Browse con HEADERIMAGES
fchirico
Post by fchirico »
Hola!!
No puedo lograr que en un BROWSE solo pueda mostrar imágenes en las columnas que yo desee con HEADERIMAGES.
Como DEMO usé el ejemplo \hmg\samples\browse_06\demo.prg
y no lo logré, lo he intentado con todas esta variaciones:
*/// RESULTADO: no muestra ningun HEADER
* HEADERIMAGES { , '01.bmp' , '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
*/// RESULTADO: no muestra el ultimo HEADER, cuando no deberia mostrar la segunda
* HEADERIMAGES { '00.bmp' , , '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
* HEADERIMAGES { '00.bmp' ,nil, '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
* HEADERIMAGES { '00.bmp' ,' ', '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
* HEADERIMAGES { '00.bmp' ,'noexiste.bmp', '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
espero puedan ayudarme.
Un saludo, Fernando Chirico.
Saludos, Fernando Chirico.
Re: Browse con HEADERIMAGES
google wrote:I can not get in a browser can only display images in the columns that I want to HEADERIMAGES.
As I used the DEMO example \ HMG \ samples \ browse_06 \ demo.prg and we fail, I have tried all these variations:
may help.
Hola Fernando
If I understood correct your question, simply add an "empty" image to your .prg and HEADERIMAGE clause:
HEADERIMAGES	{ 'empty.bmp' , '01.bmp' , '02.bmp' , '03.bmp' , '04.bmp' , '05.bmp' }
Attached an example .bmp ( used in MiniAgenda ).
Forum manager don't allow .bmp extention, so it's in .zip file.
I hope that this will help you.
Salodus
empty.zip
Empty image
(149 Bytes) Downloaded 247 times
fchirico
Post by fchirico »
Estimado Esgici:
you have understood my question.
this solution the thought, but not what I want, a deity that is the problem of background colors.
Anyway thank you very much.
Dear Fernando
Now you and me we have a wish : Mixed header images on browse : some columns have image, others no. Such as you have tried:
HEADERIMAGE { '"", "01.BMP", "", "", "02.BMP" ...
I hope Maestro will read our wish, confirm and apply in a day in the future.
For now, as a temporary solution, you can color the empty image by back color of your browse.
By the way, I had a similar wish : browse without headers. I guess that columns of our browse are constituted on headers, no fields clause.
Saludos cordiales
