After learning quite a lot of the programming basics and writing some none data programs, I need now to create my own xbase DBF file.
Does HMG have of know a create utility that a reader could recommend?
Thanks all
Creating your first dbf file
Re: Creating your first dbf file
Have you tried (from within IDE) selecting the menu items "Project" then "New Table"?
It's been a while since I used it, but I do remember that it worked.
Personally, I still prefer using dBaseIII to create .dbf files, but maybe you don't have a copy?
Good luck!
Good luck!
Do you mean whole database system, with a lot of tables, indexes realtions or creating one .dbf file?
If first, you need to study a lot of creating relation databases.
If second, you can use dbu.exe with a lot of variations of this tool.
You can create dbf file by DBCreate function:
(hmg\samples\advanced\memory_tables\demo.prg)
Function CreateTable
DBCREATE("mem:test", {{"CODE", "C", 3, 0},{"NAME", "C", 50, 0},{"RESIDENTS", "N", 11, 0}},, .T., "memarea")
DBAPPEND()
REPLACE CODE WITH 'LTU', NAME WITH 'Lithuania', RESIDENTS WITH 3369600
DBAPPEND()
REPLACE CODE WITH 'USA', NAME WITH 'United States of America', RESIDENTS WITH 305397000
DBAPPEND()
REPLACE CODE WITH 'POR', NAME WITH 'Portugal', RESIDENTS WITH 10617600
DBAPPEND()
REPLACE CODE WITH 'POL', NAME WITH 'Poland', RESIDENTS WITH 38115967
DBAPPEND()
REPLACE CODE WITH 'AUS', NAME WITH 'Australia', RESIDENTS WITH 21446187
DBAPPEND()
REPLACE CODE WITH 'FRA', NAME WITH 'France', RESIDENTS WITH 64473140
DBAPPEND()
REPLACE CODE WITH 'RUS', NAME WITH 'Russia', RESIDENTS WITH 141900000
- By IDE (as CalScot said). If you want to see a step-by-step, Esgici did a good job on his site:
Https://vivaclipper.wordpress.com/2013/ ... b-manager/
By the way, Rathi/Claudio. Is it possible to be included this contain (of course if Esgici permits to use his material) in our HMG doc ?
- Manually (as Marek said): inside your PRG.
- Using the old DBU / dBase or any other edit DBF utility.
Here's under list:
viewtopic.php?t=4082
viewtopic.php?t=209
viewtopic.php?t=4304
http://www.pctoledo.com.br/forum/fileba ... t=c&page=1
http://www.pctoledo.com.br/forum/fileba ... t=c&page=3
Everything in VivaClipper is public domain; no permission required for any kind of use....if Esgici permits to use his material in our HMG doc ?
...[*]Using the old DBU / dBase or any other edit DBF utility.
Here's under list:
http://hmgforum.com/viewtopic.php?f=10&t=42
and last release.
Viva HMG
- dragancesu
