REFRESH in TexBox control (bug)
Posted: Sat Oct 15, 2016 8:25 pm
by KDJ
Run time error occurs, if you call REFRESH method for TextBox control.
In the following example, click on "Show password" CheckBox:
#include 'hmg.ch'
FUNCTION Main()
  DEFINE WINDOW Main_WA;
    MAIN;
    ROW    100;
    COL    100;
    WIDTH  225;
    HEIGHT 150;
    TITLE  'TextBox Password Test';
    NOSIZE;
    NOMAXIMIZE;
    NOMINIMIZE
    DEFINE LABEL Pass_LA
      ROW     10
      COL     10
      WIDTH  200
      HEIGHT  13
      VALUE  'Type password:'
    END LABEL
    DEFINE TEXTBOX Pass_TE
      ROW        26
      COL        10
      WIDTH     200
      HEIGHT     21
      VALUE     'my password'
      PASSWORD  .T.
    END TEXTBOX
    DEFINE CHECKBOX Pass_CBO
      ROW       55
      COL       10
      WIDTH    200
      HEIGHT    16
      CAPTION  'Show password'
      ONCHANGE ShowPassword()
    END CHECKBOX
    DEFINE BUTTON OK_BU
      ROW     85
      COL     25
      WIDTH   80
      HEIGHT  25
      CAPTION 'OK'
      ACTION  Main_WA.RELEASE
    END BUTTON
    DEFINE BUTTON Cancel_BU
      ROW     85
      COL    115
      WIDTH   80
      HEIGHT  25
      CAPTION 'Cancel'
    END BUTTON
    ON KEY ESCAPE ACTION Main_WA.RELEASE
  Main_WA.ACTIVATE
FUNCTION ShowPassword()
  LOCAL lShowPass := Main_WA.Pass_CBO.VALUE
  SendMessage(Main_WA.Pass_TE.HANDLE, 0x00CC /*EM_SETPASSWORDCHAR*/, If(lShowPass, 0, 0x25CF), 0)
  Main_WA.Pass_TE.REFRESH
  //solution:
  //RedrawWindow(Main_WA.Pass_TE.HANDLE)
Posted: Sat Oct 15, 2016 9:25 pm
Yes, TextBox with PASSWORD is with error at _DataTextBoxRefresh.
Field mismatch type.
Very nice solution with SenMessage :) Thank you for sharing
Re: REFRESH in TexBox control (bug)
Posted: Sat Oct 15, 2016 11:54 pm
KDJ wrote:Run time error occurs, if you call REFRESH method for TextBox control.
Thanks KDJ (personally, instead of "machine code" I prefer be addressed to human names ;) )
Good "show password" method, good error catch, good solution and very nice sample :arrow:
Textbox Password Test Result.JPG (17.02 KiB) Viewed 5258 times
Viva HMG :D
Posted: Sun Oct 16, 2016 12:11 am
by srvet_claudio
#include 'hmg.ch'
FUNCTION Main()
    MAIN;
    ROW    100;
    COL    100;
    WIDTH  225;
    HEIGHT 150;
    NOSIZE;
    NOMAXIMIZE;
    NOMINIMIZE
      ROW     10
      COL     10
      WIDTH  200
      HEIGHT  13
    END LABEL
      ROW        26
      COL        10
      WIDTH     200
      HEIGHT     21
      VALUE     'my password'
      PASSWORD  .T.
    END TEXTBOX
      ROW       55
      COL       10
      WIDTH    200
      HEIGHT    16
    END CHECKBOX
    DEFINE BUTTON OK_BU
      ROW     85
      COL     25
      WIDTH   80
      HEIGHT  25
      CAPTION 'OK'
    END BUTTON
      ROW     85
      COL    115
      WIDTH   80
      HEIGHT  25
      CAPTION 'Cancel'
    END BUTTON
  Main_WA.ACTIVATE
  //solution:
Use Redraw method, Refresh is supported only by small group of controls.
Posted: Sun Oct 16, 2016 11:38 am
srvet_claudio wrote:...
Use Redraw method...
Yes; using "known" method instead of undocumented (developer only) function is better.
  //solution:
  * RedrawWindow(Main_WA.Pass_TE.HANDLE)
Main_WA.Pass_TE.REDRAW
May will be tiring adding "RedrawWindow" function to refresh method from TextBox (and other controls that not support refresh method) or removing that method from documentation.
In other point of view: does for a single control, redrawing whole window is a good way ?, I'am asking to myself :?
Viva HMG :D
Posted: Sun Oct 16, 2016 4:46 pm
by KDJ
srvet_claudio wrote:Use Redraw method, Refresh is supported only by small group of controls.
REFRESH method is documented for TexBox control and is realized in source code. But it generates a runtime error.
REDRAW method is not documented, but it works fine.
The documentation update is needed.
And it would be good to shortly describe all HMG functions, eg:
GetSystemMetrics(nIndex) --> Return nValue
HMG_ChangeWindowStyle(hWnd, [nAddStyle], [nRemoveStyle], [lExStyle], [lRedrawWindow]) --> Return nOldStyle
HMG_IsValidFileName(cFileNameWithoutPath) --> Return lValid
HMG_SendMessage(hWnd, nMsg, [@]wParam, [@]lParam) --> Return nResult
SendMessage(hWnd, nMsg, wParam, lParam) --> Return nResult
Posted: Thu Feb 15, 2018 9:36 pm
by ROBROS
Hi friends,
I got the same runtime error. :(
But I remembered, I had succsessfully changed the code of the following prg to match my needs:
C:\hmg.3.4.4\SAMPLES\Controls\DATA_BOUND\datacontrols.prg
And it works :)
the method is called by procedure refresh()
With the help of you and by the tons of code stuff I get closer to hit my target.
I like hmg.
Robert
