Translate, again
Source code related resources
dragancesu
DBs Used: DBF, MySQL, Oracle
Translate, again
Post by dragancesu »
This forum is world's, I do not know from how many countries are members, but I see that coming new every day
Examples of the program are short and every single function, there are only a few applications. Is that enough for beginners do not know, but I think it needs a few more complete examples that include menus, forms and reports. I attached one (already seen).
An example is in English, but there are also following that has translated into my language, Serbian. Translation is in the folder lang and there are files with translation
The following program is nlsedit which serves to make the necessary. There are three steps,
analysis of the program - reads strings in programs,
changes - allows input translation, and
save finally translate
When there is a LINE shift and tell translation
LINE 0 is reserved for the name of the language, so it will be called files
LINE <0 is reserved for comments
The programs i18n.prg features that are necessary
nls_init - at the beginning of
nls_select - language selection
nls_lang - to display the translation
Finaly, strings you want to translate replace it with a translation nls_lang (n)
It looks like this
         DEFINE POPUP nls_lang(4)  // date
            MENUITEM nls_lang(5)                          ACTION edit_cost() // costs
            MENUITEM nls_lang(6)                        ACTION edit_pay() // payment
            MENUITEM nls_lang(7)               ACTION md_cost() // costs and payment
            SEPARATOR
            MENUITEM nls_lang(8)                           ACTION MainForm.Release // exit program
         END POPUP
What I do need is a change of code page
For the next language is sufficient editor, so I'll ask the members of good will to do the translation for your language and leave it on the forum
Regards to all
demo1.zip
english version
(33.87 KiB) Downloaded 326 times
demo2.zip
with translate
(38.95 KiB) Downloaded 350 times
nls.zip
NLSeditor
(21.36 KiB) Downloaded 331 times
Re: Translate, again
Thanks Dragan,
I can make the dutch translation.
tonton2
Post by tonton2 »
Bonsoir à toute l'equipe
Merci beaucoup pour cette initiative, mais je n'ai pas bien compris la procedure vu que mon anglais est très mediocre ;)
Hi
Thank you very much for this initiative, but I did not understand the procedure because my English is very mediocre :roll:
L'Algerie vous salut
Y.TABET
WatsApp :+213770943143
dragancesu
Thank you for interest
Attachment contains maunual (english version) how to make translate,
also tables, indexes, sample program and final program
nls&manual.zip
(601.59 KiB) Downloaded 347 times
tonton2
Post by tonton2 »
merci mon ami
Y.TABET
