Wrapper for LIBXL libxlsxwriter.dll for Harbour
I wanted to test it, but still have no time...
Re: Wrapper for LIBXL libxlsxwriter.dll for Harbour
Thank Serge for sharing link
Mol
I have tested and working fine
Setp:
1. create path for Harbour as usual
2. you need some .ch files [attached herewith] put all the files in example folder
3. to compile I used command "hmbk2 demo example.hbp
4. run the compiled file
Mol
Setp:
- required_ch_files.rar
- required .ch files
- (30.68 KiB) Downloaded 635 times
Hi BPD,
Can you please share your test.PRG also?
Thx, Serge
Thx, Serge
Sir,serge_girard wrote: ↑Fri Jan 13, 2017 1:30 pm Hi BPD,
Thx, Serge
I had tested all .prg located at \hblibxlsxwriter-master\example, it is with you
oops...
Hi BPD,bpd2000 wrote: ↑Fri Jan 13, 2017 12:44 pm Thank Serge for sharing link
Mol
Setp:
I am trying to complie the demo.prg according to your instruction, but it never come out the "exe" file. I don't know what's wrong. listed below is my example.hbp file, could you take a look to it? Thanks.
xhb.hbc
-lhblibxlsxwriter
-w2 -es2 -iD:\hblibxlsxwriter\include -lhblibxlsxwriter
And I used following commands to complie the demo.prg
PATH=D:\hmg.3.4.4\HARBOUR\bin;D:\hmg.3.4.4\MINGW\bin
hbmk2 demo.prg example.hbp
Ha HA, I found what's wrong, I removed the " -lhblibxlsxwriter " from -w2 -es2 -iD:\hblibxlsxwriter\include -lhblibxlsxwriter and it is OK now.Tiger wrote: ↑Fri Apr 10, 2020 10:43 amHi BPD,bpd2000 wrote: ↑Fri Jan 13, 2017 12:44 pm Thank Serge for sharing link
Mol
Setp:
xhb.hbc
-lhblibxlsxwriter
Attached working folder
Unzip in c drive
set required path for harbour and mingw compiler
go example and run test.cmd
Unzip in c drive
- hblibxlsxwriter.zip
- (1.08 MiB) Downloaded 341 times
