Harbour MiniGUI Extended Edition build 16.10 is published
Hi Friends,
I am glad to announce a new version of Harbour MiniGUI Extended Edition.
It is a regularly scheduled maintenance release with the major improvements.
The setup of the build 16.10 is published at the following URL:
http://hmgextended.com/files/CONTRIB/hm ... -setup.zip
and the MinGW-based self-extracting archive is placed at the following URL:
http://hmgextended.com/files/CONTRIB/hmg1610-mingw.exe
There is the 64-bit MinGW-based self-extracting archive at the following URL:
http://hmgextended.com/files/CONTRIB/minigui64-1610.exe
There are also an extra xHarbour.ORG-based and xHarbour.COM-based archives
for this build and donationware Minigui Ex build for Embarcadero's free C++
compiler BCC 10.1 at the Minigui's homepage.
The changelog of this build is below:
2016/10/18: HMG Extended Edition version 16.10.
* New: The MAIN, CHILD and MODAL windows supports an optional CLIENTAREA
clause establishing of the width and height for a client area.
Syntax: CLIENTAREA nClientWidth , nClientHeight
Sample code:
DEFINE WINDOW Win_1 WINDOWTYPE MAIN ;
CLIENTAREA 400, 300 TITLE 'Hello World!'
(see demo in folder \samples\Basic\Calendar)
(see demo in folder \samples\Basic\Picture_Coords)
* New: Added 'ToolTip Custom Draw' support for the BALLOON tooltips.
You can add a custom tooltip to a form or controls with using of
nToolTip := InitToolTipForRect( ;
nFormHandle [, aRect ][, cToolTip ][, cTitle ][, nIcon ];
[, lBallon ][, lClosable ][, lNotUsedYet ] [, lCenterTip ] )
Contributed by Petr Chornyj <myorg63@mail.ru>
(see demo5.prg in folder \samples\Basic\Tooltip_Balloon)
* New: The Slider control supports the optional ENABLESELRANGE and SELRANGE
clauses for the marking of a selected range.
Standard syntax:
@ <row>,<col> SLIDER <controlname> [ OF <parent> ] ;
RANGE <min>,<max> SELRANGE <min>,<max> ;
[ WIDTH <nWidth> ] [ HEIGHT <nHeight> ] ;
ENABLESELRANGE
Alternative syntax:
DEFINE SLIDER Slider_1
ROW 20
COL 20
RANGEMIN 1
RANGEMAX 10
SELRANGEMIN 3
SELRANGEMAX 7
ENABLESELRANGE .T.
END SLIDER
There is the helpful function
SetSliderSelRange( <SliderHandle>, <selrangemin>, <selrangemax> )
for mounting or changing of the selected range at runtime.
Note that the selected range will be displayed only if was defined
the ENABLESELRANGE clause.
(see demo in folder \samples\Basic\Slider)
* New: The Spinner control supports the HORIZONTAL clause for min/max arrows.
(see demo in folder \samples\Basic\SPINNER)
* Enhanced: Added the readonly 'Handle', 'Index', 'Type', 'ClientWidth' and
'ClientHeight' properties for the forms and controls.
Examples:
- function syntax:
hForm := GetProperty ( FormName, 'Handle' )
hControl := GetProperty ( FormName, ControlName, 'Handle' )
- pseudo-OOP syntax:
hForm := FormName.Handle, cFormType := FormName.Type
hControl := FormName.ControlName.Handle
cControlType := FormName.ControlName.Type
Based upon a contribution of Russian user SergKis
* Enhanced: Added a read/write property 'CueBanner' for TEXT family, ComboBox
and Spinner controls.
You can set/get this property at runtime via:
- function syntax:
SetProperty( Form, Control, 'CueBanner', 'New Text' )
GetProperty ( Form, Control, 'CueBanner' )
Form.Control.CueBanner := 'New Text'
Form.Control.CueBanner --> character value
Based upon a contribution of Petr Chornyj <myorg63@mail.ru>
(see demos in folder \samples\Advanced\CueBanner)
* Enhanced: The GetBox control supports an optional focused colors tuning
with the following new commands:
- SET GETBOX FOCUS BACKCOLOR [ TO <backcolor> ]
- SET GETBOX FOCUS FONTCOLOR TO <fontcolor>
where the colors value may have the array or codeblock type.
It was a postponed user's request.
(see demo in folder \samples\Basic\GetBox)
(see demo3.prg in folder \samples\Basic\Color_3)
* Changed: The functions GetFormHandle()/GetControlName() will be return an
error instead of a masking of the wrong calling at an absent window
or control.
* Changed: DEFINE BKGBRUSH command supports a reduced format now, i.e.
- <DEFINE | CREATE> BKBRUSH <brush> [ STYLE ] PATTERN ;
IN [ FORM | WINDOW ] <parent> PICTURE <image>
- ADD BKBRUSH <brush> [ STYLE ] PATTERN ;
TO [ FORM | WINDOW ] <parent> PICTURE <image>
Added also the BKBRUSH synonym for the BACKCOLOR clause of a form.
(see demo in folder \samples\Basic\WindowBackground)
* Updated: The all C-code was revised as below:
- improved the header file mgdefs.h;
- fixed memory leak in a menu extended destructor;
- added the new C-functions ComboFindString, ComboFindStringExact;
(see demo in folder \samples\Basic\ComboSearch)
- optimized C-functions ComboAddStringEx, ComboInsertStringEx,
ComboAddDataStringEx, ComboGetString and ListBoxGetString;
- optimized parameters checking in the functions MESSAGEBOX*;
- improved handling for the cursor and background of a window;
(see demo in folder \samples\Basic\WindowBackground_2)
- reformatted to Harbour standard using uncrustify version 0.63;
- updated for correct compiling with Pelles C 8.0 and XCC compilers
and xHarbour.
* Updated: Synchronized Extended HMG for compatibility with Official HMG:
- New: Added the helpful function HMG_PressKey( nVK1, nVK2, ... )
returns array { nVK1, nVK2, ... },
where nVK is a virtual key code.
Simulates the pressure of a key or a combination of keys.
Contributed by Claudio Soto <srvet@adinet.com.uy>
(see demo in folder \samples\Basic\HotKeyBox)
* Updated: Header file i_hmgcompat.ch for compatibility with Official HMG:
- added a simple 'Grid as Browse' command, f.e.:
@ 10,10 GRID Grid_1 WIDTH 770 HEIGHT 440 ;
HEADERS {'Column 1','Column 2','Column 3','Column 4',;
'Column 5','Column 6'} ;
WIDTHS {140,140,140,100,100,110} VALUE 1 ;
ROWSOURCE "Test" ;
COLUMNFIELDS { 'Code' , 'First' ,'Last' , 'Birth' ,;
'Married' , 'child->info' } ;
COLUMNCONTROLS { aCtrl_1 , aCtrl_2 , aCtrl_3 , aCtrl_4 ,;
aCtrl_5 , aCtrl_6 } ;
EDIT ALLOWAPPEND ALLOWDELETE
(see i_hmgcompat.ch in folder \include)
* New: MiniGUI Extended Edition Common Commands list.
(look at commands.txt in folder \Doc)
* Updated: HBPrinter library v.2.40:
- Changed: GetBox controls were used in the Options form.
(see demo in folder \samples\Basic\HBPrinter)
* Updated: PropGrid library v.2.0 (see source in folder \source\PropGrid):
- New: Added an optional WHEN clause to PROPERTYITEM command.
Contributed by Janusz Pora <januszpora@onet.eu>
* Updated: HbSQLite3 library:
- update for using SQLITE3 version 3.15.0 (from 3.14.2).
* Updated: Harbour Compiler 3.2.0dev (SVN 2016-09-28 19:55):
* Updated: most important differences between Harbour and xHarbour
(see xhb-diff.txt in folder \harbour\doc)
Contributed by Przemyslaw Czerpak <druzus/at/priv.onet.pl>
(look at ReadMe.txt in folder \harbour)
* Updated: HMGS-IDE v.1.4.0 Project Manager and Two-Way Visual Form Designer.
(look for what's new at changelog.txt in folder \Ide)
* New: 'Windows/HMG internal/RC/Animated and custom cursors' sample.
Based upon a contribution of Pablo Cesar Arrascaeta.
Adapted for Minigui Extended by Grigory Filatov <gfilatov@inbox.ru>
(see in folder \samples\Basic\CURSOR_2)
* New: 'Show Image from a resource with using of the Stretch clause' sample.
(see in folder \samples\Basic\IMAGE)
* New: 'Using of the BosTaurus for drawing of a missing image' sample.
(see in folder \samples\Advanced\BTnoImage)
* New: 'TsBrowse Add New Record with Index Order' sample.
Contributed by SergKis
(see in folder \samples\Advanced\Tsb_addrecord_2)
* Updated: 'Print Pie Graph' sample: updated the data for September 2016.
(see demo.prg in folder \samples\Basic\GraphPrint)
* Updated: 'Mini MP3 player' sample is based upon MCI WinAPI:
- added the playing progress bar and numeric title info;
- misc bugfix.
(see in folder \samples\Basic\MiniPlayer)
* Updated: 'SplitBox Resize' sample for compatibility with the last Minigui
improvements. Contributed by Grigory Filatov <gfilatov@inbox.ru>
(see demo8.prg in folder \samples\Basic\CONTAINERS\Splitbox)
* Updated: 'Tooltip Balloon usage' samples.
(see demos in folder \samples\Basic\Tooltip_Balloon)
* Updated: 'Replacement for Clipper ALERT() function' sample:
- added the missed RELEASE FONT command.
(see in folder \samples\Basic\WALERT_2)
BTW We have a new member of the MiniGUI Team C-guru Petr Chornyj.
Thanks for your attention and support.
[MiniGUI Team]
vagblad
DBs Used: MySQL,DBF
Re: Harbour MiniGUI Extended Edition build 16.10 is published
Post by vagblad »
Thanks a lot Grigory for your great work. Really appreciate it. And a big welcome and thanks also to Petr.
Vagelis Prodromidis
gfilatov wrote:I am glad to announce a new version of Harbour MiniGUI Extended Edition.
Thanks for your GREAT work... as always!
Thanks Grigory and Welcome to Petr Chornyj !!
Congratulations Mr. Filatov, nice work, nice samples (I'm feeling grateful to make part of it) and good team too.
Welcome Mr. Petr Chornyj.
Congratulations Mr. Filatov, and Welcome Mr. Petr Chornyj.
Steed
Post by Steed »
thanks
quartz565
Post by quartz565 »
serge_girard wrote:Thanks Grigory and Welcome to Petr Chornyj !!
Nikos.
os: Windows Server 2019 - 64
