CELLNAVIGATION in Grid control (bug)
KDJ
Post by KDJ »
In grid control definition "CELLNAVIGATION .F." is ignored if "ROWSOURCE" is used.
This property is allways set to .T.:
#include 'hmg.ch'
FUNCTION Main()
  dbCreate('Users', {{'Name', 'C', 30, 0}, {'Location', 'C', 30, 0}})
  dbUseArea(NIL, NIL, 'Users')
  dbAppend()
  Users->Name     := 'Claudio'
  Users->Location := 'Uruguay'
  dbAppend()
  Users->Name     := 'Krzysztof'
  Users->Location := 'Poland'
  dbGoTop()
  DEFINE WINDOW Main_WA;
    MAIN;
    ROW    100;
    COL    100;
    WIDTH  340;
    HEIGHT 200;
    TITLE  'Grid Test'
    DEFINE GRID Users_GR
      ROW             10
      COL             10
      WIDTH          310
      HEIGHT         100
      HEADERS        {'Name', 'Location'}
      WIDTHS         {150, 150}
      CELLNAVIGATION .F.
      ROWSOURCE      'Users'
      COLUMNFIELDS   {'Name', 'Location'}
    END GRID
    DEFINE BUTTON Close_BU
      ROW     130
      COL     120
      WIDTH   80
      HEIGHT  25
      CAPTION 'Close'
      ACTION  Main_WA.RELEASE
    END BUTTON
    ON KEY ESCAPE ACTION Main_WA.RELEASE
  //MsgBox(Main_WA.Users_GR.CELLNAVIGATION, 'CELLNAVIGATION') ==> .T.
  IF Main_WA.Users_GR.CELLNAVIGATION
    Main_WA.Users_GR.VALUE := {2, 2}
    Main_WA.Users_GR.VALUE := 2
  Main_WA.ACTIVATE
Re: CELLNAVIGATION in Grid control
I will check.
KDJ
Post by KDJ »
Although in the documentation is written:
CellNavigation (D)
D: Available at control definition only
we can to force to set CELLNAVIGATION after Grid definition:
Main_WA.Users_GR.CELLNAVIGATION := .F.
In this case, if you try to use RecNo property, run-time error occurs:
#include 'hmg.ch'
FUNCTION Main()
  dbAppend()
  dbAppend()
  dbGoTop()
    MAIN;
    ROW    100;
    COL    100;
    WIDTH  340;
    HEIGHT 200;
    TITLE  'Grid Test'
      ROW             10
      COL             10
      WIDTH          310
      HEIGHT         100
      WIDTHS         {150, 150}
      CELLNAVIGATION .F.
      ROWSOURCE      'Users'
    END GRID
    DEFINE BUTTON RecNo_BU
      ROW     130
      COL     120
      WIDTH   80
      HEIGHT  25
      CAPTION '? &RecNo'
      ACTION  MsgBox(Main_WA.Users_GR.RecNo, 'Record')
    END BUTTON
  Main_WA.ACTIVATE
KDJ
Post by KDJ »
srvet_claudio wrote:I will check.
If you checked, I expect some information on this topic.
KDJ
Re: CELLNAVIGATION in Grid control (bug)
Post by KDJ »
Because "CELLNAVIGATION := .F." with ROWSOURCE does not work properly, for now, I solved the problem in following way:
I used "CELLNAVIGATION := .T." and changed colors of selected row and cell.
CELLNAVIGATION is turned on but it looks like CELLNAVIGATION has been turned off (CELLNAVIGATION without CELLNAVIGATION).
#include 'hmg.ch'
FUNCTION Main()
  LOCAL aFRowColor
  LOCAL aBRowColor
  LOCAL aFCellColor
  LOCAL aBCellColor
  dbAppend()
  dbAppend()
    MAIN;
    WIDTH  340;
    HEIGHT 200;
    TITLE  'Grid of Data Test'
      ROW             10
      COL             10
      WIDTH          310
      HEIGHT         100
      HEADERS        {'Record', 'Name', 'Location'}
      WIDTHS         {55, 150, 150}
      //CELLNAVIGATION .F.
      ROWSOURCE      'Users'
      COLUMNFIELDS   {'RecNo()', 'Name', 'Location'}
      JUSTIFY        {GRID_JTFY_RIGHT, GRID_JTFY_LEFT, GRID_JTFY_LEFT}
      ONGOTFOCUS     (CellNavigationColor(_SELECTEDROW_FORECOLOR, aFCellColor), CellNavigationColor(_SELECTEDROW_BACKCOLOR, aBCellColor), CellNavigationColor(_SELECTEDCELL_FORECOLOR, aFCellColor), CellNavigationColor(_SELECTEDCELL_BACKCOLOR, aBCellColor), This.REDRAW)
      ONLOSTFOCUS    (CellNavigationColor(_SELECTEDROW_FORECOLOR, aFRowColor),  CellNavigationColor(_SELECTEDROW_BACKCOLOR, aBRowColor),  CellNavigationColor(_SELECTEDCELL_FORECOLOR, aFRowColor),  CellNavigationColor(_SELECTEDCELL_BACKCOLOR, aBRowColor),  This.REDRAW)
    END GRID
    DEFINE BUTTON Record_BU
      ROW     130
      COL     120
      WIDTH   80
      HEIGHT  25
      CAPTION '? &Record'
      ACTION  MsgBox(Main_WA.Users_GR.RECNO, 'Record')
    END BUTTON
  aFRowColor  := CellNavigationColor(_SELECTEDROW_FORECOLOR)
  aBRowColor  := CellNavigationColor(_SELECTEDROW_BACKCOLOR)
  aFCellColor := CellNavigationColor(_SELECTEDCELL_FORECOLOR)
  aBCellColor := CellNavigationColor(_SELECTEDCELL_BACKCOLOR)
  Main_WA.Users_GR.RECNO := 2
  Main_WA.CENTER
  Main_WA.ACTIVATE
