Page 1 of 4
HMG_Upper() function causes a memory leak
Posted: Mon Sep 19, 2016 1:11 pm
by KDJ
I have tested the following code in real Win-XP (32 bit) and Win-7 (64 bit).
Each time you press "Test" button, consumption of memory is increased by approx 600 KB.
// Press 'Test: HMG_Upper()' and observe memory usage at status bar
#include 'hmg.ch'
FUNCTION Main()
  SET FONT TO 'MS Shell Dlg', 8
  DEFINE WINDOW MUT_WA;
    COL    200;
    ROW    100;
    WIDTH  340;
    HEIGHT 120;
    TITLE  'Memory usage test';
    DEFINE BUTTON Test_BU
      COL      10
      ROW      20
      WIDTH   150
      HEIGHT   25
      CAPTION 'Test: HMG_Upper()'
      ACTION  DoTest()
    END BUTTON
    DEFINE BUTTON Exit_BU
      COL     170
      ROW      20
      WIDTH   150
      HEIGHT   25
      CAPTION 'Exit'
      ACTION  MUT_WA.RELEASE
    END BUTTON
    DEFINE STATUSBAR
      STATUSITEM ''
    END STATUSBAR
    DEFINE TIMER MUT_WA_TI;
      INTERVAL 1000;
      ACTION   UpdateStatus()
    ON KEY ESCAPE ACTION MUT_WA.RELEASE
  END WINDOW //MUT_WA
  UpdateStatus()
  MUT_WA.ACTIVATE
FUNCTION DoTest()
  LOCAL n
  LOCAL cString := 'abcdefgh'
  FOR n := 1 TO 10000
    HMG_Upper(cString)
    //HMG_Lower(cString)
    //Upper(cString)
    //Lower(cString)
    //HMG_CallDLL('User32.dll', 0, 'CharUpper', cString)
  UpdateStatus()
FUNCTION UpdateStatus()
  MUT_WA.STATUSBAR.Item(1) := 'Memory usage: ' + LTrim(Str(GetProcessMemoryInfo()[3] / 1024, 10, 0) + ' KB')
  //RELEASE MEMORY does not work in Win-XP, in Win-7 works
  //RELEASE MEMORY
Re: HMG_Upper() function causes a memory leak
Posted: Mon Sep 19, 2016 1:15 pm
by srvet_claudio
I will check.
Posted: Mon Sep 19, 2016 5:09 pm
Claudio,
Is it good practice to put a 'RELEASE MEMORY' on several places in a program OR should it be done "automatically" ?
Posted: Mon Sep 19, 2016 5:33 pm
by EduardoLuis
Hi friends:
I've test your sample under different versions of HMG since 3.030 to 3.43 and the result is the same: up 600kb each time is pressed the button.-
So previously Claudio you change anything on new version, i suppose there is no issue with HMG_Upper() and 3.43.-
Just for the records, the test was made on a PC with win XP SP3 and only 512mg ram.-
As never hangs up the program or the OS, i made the test till memory on status shows 390.000kb.-
Just a test.-
With regards.
Eduardo
Hola Amigos:
He testeado el ejemplo bajo diferentes versions de HMG desde la version 3.030 hasta la 3.43 y el resultado fue el mismo: 600kb hacia arriba cada vez que se presionba el botón.-
Por eso, Claudio, previamente antes que introduzcas algun cambio en la proxima version, supongo que esto no es un defecto de HMG_Upper() en la 3.43.-
Para el registro, este test fue hecho en una PC con Win XP SP3 y solo 512mg. ram.-
Como el programa nunca se colgó y tampoco el SO, por lo tedioso del test lo realizé hasta que la barra de status mostró 390.000kb.-
Es solo un test.-
Cordialmente
Eduardo
Posted: Mon Sep 19, 2016 5:46 pm
by KDJ
1. This test program almost does nothing, only converts string to uppercase. So why to use "RELEASE MEMORY"?
2. Using Upper(cString) function or HMG_CallDLL('User32.dll', 0, 'CharUpper', cString) instead of HMG_Upper(cString) does not result in increased memory usage.
3. "RELEASE MEMORY" does not work in Windows XP.
Posted: Mon Sep 19, 2016 10:17 pm
by Roberto Lopez
There is not memory consumption increase here (Windows 7 32 bits).
Posted: Tue Sep 20, 2016 10:47 am
by mustafa
Try ? have if it works
COL 200;
ROW 100;
WIDTH 340;
HEIGHT 120;
View Post luisvasquez --> viewtopic.php?f=43&t=4738&start=70
----------- here this code -------------> DEFINE TIMER Timer_1 INTERVAL 1000 ACTION (RELEASE MEMORY)
COL 10
ROW 20
Saludos/Regarts
Posted: Tue Sep 20, 2016 11:11 am
Hello,
What I meant is :
Is it necessary to put a 'RELEASE MEMORY' on (via TIMER) in a program ?
OR
should it be done automatically in HMG-sources
OR
Is it a temporarily problem?
I think only Claudio or Rathi knows the right answer?
Regards, Serge
Posted: Tue Sep 20, 2016 11:25 am
by dragancesu
This program is classic for compiler test, code like
FOR I = 1 TO 10000
x = 1
is one step, this code can be compiled like X = 1, in this case compiler must be clever then programer and correct programer's bad code
x = 0
FOR I = 1 TO 10000
x = x + 1
can be loop 10000 times
Posted: Tue Sep 20, 2016 1:01 pm
serge_girard wrote:Hello,
What I meant is :
OR
OR
Regards, Serge
IMHO, the memory resources once not needed shall be released automatically.
For some memory hungry programs (with huge image manipulation), I think we shall use release memory.
