Data base RecNo() in Grid
KDJ
Post by KDJ »
Moving the mouse cursor within Grid control causes the change of database record (Alias->(RecNo())).
This is a bug or intentional action?
Example:
// Move the mouse cursor within Grid control and observe StatusBar.
#include 'hmg.ch'
FUNCTION Main()
  OpenData()
  DEFINE WINDOW Main_WA;
    MAIN;
    WIDTH  310;
    HEIGHT 235;
    TITLE  'Grid Test'
    DEFINE GRID Users_GR
      ROW             10
      COL             10
      WIDTH          280
      HEIGHT         120
      HEADERS        {'Record', 'Name', 'Price'}
      WIDTHS         {55, 130, 70}
      CELLNAVIGATION .F.
      ROWSOURCE      'Comp'
      COLUMNFIELDS   {'RecNo()', 'Name', 'Price'}
      JUSTIFY        {GRID_JTFY_RIGHT, GRID_JTFY_LEFT, GRID_JTFY_RIGHT}
    END GRID
    DEFINE BUTTON Exit_BU
      ROW      140
      COL      100
      WIDTH     80
      HEIGHT    25
      CAPTION 'Exit'
      ACTION   Main_WA.RELEASE
    END BUTTON
    DEFINE STATUSBAR
      STATUSITEM ''
      STATUSITEM '' WIDTH 200
    END STATUSBAR
    DEFINE TIMER Timer;
      INTERVAL 10;
      ACTION   UpdateStatus()
    ON KEY ESCAPE ACTION Main_WA.RELEASE
  Main_WA.Users_GR.RECNO := 1
  Main_WA.CENTER
  Main_WA.ACTIVATE
FUNCTION UpdateStatus()
  Main_WA.STATUSBAR.Item(1) := 'RecNo(): ' + LTrim(Str(RecNo()))
  Main_WA.STATUSBAR.Item(2) := 'Grid.RECNO: ' + LTrim(Str(Main_WA.Users_GR.RECNO))
FUNCTION OpenData()
  IF File('Comp.dbf')
    dbUseArea(NIL, NIL, 'Comp')
    dbCreate('Comp', {{'Name', 'C', 30, 0}, {'Price', 'N', 6, 2}})
    dbAppend()
    Comp->Name  := 'Main board'
    Comp->Price := 120.34
    dbAppend()
    Comp->Name  := 'Processor'
    Comp->Price := 97.95
    dbAppend()
    Comp->Name  := 'RAM'
    Comp->Price := 204.58
    dbAppend()
    Comp->Name  := 'HDD'
    Comp->Price := 142.71
    dbAppend()
    Comp->Name  := 'SSD'
    Comp->Price := 316.94
    dbAppend()
    Comp->Name  := 'Graphics card'
    Comp->Price := 143.48
    dbAppend()
    Comp->Name  := 'Power supply'
    Comp->Price := 54.29
    dbAppend()
    Comp->Name  := 'PC case'
    Comp->Price := 72.85
Hi KDJ,
It's displaying at Status Item(1) := 'RecNo() according mouse's position at row/grid. IMHO this we would not considered as bug is correct indicating the right recno. Second item displaying according highlited cursor of grid navigator.
KDJ
Re: Data base RecNo() in Grid
Post by KDJ »
Hi, Pablo
Thanks for your answer.
RecNo() is data base function, it returns current record number in data base.
I don't understand why moving mouse (without changing selection in Grid) causes changing record in data base.
In addition, it turns out that the record is changed, even when we do not use the mouse.
Try following test using keyboard only:
1. Move mouse cursor to any edge of desktop.
2. Run my example program (Enter).
Now RecNo() returns 1 and Grid.RECNO is 1.
3. Open window menu (Alt+Space) and select "Minimize". Window was minimized.
4. Restore window by using Alt+TAB.
Now RecNo() returns eg. 6 and Grid.RECNO is still 1.
KDJ wrote:I don't understand why moving mouse (without changing selection in Grid) causes changing record in data base.
You're right Recno() should returns record number and here it is doing upto the moment when mouse is poiting any other row/record in the grid. This behaviour seems to obey to Grid Events when mouse is positioning.
Regarding your steps for testing: I make already and all seems good for me.
When change by keyboard arrors down/up and right and left Recno number are equal the same, but as you've indicated: with mouse's pointer out of form. When minimize and restored returns at the same recno number. for me returns at 4 (both status/items).
I'm testing under Win 7 32 bits with HMG 3.4.3
Probably Claudio can explain this behaviour if is working in accordingly.
KDJ
Post by KDJ »
This last test (without mouse) I have done on Win-XP. Result:
RecNo() --> 6 (6 is last visible item is Grid)
Grid.RECNO --> 1
Now I have tested on Win7. Result:
RecNo() --> 1
Grid.RECNO --> 1
It seems that the behavior depends on Windows version.
I will check.
