CheckBox Centered and Multiline text
Hi all,
When more available space is not enough for text in CheckBoxes and as default in one line the text is cutted off... :?
We can use this:
#define BS_MULTILINE         8192
#define BS_CENTER            768
Function Main()
DEFINE WINDOW Demo AT 426, 890 WIDTH 215 HEIGHT 256 TITLE "CheckBox Multiline" MAIN NOMAXIMIZE NOMINIMIZE NOSIZE
    DEFINE CHECKBOX Check_1
		ROW    25
        COL    30
        WIDTH  150
        HEIGHT 42
        CAPTION "CheckBox Centered and Multine Item"
        VALUE .F.
        FONTNAME "Arial"
        FONTSIZE 9
		FONTBOLD .T.
		BACKCOLOR {180,180,180}
        FONTCOLOR {128,0,0}
		TRANSPARENT .F.
    END CHECKBOX
	DEFINE CHECKBOX Check_2
	    ROW    95
        COL    30
        WIDTH  150
        HEIGHT 42
        VALUE .F.
        FONTNAME "Arial"
        FONTSIZE 9
		FONTBOLD .T.
        FONTCOLOR {128,0,0}
		TRANSPARENT .F.
    END CHECKBOX
	DEFINE CHECKBOX Check_3
	    ROW    165
        COL    30
        WIDTH  150
        HEIGHT 42
		CAPTION "CheckBox Centered "+CRLF+"   and Multine Item"
        VALUE .F.
        FONTNAME "Arial"
        FONTSIZE 9
		FONTBOLD .T.
        FONTCOLOR {128,0,0}
		TRANSPARENT .F.
    END CHECKBOX
Demo.Center
HMG_ChangeWindowStyle ( GetControlHandle("Check_2","Demo"), BS_MULTILINE+BS_CENTER, NIL, .F. ) // MULTILINE
HMG_ChangeWindowStyle ( GetControlHandle("Check_3","Demo"), BS_MULTILINE+BS_CENTER, NIL, .F. ) // MULTILINE
Demo.Activate
I hope this would be useful for you and be for fan. :D
Re: CheckBox Centered and Multine text
Thanks Pablo !
quartz565
Post by quartz565 »
Thank you Pablo !
Nikos.
os: Windows Server 2019 - 64
Nice, thank you Pablo !
Anand
Re: CheckBox Centered and Multiline text
Post by Anand »
Really useful when needed. Thanks Pablo.
BTW can we have "Copy" along with "Select ALL" for code ? You see one has to right click and copy each time, so a direct copy to clipboard will be very useful. I have seen it in some forums though, so there must be a way for it.
Anand
Anand
Thank you all for your expressed interest in this topic.
Glad to know it will be useful to you. :)
Anand wrote:BTW can we have "Copy" along with "Select ALL" for code ? You see one has to right click and copy each time, so a direct copy to clipboard will be very useful. I have seen it in some forums though, so there must be a way for it.
Hi Anand,
I'm not sure what you're talking about: whether it's the CheckBox or the forum editing features regarding your question about "Select ALL". :?
1. If your question is about CheckBox. It has a way to put the text of each item in the ClipBoard, but this the user can do and in several ways.
2. If your question is about the forum features. Note that to select the whole code and copy it to the clipboard just click on "SELECT ALL" and then with the right mouse click on the selected text and with left click on the "Copy" option.
But this last, if is this your case and I also agree with you to have an extra option or modified option, you should post it at Forum help, right ?
Then your question may be responded by Mr. Rathinagiri.
Sorry to tell you but this makes confusions... :oops:
Post by EduardoLuis »
Hi Pablo:
First your experiment is excellent, very very usefull.-
I've test mergin both of your checkbox new properties:
Center and multiline with left text alligment and works fine (perfect).-
Thanks for share.-
Eduardo
trmpluym
Post by trmpluym »
Thanks Pablo,
Very usefull...
Theo
Anand
Post by Anand »
Pablo César wrote:2. If your question is about the forum features. Note that to select the whole code and copy it to the clipboard just click on "SELECT ALL" and then with the right mouse click on the selected text and with left click on the "Copy" option.
Thanks Pablo, yes I meant that.
I have posted the same in "Forum Help" Sorry for the confusion.
Anand
Anand
You're welcome guys.
Anand wrote:I have posted the same in "Forum Help" Sorry for the confusion.
Good man, Maybe Rathinagiri can do something to improve this.
