window release method compile error
I must have a fundamental problem understanding methods.
I want to release a window then go back to a previous one. In the code below, why does the build give me a syntax error
at either the hide or release command at the end. Form_1 is the destination after leaving form_3
FUNCTION BackToInputScreen //called from SelectInput
Form_1.setfocus
if lUseTestData //
xDummy:=ScanToFillBlanks(.f.)
Form_1.ebox_1.visible:=.T. //get numbers
Form_1.ebox_1.setfocus
Form_1.Lbl_3.visible:= .T. //instructions
Form_1.startbutton.visible:= .F.
Form_1.updatearray.visible:= .T.
Form_1.updatearray.setfocus
//Form_3.hide
Form_3.release
Form_1.setfocus
if lUseTestData //
//Form_3.hide
Form_3.release
Re: window release method compile error
It's impossiple to analyze your code without complete sample.
To Mol
The complete code is way too big
The HMG reference for the release method just says that <windowname>.release will close it
That sounds simple but it is not happening on the last line either for Hide or release.
Is there anything else that any user should know about using a method?
Thanks
Thanks
Try to declare window by
Paste error message here, too.
declare window Form_3
Hi Bluebird,
Maybe a small part of the program will be sufficient to understand the problem?
Thanks to those kind souls who responded
error is Error E0030 syntax error " Syntax error at '.'"
Code below shows window Form_3 and function called to exit back to Form_1
FUNCTION SELECTINPUT() //Called from Startup Button
If !IsWindowDefined(Form_3)
DEFINE WINDOW Form_3 ;
AT 290,290 ;
WIDTH 400 ;
HEIGHT 300 ;
BACKCOLOR GREEN ;
TITLE "Choices"
@ 50 ,100 BUTTON Button_1 ;
PARENT Form_3;
CAPTION "Click to Use Set Values" ;
ONCLICK {||(lUseTestData:=.t.,BackToInputScreen())} ;
WIDTH 200 ;
FONT "Arial" SIZE 12 ;
HEIGHT 35
@ 100 ,100 BUTTON Button_2 ;
PARENT Form_3;
CAPTION "Click to enter New Values" ;
ONCLICK {||(lUseTestData:=.f.,BackToInputScreen())} ;
WIDTH 200 ;
HEIGHT 35
ACTIVATE WINDOW Form_3
Else
Form_3.setfocus
Endif
FUNCTION BackToInputScreen() //called from SelectInput
Form_1.setfocus
if lUseTestData //
Form_1.DisplayClues.visible:= .T.
Form_1.DisplayClues.setfocus
//Form_3.hide
Form_3.release
AT 290,290 ;
WIDTH 400 ;
HEIGHT 300 ;
BACKCOLOR GREEN ;
TITLE "Choices"
PARENT Form_3;
WIDTH 200 ;
HEIGHT 35
PARENT Form_3;
WIDTH 200 ;
HEIGHT 35
Else
Form_3.setfocus
Endif
Form_1.setfocus
if lUseTestData //
//Form_3.hide
Form_3.release
try to build whole complete working sample. Respect our time, please...
- dragancesu
Can you zip files and attach?
Hello Bluebird,
Extremly difficult without main function. I tried to make the main function myself (as simple as possible) and it seems working.
See below:
See below:
DEFINE WINDOW Form_1 ;
AT 0,500 ;
WIDTH 1300 ;
HEIGHT 850 ;
TITLE 't' ;
BACKCOLOR SILVER;
MAIN ;
ON INIT SELECTINPUT();
ACTIVATE WINDOW Form_1
//lUseTestData := .f.
AT 290,290 ;
WIDTH 400 ;
HEIGHT 300 ;
BACKCOLOR GREEN ;
TITLE "Choices"
PARENT Form_3;
WIDTH 200 ;
HEIGHT 35
PARENT Form_3;
WIDTH 200 ;
HEIGHT 35
Else
Form_3.setfocus
Endif
Form_1.setfocus
if lUseTestData //
xDummy:= '' //ScanToFillBlanks(.f.)
//Form_1.ebox_1.visible:=.T. //get numbers
//Form_1.ebox_1.setfocus
//Form_1.Lbl_3.visible:= .T. //instructions
//Form_1.startbutton.visible:= .F.
//Form_1.DisplayClues.visible:= .T.
//Form_1.DisplayClues.setfocus
//Form_3.hide
Form_3.release
Hi BlueBird ....
IF !IsWindowDefined( Stock ) ..... You Form_3
Load Window .\Formularios\Stock
ON KEY SHIFT + DELETE OF Stock ACTION .......
ON KEY F3 OF Stock ACTION ......
DesactivarEdicion()
ConectarStock( .T. )
Stock.Activate
Else
Stock.Restore
Stock.Setfocus
EndIf
