Set function key to a Value
franco
Post by franco »
Hello again,
I am trying to set function keys to values like I did in Clipper.
Clipper command Set function 22 to '123'
When ever I hit ctrl+function 2 in a inputbox or textbox it would type 123 in the box.
I can not get this to work in HMG, I know there must be a way to do it.
Thanks in advance........... Franco :?
All The Best,
Franco
Canada
Re: Set function key to a Value
Franco,
you can use:
ON KEY F1 ACTION {somefunction() }
franco
Post by franco »
how could I say
ON KEY F22 KEYBOARD '123'
fRANCO
All The Best,
Franco
Canada
Franco,
Try this:
DEFINE WINDOW Form_1
ON KEY F1 ACTION somefunction()
FUNCTION Somefunction()
keyboard '123'
trmpluym
Post by trmpluym »
Franco
If you use the GUI the command "keyboard" does not work.
When i assume the window (form) is named Form_1, you can use this:
ON KEY F1 OF Form_1 ACTION Somefunction()
_Pushkey(VK_1)		// Press "1"
_Pushkey(VK_2)		// Press "2"
_Pushkey(VK_3)		// Press "3"
Theo
Hi Franco,
Alternatively, you could do this:
    cFocusedControl := GetProperty( 'Form_1' , 'FocusedControl' )
    SetProperty( 'Form_1' , FocusedControl , 'Value' , '123' )
Hi Franco,
    SetProperty( 'Form_1' , cFocusedControl , 'Value' , '123' )
Or:
ON KEY F1 OF Form_1 ACTION SetProperty( 'Form_1' , GetProperty( 'Form_1' , 'FocusedControl' ) , 'Value' , '123' )
trmpluym
Post by trmpluym »
Hi Franco,
A little addition to the very nice code of Roberto. To preserve errors when pressing F1 check if the focussed control is an EDITBOX.
IF GetControlType( cFocusedControl , "Form_1") == "EDITBOX"
In addition, to be perfect, you also have to check if the "EDITBOX" is ReadOnly.
Theo
Theo:
AFAIR, the values returned by GetControlType() are the following for text inputs:
For TextBox:
"NUMTEXT", "TEXT","MASKEDTEXT"
For EditBox:
"EDIT" (not 'EDITBOX' )
So, The correct code should be:
IF GetControlType( cFocusedControl , "Form_1") == "EDIT" .Or. GetControlType( cFocusedControl , "Form_1") == "TEXT"
trmpluym
Post by trmpluym »
Roberto,
You are right, thanks for improving the demo !
Franco can go on now :D
Theo
