IDE fatal error at loading form
Hi Claudio,
This is to inform you that this error is occurring when trying to open Form2.
What is the difference of these two forms:
DEFINE WINDOW TEMPLATE AT 345, 485 WIDTH 550 HEIGHT 350 VIRTUAL WIDTH Nil VIRTUAL HEIGHT Nil TITLE "Demo" ICON NIL
DEFINE WINDOW TEMPLATE AT 345, 485 WIDTH 550 HEIGHT 350 VIRTUAL WIDTH NIL VIRTUAL HEIGHT NIL TITLE "Demo" ICON NIL
Only Nil is acepted not NIL.
This behaviour is it normal :?:
Please load Main project at your IDE and try to open Form2:
IDE_Error.rar
Main project
(674 Bytes) Downloaded 317 times
This error causes the collapse of running of the IDE :o
Re: IDE fatal error at loading form
Thank for report.
Dear Claudio, Sorry Claudio maybe my question would seem unnecessary, but I'd really like to know: would it be easy for you to correct it ? And you would standardize that in xBase dialect language (working with non-sensitive case) ?
Because how we will know when to use Nil (camel case) or when in NIL (all capital letters).
Ok, I will fixed
Many thanks Claudio
Not wanting to abuse your goodwill but since incidentally I could ask you another favor before you compile?
It is quite simple. Double-quote the call of Build.bat %1 "%2", so that we could compile with the IDE in named user_projects folders that contain spaces. Can be ? I assure you that that will not bring problems of retrocompatibility and nor in future. From what I saw in the executable editor there are only 4 mentions and only one with Build.bat %1 "%2". Maybe it will not be so laborious. :oops:
Muchas gracias Claudio
No queriendo abusar de tu buena voluntad pero dicho sea de paso, podria pedirte otro favor antes que compiles ?
Es algo bien simples. Colocar entre aspas duplas el llamado del Build.bat %1 "%2", asi de esta forma podríamos compilar con el IDE en carpetas de nuestros projectos con nombre que contengan espacios. Puede ser ? Te aseguro que eso no trairá problemas de retrocompatibilidad ni futuro. Por lo que vi en el editor de ejecutables hay solo 4 menciones y solo uno con Build.bat %1 "%2". Talvez no te sea tan laborioso. :oops:
