Hi Claudio,
I do not know if this is a HMG bug or normal behaviour in API demands...
DISABLEDFONTCOLOR at TextBox, do not change color at all
In this message Javier told us.
I'm using in Win7 32 bits classic style. I do not know what I am doing worng
- srvet_claudio
Re: DISABLEDFONTCOLOR at TextBox
I will check
I have mentioned about API (I do not know if this term is correct) which probably this strange behaviour is normal in Windows appearance.
I done a simple test code:
If you comment the line 27 where is Form_1.Text_1.ReadOnly := .T. you will see is not working. Only works with ReadOnly property. But I do not wish to setcursor in it
Function Main()
DEFINE WINDOW FORM_1 AT 132 , 235 WIDTH 550 HEIGHT 350 MAIN
DEFINE TEXTBOX Text_1
ROW 90
COL 180
WIDTH 160
HEIGHT 24
DISABLEDFONTCOLOR RED
VALUE "FONT IN RED COLOR"
END TEXTBOX
DEFINE TEXTBOX Text_2
ROW 120
COL 180
WIDTH 160
HEIGHT 24
VALUE "FONT normal COLOR"
END TEXTBOX
Form_1.Text_2.SetFocus
Form_1.Text_1.Enabled := .F. // Not working
CENTER WINDOW Form_1
ACTIVATE WINDOW Form_1
I appreciated your return.srvet_claudio wrote:I will check
Function Main()
ROW 90
COL 180
WIDTH 160
HEIGHT 24
END TEXTBOX
ROW 120
COL 180
WIDTH 160
HEIGHT 24
END TEXTBOX
Hi Pablo:
Yes you are right, but this is not an issue relationship with Hmg 3.43 and or Win version.-
If my memory don't fail, this becomes from older HMG versions (3.046 and later).-
I've implement your proposal, READONLY instead of dissablefontcolor.-
Just for the records, i test my app developed with the latest HMG version on several WIN os.- This shows me that the more stable ones were those that i compiled under WIN XP and execute them on later WIN os, withouth any issues.-
With regards.
Eduardo
With regards.
Eduardo
Hi Eduardo and thank you for your testing. But I would like a changeable option when control is disabled without to add a routine for escaping when user makes focus in it.EduardoLuis wrote:I've implement your proposal, READONLY instead of dissablefontcolor.-
