Bos Taurus - BT_BitmapLoadFile
Hi Claudio,
BT_BitmapLoadFile does not load Bitmap (.bmp) file from resource file. :shock:
All JPG, GIF and PNG types works perfectly.
hBitmap_aux := BT_BitmapLoadFile ("HMG")
msgdebug(hBitmap_aux) // Here is returning value zero
Even changing Bitmap for BMP doesn't work... :(
B.Rgds
Re: Bos Taurus - BT_BitmapLoadFile
I will check Pablo.
You have defined the resource as:
NameRes BITMAP FileName
I found the error, Claudio. When is written BITMAP as you described: no problem but if you write Bitmap (not all upper case) then not recognizes it. :o
The strange and funny that for other types you can write as you want (upper, lower, camel case, mixed) and works perfectly but not for BMPs. :shock:
IMHO, should it works for BMPs (bitmap) written and interpreted by non sensitive case.
So it's seems not a bug at all but fails in some cases. Then my suggestion.
Pablo César wrote:I found the error, Claudio. When is written BITMAP as you described: no problem but if you write Bitmap (not all upper case) then not recognizes it. :o
BITMAP is a standard keyword of the compiler resource of C.
Yes, you are right Dr. Soto. This is a resource compiler issue and resource type file (BITMAP) must it be in upper case for convention.
