HMG 2.9.2 (Forum test III)
A new attempt :)
Thanks in advance for test and report.
hmg292-3.rar
(369.93 KiB) Downloaded 308 times
Re: HMG 2.9.2 (Forum test III)
Hi Maestro
Thanks a lot for this new release :)
Tested for some random built (old) projects, it seems no problem.
Unfortunately I'm not sure understanding new feature : property style synonyms :(
Here is my test prg :
  Testing property style synonyms for the DEFINE WINDOW command clauses introduced by HMG 2.9.2
#include "minigui.ch"
PROC Main()
   DEFINE WINDOW frmSynsTest ;
      ROW         0          ;
      COL         0          ;
      WIDTH       520        ;
      HEIGHT      400        ;
      TITLE       'Tests for property style synonyms' ;
      WindowType  "MAIN"     ;
      Visible     .T.        ;
      AutoRelease .F.        ;
      MinButton   .T.        ;
      MaxButton   .F.        ;
      Sizable     .F.        ;
      SysMenu     .F.        ;
      TitleBar    .T.        ;
      FontName    "FixedSys" ;
      FontSize    12         ;
      HelpButton  .T.        ;
      Break       .T.        ;
      Focused     .T.        ;
      Topmost     .T.
   END WINDOW // frmSynsTest
   frmSynsTest.Center
   frmSynsTest.Activate
RETU // Main()
*-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.-._.
It produce most annoying error : Syntax error at WINDOW :!:
Where I'm wrong :?:
Thanks in advance with best regards.
esgici wrote:Hi Maestro
WindowType "MAIN" ;
Where I'm wrong :?:
You must not use quotes for Main.
And... this is not exactly a feature. The purpose for this, is consistency and easyness.
The syntax:
<PropertyName> <PropertyValue>
IMHO, is easier to understand and remember. Besides that, its consistent with IDE, where (ie) for windows you use 'row' and 'col' properties instead AT <row> , <col>.
I've attached the new help text for 'define window'. Please, take a look at it.
definewindow.rar
(3.51 KiB) Downloaded 321 times
Thanks Maestro
Now it's more clear :)
Best Regards
Vanguarda
Post by Vanguarda »
Thanks master for this update.
with best regards,
esgici wrote:Thanks Maestro
Best Regards
A little more clarification:
For controls (alternate syntax) you can define it as non-visible at definition via:
VISIBLE .F.
To do the same for windows you must add NOSHOW clause.
The idea is that you be able to do the same thing using the same syntax (or logic).
So, you can define a non visible window now in the same way that you define a non visible control via alternate syntax (as I've said: VISIBLE .F.)
The same is applicable to a lot of properties.
Thanks for clarifications, Maestro :)
Best Regards
