IDE - Open project and not even release when it is closed
FOLDER's project is not releasing
Hi Claudio,
When we open a project by IDE is not releasing it. I do not exactly if is an open file with name of folder (without extension file) or if it's the folder one.
You can make this test:
1. Create a folder for new project.
1. Open a new project at IDE. Could it be without any changing.
2. Close the project at IDE.
3. Go to Windows Explorer and try to delete folder where the project had created. You will not able to eliminate the folder upto you change by open a existing project or upto IDE be terminated.
I saw a process at Resource Monitor by the executing the resmon.exe and the IDE it leaves open a process even project is closed or supposed to be closed. :?
I do not know what this can affect without this releasing... but this is not correct. The test described says that.
Re: Open project and not even release when it is closed
I will check.
DBF is not releasing
Hola Claudio, más un error similar durante la ejecucion de la IDE...
Es el mismo caso que el problema anterior, pero en esta vez es cuando abrimos un archivo REPORT (RMG) a través del "HMG Report Builder" y que precisa abrir el archivo DBF. La IDE que tendria que liberar el uso de este archivo cuando la edición está terminada, no lo hace. Ni tampoco mismo cerrando el proyecto ...  :evil:
Abrir, usar y "liberar" (este último) no es la característica más fuerte de nuestro IDE.   :mrgreen:
No libera el DBF y las carpetas/archivos hasta que finalmente se encierra la IDE.   :shock:
Realmente me gusta usar el IDE pero confieso que a veces me deja frustrado por no encontrar lo que pudiera haberme salido mal en mi proyecto... y que por causa de esos defectos hacen a cualquiera se ponga loco...  :|
Googled
Hi Claudio, more one similar error during the execution of the IDE...
Is the same case than previous problem reported, but this time when we open a REPORT (RMG) file through the "HMG Report Builder" and when needs to open DBF file. The IDE would have to release the use of this DBF file when the edit is finished, it does not. Nor even closing the project... :evil:
Open, use and "release" (this last one) is not the stronger-feature of our IDE.   :mrgreen:
It does not release the DBF and folders/files until it finally closes the IDE.   :shock:
I really like to use the IDE but I confess that sometimes it leaves me frustrated for not finding what could have gone wrong in my project ... and that because of those flaws make anyone go crazy...  :|
Re: IDE - Open project and not even release when it is closed
I will check
Please Claudio.
Thank you.
It happen again with me this DBF not been released at HMG Report Builder...
I'm pissed off with that !!! :evil: :evil:
I missed a huge time with a colleague who opened this feature at IDE.
It opened, showed the fields and finish report accordingly DBF normally but did not release the DBF anymore.
Does not close the DBF, normally. Image
IDE only closes when you finish execution of IDE... :o :shock: :?
Does not release even closing the project... :evil: :evil: :evil: :evil: :o :x
Otherwise it is open and if by chance we need to delete the DBF file, open in EXCLUSIVE mode, it does not leave because IDE does not release ... Damn!
A lot of time lost for nothing...
This must be fixed or DO NOT USE IT !!!
The same happen regarding FOLDER project. Even project been closed, do not release properly the folder's project.
You can try to open a new project, close and try to rename the folder's project: you will not ! :evil:
Only if you close the IDE, then it is posible to handle your folders... Image
