HMG 2.5.5
Re: HMG 2.5.5
Roberto Lopez wrote:
gfilatov wrote: Excuse me but a new Image ComboBox is not work at Win98 (a such control is not displayed). :(
The ComboBox control without an Image clause still works OK.
:roll:
Please try removing comment slashes '//' in the lines 195 and 196 of c_combo.c file.
Roberto,
Thanks for prompt reply!
The Imaged ComboBox works now at Win98 :)
Re: HMG 2.5.5
:roll:
Roberto,
Thanks!
I've forgot to uncomment that lines :)
I'll publish the fix in the next build.
Re: HMG 2.5.5
Roberto Lopez wrote: I've forgot to uncomment that lines :)
Hello Roberto,
There are a more library code's improvements:
1) look at h_button.prg for the following condition:
	if (.Not. IsAppThemed())
		aRet := InitImageButton ( ParentForm, Caption, 0, x, y, w, h, image , flat , notrans, invisible, notabstop , .F. )
		aRet := InitImageButton ( ParentForm, Caption, 0, x, y, w, h, image , flat , notrans, invisible, notabstop , .T. )
Why not to replace it with one code's string:
		aRet := InitImageButton ( ParentForm, Caption, 0, x, y, w, h, image , flat , notrans, invisible, notabstop , IsAppThemed() )
2) look at h_windows.prg for function IsAppThemed():
Function IsAppThemed()
local uResult
Local nVersion
	nVersion := WINMAJORVERSIONNUMBER() + ( WINMINORVERSIONNUMBER() / 10 )
	If nVersion >= 5.1
	If IsWinXPorLater()
where
Function IsWinXPorLater()
Local nVersion
Return ( nVersion >= 5.1 )
Or is better as C-level function
HB_FUNC( ISWINXPORLATER )
  OSVERSIONINFO osvi;
  osvi.dwOSVersionInfoSize = sizeof( OSVERSIONINFO );
  GetVersionEx ( ( OSVERSIONINFO * ) &osvi );
  hb_retl( osvi.dwPlatformId == VER_PLATFORM_WIN32_NT
        && ((osvi.dwMajorVersion == 5 && osvi.dwMinorVersion > 0) ||
		(osvi.dwMajorVersion > 5)) );
Just my two cents...
:oops:
Re: HMG 2.5.5
<...>Just my two cents...
:oops:
Well... I've only took a brief look at your suggestions, but I'm afraid that you are right :)
When I'm 'fighting' against Windows API, usually I write some 'silly' code, beacuse I'm focused on make that **** 'thing' working right.
When that 'thing' finally works I do some 'clean and sweep', but sometimes I've forgot and sometimes I'm simply 'lazy' :)
Re: HMG 2.5.5
:oops:
Anyway... Had you heard about "It's working fine, don't touch it" :) ?
Re: HMG 2.5.5
Roberto Lopez wrote:Anyway... Had you heard about "It's working fine, don't touch it" :) ?
Roberto,
Yes, of course!
:P
Re: HMG 2.5.5
It is nice to see two giants talking about simplified programming. :)
Re: HMG 2.5.5
rathinagiri wrote:It is nice to see two giants talking about simplified programming. :)
My weight has augmented lately... It's winter here... and... you know... one tends to eat more... but 'giant' may be a little exaggerated :)
Re: HMG 2.5.5
In that case, I would recall the giants philosophy. :)
