Actualizacion de windows
martingz
Post by martingz »
La actualizacion de windows KB3177725 en windows 8.1 y la de windows 10, del 11 y 12 de Agosto ( mil disculpas por no tener el numero), dan problemas con la impresion, nuestro sistema de imprecion de recibos ( imprimimos uno 20,000 cada 5 dias) solamente mandaba el primer recibo de todo el trabajo
el spooler recibe solo el primero, desinstalando estas actualizaciones todo vuelve a la normalidad, esto solamente una advertencia por si alguien tiene este tipo de problemas
saludos
google translation
Windows Update KB3177725 on Windows 8.1 and Windows 10 ,11 and 12 August (apologies for not having the number), given problems with printing, our system inaccuracies receipts (print one 20,000 every 5 days) only He commanded the first receipt of all work
the spooler receives only the first, uninstalling these updates everything returns to normal, this is only a warning if someone has this kind of problem
mlnr
Re: Actualizacion de windows
Post by mlnr »
Thanks a lot!
https://support.microsoft.com/en-us/kb/3177725
Known issues
After you apply this security update and you print multiple documents in succession, the first two documents may print successfully. However, the third and subsequent documents may not print.
koke
DBs Used: DBF, mySql, mariaDB
Post by koke »
Gracias ! ! !
,___,
[O.o]
/)__)
KoKe
martingz
Post by martingz »
For windows 10 KB3176493 is the update
Known issues
