HMG -GitBook
Posted: Thu Aug 04, 2016 4:49 pm
Dear HMGians,
I have started converting HMG documentation in GitBook (
https://www.gitbook.com/book/rathinagir ... lp/details)
The advantages of GitBook are:
- more people can contribute online.
- you can search the whole book by any keyword (Try it! You will enjoy!)
- can be downloaded at anytime in PDF/epub/mobi format (with table of contents and search enabled of course!)
Anybody willing to join with me?
Re: HMG -GitBook
Posted: Fri Aug 05, 2016 7:18 am
Great Rathi! How can we help or join?
Re: HMG -GitBook
Posted: Fri Aug 05, 2016 7:32 am
Thank you Serge.
I have added you as a collaborator and sent an email to you.
You can download the GitBook Editor for windows from here
https://www.gitbook.com/editor/windows
First you go around and make familiar how things are managed. Then you can easily contribute.
Re: HMG -GitBook
Posted: Fri Aug 05, 2016 7:37 am
by mol
I can help, but, I'll be ready after 22. August
Re: HMG -GitBook
Posted: Fri Aug 05, 2016 8:21 am
by vagblad
Rathi that's great news! The more documentation we have the better!
I would love to help in any way i can!
Re: HMG -GitBook
Posted: Thu Aug 11, 2016 6:29 pm
Conversion of HMG documentation in GitBook is over now.
You can see the GitBook online or download as PDF/epub/mobi format.
Please give your suggestions/comments if any. The link for the GitBook is available at the first post of this topic.
Re: HMG -GitBook
Posted: Fri Aug 12, 2016 4:43 am
by bpd2000
Dear Rathi
Thank you for your contribution and effort
Re: HMG -GitBook
Posted: Fri Aug 12, 2016 6:14 am
Thank you.
Since both online and offline editing are possible, many can contribute for this book.
For example, today I have added the following in the documents:
HMG and Alternate Syntax:
All over this help document you can find that there are two types of syntax available for the definition of various controls. One is traditional '@ row, col CONTROLTYPE controlname' syntax and the alternate syntax with 'define....end' statements. Each synatx is having its own merits and demerits.
@ nRow, nCol CONTROLTYPE controlname
While '@ nRow, nCol CONTROLTYPE controlname' syntax is a single line simple syntax it requires the sequence of various properties of that control as it is. For example the following statement is right:
@ 10,10 textbox t1 height 40 width 100
Where as the following is wrong
@ 10,10 textbox t1 width 100 height 40
In other words, you have to memorize the sequentail order of the various properties also.
Alternate Syntax: DEFINE CONTROLTYPE controlname:
In the case of alternate syntax, the control definition is between DEFINE....END statements and the property values can be in any order. That is the advantage of alternate syntax though it requires more lines of coding.
For example, both the following are right:
define textbox t1
row 10
col 10
width 100
height 30
end textbox
define textbox t1
row 10
col 10
height 30
width 100
end textbox
