Bos Taurus problem?
Bos Taurus problem?
Hi Claudio (and all),
I've created an app to monitor a PC.
Basically it takes a screenshot of desktop window each 30 seconds and uploads it to an FTP server.
I've noted that after 467 iterations, it stops working.
I've tried on different machines with the same result.
Since I need capture the desktop window and not an HMG one, I've made very little modification to BT_BitmapCaptureClientArea() function to make it work with a handle instead an HMG window name.
I've created the simplest possible example to verify the problem... here it is:
Function Main()
	DEFINE WINDOW Win_1 ;
		WIDTH 400 ;
		HEIGHT 400 ;
		TITLE '' ;
		MAIN
		define button test
			row 10
			col 10
			caption 'test'
			action test()
		end button
	ACTIVATE WINDOW Win_1
procedure test
local i, hDesktop, nDesktopWidth, nDesktopHeight
	hDesktop := BT_SCR_GETDESKTOPHANDLE()
	nDesktopWidth := GetDesktopWidth()
	nDesktopHeight := GetDesktopHeight()
	for i := 1 to 1000
		xSaveWindowByHandle ( hDesktop , strzero(i,4)  + '.' + 'jpg' , 0 , 0 , nDesktopWidth , nDesktopHeight )
	next i
	msginfo('fin')
return
FUNCTION xSaveWindowByHandle ( nHandle , cFileName , nRow , nCol , nWidth , nHeight )
LOCAL hBitmap
   hBitmap := xBT_BitmapCaptureClientArea ( nHandle , nRow, nCol, nWidth, nHeight)
   IF hBitmap <> 0
	IF	UPPER(RIGHT( cFileName , 4 ) ) == '.GIF'
	      BT_BitmapSaveFile (hBitmap, cFileName , BT_FILEFORMAT_GIF )
	ELSEIF	UPPER(RIGHT( cFileName , 4 ) ) == '.JPG'
	      BT_BitmapSaveFile (hBitmap, cFileName , BT_FILEFORMAT_JPG )
	ELSEIF	UPPER(RIGHT( cFileName , 4 ) ) == '.PNG'
	      BT_BitmapSaveFile (hBitmap, cFileName , BT_FILEFORMAT_PNG )
	ELSEIF	UPPER(RIGHT( cFileName , 4 ) ) == '.BMP'
	      BT_BitmapSaveFile (hBitmap, cFileName , BT_FILEFORMAT_BMP )
	BT_BitmapRelease (hBitmap)
RETURN hBitmap
Function xBT_BitmapCaptureClientArea ( nHandle , Row, Col, Width, Height)
   LOCAL New_hBitmap
   LOCAL Max_Width  := BT_ClientAreaWidth( nHandle )
   LOCAL Max_Height := BT_ClientAreaHeight( nHandle )
   bt_FillRectIsNIL (@Row, @Col, @Width, @Height, 0, 0, Max_Width, Max_Height)
   bt_AdjustWidthHeightRect (Row, Col, @Width, @Height, Max_Width, Max_Height)
   New_hBitmap := BT_BMP_CAPTURESCR ( nHandle , Col, Row, Width, Height, BT_BITMAP_CAPTURE_CLIENTAREA)
Return New_hBitmap
Thanks in advance.
Re: Bos Taurus problem?
I've forgot to mention that I've tested on Windows 7 32 bits and Windows 8.1 64 bits.
Roberto,
Thanks for report. I will check.
Hola Roberto
Aquí, llega hasta la imagen 608 y es una imagen negra con solo 17kb. a diferencia de
las otras que son de 143kb.
Tengo Win7, SP1 32bits.
srvet_claudio wrote:Roberto,
I'm keep testing and I'm discovered something really really disturbing...
I've created an equivalent test example with an old HMG version (3.0.40) and used the SaveWindowByHandle() internal function.
The result is the same... only changing the number of files created prior the crash...
mmm... I'm lost :)
extraño... ahora llegó a la 605. la ultima es una pantalla negra.
Me quedé sin memoria...
andyglezl wrote:Hola Roberto
I'm not sure, but, apparently it depends on desktop size...
andyglezl wrote:extraño... ahora llegó a la 605. la ultima es una pantalla negra.
These kind of errors, usually are related with handles or memory not released... but I can't find it...
And the fact that a complete different routine like the old SaveWIndowByHandle() creates a similar problem, is very strange...
That's it!
Memory use grows with each screenshot and when is near to the point of no physical memory available, it stops creating images.
The question is why...
Appears to be memory allocated but not released... but... it is not obvious looking at the code...
