CheckBox with text aligned to left side
Hi all,
Normally (by default) we have CheckBox texts aligned to the right side of clickable box but when we need to align text to left you can do it changing its style making in this way:
#define BS_LEFTTEXT      0x00000020
Function Main()
DEFINE WINDOW Drives AT 426, 890 WIDTH 288 HEIGHT 166 TITLE "CheckBox Left Text" MAIN
    DEFINE CHECKBOX Check_1
		ROW    30
        COL    30
        WIDTH  210
        HEIGHT 28
        CAPTION " CheckBox with text on the RIGHT"
        VALUE .F.
        FONTNAME "Arial"
        FONTSIZE 9
		FONTBOLD .T.
		BACKCOLOR {180,180,180}
        FONTCOLOR {128,0,0}
		TRANSPARENT .F.
    END CHECKBOX
	DEFINE CHECKBOX Check_2
	    ROW    70
        COL    30
        WIDTH  210
        HEIGHT 28
		CAPTION " CheckBox with text on the LEFT"
        VALUE .F.
        FONTNAME "Arial"
        FONTSIZE 9
		FONTBOLD .T.
        FONTCOLOR {128,0,0}
		TRANSPARENT .F.
    END CHECKBOX
Drives.Center
HMG_ChangeWindowStyle ( GetControlHandle("Check_2","Drives"), BS_LEFTTEXT, NIL, .F. ) // LEFTJUSTIFY
Drives.Activate
I hope this would be useful for you. :)
Just for fan. :D
Re: CheckBox with text aligned to left side
Thank you Claudio!
It's useful for me, I was using empty caption of checkbox and label on the left to realize this till now.
This solution should be included in HMG and IDE, I think...
Muy Bueno !!!
Thank you Mustafa.
mol wrote:Thank you Claudio!
His a good fellow but I'm not... :lol:
mol wrote:It's useful for me, I was using empty caption of checkbox and label on the left to realize this till now.
Good to know being useful. For me it is also sometimes... at the moment I will use for HMG version installed (InstalledAt app) and searching others drives, as Serge has noted.
I imagined that more work to make empty CheckBox and adding Labels, postioning, color, so on...
mol wrote:This solution should be included in HMG and IDE, I think...
Yes it's strange not having in HMG. At HMG Extended, there is LEFTJUSTIFY property which set in that way.
Pablo César wrote:Thank you Mustafa.
Sorry Pablo for renaming you for Claudio.... :-D
I have very busy days now.
Thanks again for this solution!
New name
mol wrote:Sorry Pablo for renaming you for Claudio.... :-D
:lol:
No problem man. It's ok.
Claudio is a gentleman as many here around...
Post by EduardoLuis »
Hi Pablo
Very usefull. Thanks for share.-
With regards
Eduardo
Hola Pablo:
Muy util. Gracias por compartirlo.-
Cordialmente
Eduardo
quartz565
Post by quartz565 »
Thank you Pablo !!!
Nikos.
os: Windows Server 2019 - 64
