IDE Blocks Enter key
mol wrote:Can somebody do the test:
Press F5 to compile and run project, ant try use ENTER key in another application: eg editor
Tested and confirmed :(
While IDE running in building process, ENTER key doesn't work anywhere, including editors and Windows Explorer, until IDE complete building process.
XP SP2, HMG 2.9.2 ( FTIV), IDE 2.8.6.f
Re: IDE Blocks Enter key
Thanks.
I'll review it ASAP.
And...
The error reported by MOL (List_2 of Win_1 not defined...) appears to be related with this.
If you press [Enter] key in another app during compilation and, when compilation finish, the application is at foreground, that error, arises.
This will be very funny to fix bug :)
Roberto Lopez wrote:
And...
Very interesting :o
May God give facility to you :!:
Best Regards
And...
Very interesting :o
Best Regards
It appears to be not an IDE bug, but an HMG bug.
The 'guilty' command appears to be EXECUTE ... WAIT used to run a .bat file to build app in IDE.
EXECUTE command calls 'WaitRunPipe' (contribution) function.
Anyway, I should do more tests to be completely sure.
Hi Maestro
Is there anything we can do; f.e. some specific tests ?
Best Regards
esgici wrote:Hi Maestro
Best Regards
Yes, of course.
Any sample reproducing the problem as in IDE could be very useful to confirm the bug in EXECUTE command.
Hi Maestro
Roberto Lopez wrote: Any sample reproducing the problem as in IDE could be very useful to confirm the bug in EXECUTE command.
Sorry, I couldn't found any clue for confirmation :(
But I had succeed reproduce the error in a obscure way :
I have a big ( in source size ) project : up to 40 .prg, 40 .fmg, some .ch files, total up to 29.000 lines.
When issued build command in IDE after resetting project incremental data, the enter key disabled for all applications running and ( after a long building time ) the error occurs :
Date:2009.06.02 Time: 17:07:45
Error: Harbour MiniGUI 2.8.9 (2009.04.30)
Control: LIST_2 Of Win_1 Not defined. Program Terminated
Called from DOMETHOD(7402)
Called from BUILDPROJECT(39502)
Called from (b)HMGMAKE(38895)
Called from _PROCESSINITPROCEDURE(4519)
Called from _ACTIVATEWINDOW(4343)
Called from HMGMAKE(39121)
Called from BUILDPROJECTM(36208)
Called from RUNAPPLICATION(30972)
Called from (b)MAIN(878)
Called from _DOCONTROLEVENTPROCEDURE(4680)
Called from EVENTS(1360)
Called from _DOMESSAGELOOP(0)
Called from _ACTIVATEWINDOW(4322)
Called from MAIN(1297)
This is identical with Marek introduced. And other symptoms are similar : the target .exe builded and running as expected.
The worse is all this symptoms aren't absolute, under some UNDETERMINED conditions; such as other applications running same time with IDE :(
If you want I can send you that project files for testing.
Does this article may give a clue ?
http://support.microsoft.com/kb/933662
Best Regards
In my project, saving all forms from IDE was helpful. Try to open and save all forms from IDE.
So, it's strange that program runs well, and IDE runs without errors while incremental compilation, and crashes after full compilation.
mol wrote:In my project, saving all forms from IDE was helpful. Try to open and save all forms from IDE.
I guess I've determined the precise condition to reproduce the problem.
As I've said, it is not IDE specific, but an HMG problem.
When your application reaches EXECUTE...WAIT command and THERE ARE ON KEY definitions active, the HMG appplication will still capturing keys and process it when the EXECUTE...WAIT returns control to the application.
I've fixed IDE, releasing key prior to calling EXECUTE command and call it again later.
Anyway, I'll still researching to fix EXECUTE command.
