMG_CallDLL('Gdi32.dll', 0, 'SelectObject', nHDC, nHFont)
  ReleaseDC(nHWnd, nHDC)
RETURN cPath
FUNCTION GetCompactPathWnd(cPath, nHWnd)
RETURN GetCompactPathPix(cPath, GetClientAreaWidth(nHWnd), nHWnd)
//#pragma BEGINDUMP
//  #include "SET_COMPILE_HMG_UNICODE.ch"
//  #include "HMG_UNICODE.h"
//  #include <windows.h>
//  #include <shlwapi.h>
//  #include "hbapi.h"
//  //this function does not work, error while linking: undefined reference to `_imp__PathCompactPathW@12'
//          //PathCompactPix(cPath, nPix, nHWnd)
//  HB_FUNC ( PATHCOMPACTPIX )
//    LPTSTR lpszPath = (LPTSTR) HMG_parc (1);
//    UINT   dx       = (UINT)   hb_parni (2);
//    HWND   hWnd     = (HWND)   HMG_parnl(3);
//    HDC    hDC      = GetDC(hWnd);
//    HFONT  hFont    = SelectObject(hDC, (HFONT) SendMessage(hWnd, WM_GETFONT, 0, 0));
//    PathCompactPath(hDC, lpszPath, dx);
//    SelectObject(hDC, hFont);
//    ReleaseDC(hWnd, hDC);
//    HMG_retc(lpszPath);
//#pragma ENDDUMP
PathCompactPath
WOW Krzysztof ! Image
Wonderful I did not imagined by this time that we can use DLL. This is thanks to HMG_CallDLL function enhancement fixed by Claudio and that you man were able to use wisely.
Thank you Krzysztof !
I've been busy preparing other types of examples today (very nice ones about UAC) and I could not see this question of CompactPath yet upto now.
But in the bathroom in the shower, last night (where ideas come up), I imagined using the second parameter as optional (to use or not) for the user. User can enter the numeric value or leave it not informed. In this way the function would automatically find the maximum value conform the width of the container. By testing incrementally figure until the maximum value is reached in the container. But this would be one more improvement that we could implement. Probably I will do tomorrow (know I'm gonna to the dancing club).
However these functions deserve to be in the core of HMG and this example in the SAMPLES for next HMG release in my opinion. Claudio and Rathi please kindly you consider it a contribution and an excellent resource to avoid text truncations in containers that do not fit everything.
Congratulations Krzysztof and thank you very much for your contribution. Thanks a lot to you Claudio for the tip and work in HMG_CallDLL and all your job around in HMG.
Best regards
PD.: I've tested with changing of FONTNAME and FONTSIZE (to Courier New) and worked perfectly. What the another first examples were not correct.
Re: PathCompactPath
Thanks Pablo and Krzysztof !
Should indeed be in the core of HMG !
KDJ
Re: PathCompactPath
Post by KDJ »
It turns out that the compiler does not automatically enable to link the library "shlwapi".
You have to do it manually, eg. in .hbp file:
-lshlwapi
and all works right.
So I can now write another version of functions GetCompactPathChar and GetCompactPathPix - coding in C instead of using HMG_CallDLL.
This should work faster.
PathCompactPath
Krzysztof wrote:It turns out that the compiler does not automatically enable to link the library "shlwapi".
-lshlwapi
:shock:
I did not know there was this lib in Harbour. I searched and only found it as DLL.
Please feel free, we would like to have this function. Very useful and follows the pattern so that there are no truncations with this function.
Ddziękuję Krzysztof ! :P
KDJ
Re: PathCompactPath
Post by KDJ »
Pablo César wrote: Sun Jan 15, 2017 7:05 pm
-lshlwapi
:shock:
Pablo
This library is in C compiler (MinGW) named "libshlwapi.a".
